My Timbrens work great. I recommend them. I'm sure air bags would be nice too, but I don't have to adjust the Timbrens at all and the install was easy.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
Anybody running Timbrens on something heavier, like a F450-F550, with a dump bed?
I've got an older GMC 3500HD dump -- the ones with a SFA and a 15K GVWR. But, invariably, the quarry operators are always loading me heavier than that, which considerably flattens the rear springs onto the overloads and lightens the front end. I've looked into it, and Timbren does offer a rear axle kit for this truck that is rated to 10K. However, it's a $300 kit, and I'm not sure how well they will combat something like a heavily loaded dump bed.
The weekend has probably gone by that you wanted to add one or the other.
In my case, I installed airbags on 2000 F250 4WD after towing my 11K 5th wheel about 500 miles. It brought rear of truck back to level just fine. I run about 40-45 pounds with about 2380 pounds of pin weight. I am real happy with them but never had the Timbrens to compare with.
When not towing, you will be reminded in a hurry to lower the air pressure in the bags down to 3-5 pounds or loose your false teeth.
I placed the "seperate" air inlets in the bottom rail down from fuel tank entry.
Installtion took me about 2 hours on the drivers side and 45 minutes on the passenger side, it should have been a 1 1/2 to 2 hour job total.
I have had them on for a year with about 35,000 miles total driving and 20,000 miles of that has been towing.
Let us know what you installed.
Gary
Pretty Much Stock 2000 F250 XLT Automatic, 10K Mod (Closer to 15K), Banks Gauges for Boost- Transmission Temperature & EGT, & $1500.00 worth of front end work and it still "wanders". Moved from California to Florida in 2007.
The reason I like airbags is that I can always run level.
Run a load add some air.
Need two inches more clearence, add some air.
I am sure the Timbren system works well for it's intended purpose.
2003, F250, Super Duty, Super Cab, 7.3, Auto, 4X4 Silver, 2" lift in front only, 46 gal fuel tank, Billet Grill, 285X75X16 BFG MT, Bilsteins, Firestone Air Rear, B&W Gooseneck, We call it the "Silver Knocker"
What do you mean level, can you get level empty? How much more level do you need to get? Like I mentioned above, this is with about 7k rear axle weight,,,(Not on the "PIN" as misconstrued above)[img]/ubbthreads/images/graemlins/grin.gif[/img] Whats not level about that?
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics!'03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
I had the same set of AirLift bags on my '02 F250, then my '04 F350--after about 230-250k miles, one developed a slow leak. When I traded for the '07, I went with the Timbrens. They are a 'install-and-forget' deal. And the Timbrens work as good as the air bags did. So take your pick.
2009 F450 Lariat 4x4
2007 F350 KR DRW CC 4x4-Gone
2005 Mobile Suites 36TK3
Any Timbren owners carrying 4,000lbs cargo? I have a 5'er with a 4,000lb pin. I have airbags sitting in the garage but will require drilling through my hitch bracket. Timbrens might be an alternative.
2003 350 Lariat FX4 Short Box 6.0L *SOLD*
2008 FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
2007 Keystone Raptor 3712TS PICTURES
I do not know what the actual pin weight was on my truck most loads, but I know I have been at the highest 9400 lbs on the rear axle, (empty trailer I THINK it was around...5200 on the drive) Not sure. (I KNOW, I was over on the drive by about 600 lbs,,, [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]) This was for about 400 miles, and the truck set level, just like in this pic many have seen where I know the drive axle weight was in the neighborhood of about 7k
Wow, that would put the pin in the neighbourhood of 5000lbs. I think I'll start looking at the timbrens.
The Firestones are a joke. I put them on the 01 in sig in may and the right one is really close to the exhaust and spare tire. It' also keeps leaking some how. I've sprayed water everywhere looking for a leak but can't find it. Also, they were a pain in the ass to install. I would never buy a firestone product again. End of story!
1969 Ford F-250 Camper Special 360 V8 4 speed
1998 Ford Explorer XLT 4X4 4.0L V6 124K
Stock. Daily Driver
I have had air bags and timbrens and I will go with timbrens again if I ever need more capacity than the factory camper package provides.
07 White /AZ beige F-350 4x4 CC LB fully loaded Lariat. Leveling Kit 325/60R18 Terra grapplers on Moto Metal wheels. B&W turnover ball hitch . Eclipse AVN6610 Navigation/DVD system. Back up camera, Headrest screens, IR headphones, Integrated I-pod 80gb Rockford Fosgate P3S 12" subs, MB Quart midbass, mids and highs front and rear, powered by old school Rockford fosgate. Pulling an 05 Raptor 3612ds toy hauler Full of Honda and Yamaha ATV's.
Last truck: 04 silver XLT 4x4 cc sb 6.0
Before that: 01 silver 4x4 XLT cc swb auto 3.73 limited slip ,PMT3
First super duty: 99 red F-250 4x4 sc sb XLT 7.3 auto 80 hp superchip 4" exhaust.
