Old 07-17-2008, 08:49 PM   #1 (permalink)
Time for 7 new tires
Well, my 5er's tires are showing some cracks,,even the spare which is in the shade and never touched the ground. I know this has probably been discussed a lot in the past, but i need you guy's advise on the best trailer tire.
My 5er is a 39' toyhauler..with 225/75/15 (3 axle) I need the heaviest duty that i can run on a 15" rim. Greenballs any good? I have marathons on my car trailer, and boat trailer, but this 5er is heavy** The tires on there now are Generals..no troubles until they started to crack.
By the way, John Wood Transmissions ROCK!
2002 F350 Lariat CC SRW 4x4 LB , Shadow Gray, Edge 4.5" w/ dual bilsteins up front/ Toyo Open Country M/T 315-75-16. Stock Motor 7.3, dual alts / 3 guage pillar pod, Auto Meter/ 5" turbo back magnaflow exhaust w/Aeroturbine muffler & 6" Jardine tip/ Husky 24k 5th wheel / Air Lift Bags.
John Wood Transmission / DP tuner / 08' rear diff cover
2005 40' Weekend Warrior 5er, SLC 3905
1977 Tahiti 21' / Berkeley Jet Daycruiser/ 455 Olds.
2000 Sandcars Unlimited / Turbo VW 2275
415_dezl is offline
Old 07-17-2008, 09:07 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Last time I needed trailer tires, I planned ahead and ordered Denman ST225/75R16E. Yes, load range E. Very few outfits make that tire in load range E. My dealer didn't have any, of course, but he ordered them and it took a couple of weeks to get them.
On the following link, scroll down to radial tires, then look for that size with 10 P.R. (ply rating). 10 ply rating is the same as load range E. http://www.denmantire.com/catalog/22.pdf
If you can't find a Denman tire dealer nearby, call Denman at 800-334-5543 and maybe they will tell you their nearest dealer to you. Or maybe they will ship you 7 new tires direct from Denman.
Second best trailer tire in that size is Cooper Custom Trailer Plus. But they don't make it in load range E. Cooper Tires. Then click on tires, then on light truck, then on Custom Trailer Plus. I have those on my 5er, and they have been great. But expensive. The Denman in load range E will probably cost you less than the Cooper in load range D, but most decent-sized towns have a Cooper dealer.
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; TurboRamAir intake and 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and TTM; AIC. I special-ordered it new and plan to drive it until it quits.
SmokeyWren is online now
Old 07-18-2008, 09:53 AM   #3 (permalink)
Location: Spring Creek, Nevada(Summer) Quartzsite, AZ.(Winter)
If you plan on keeping the toyhauler for a while, I would consider biting the bullet now and going all the way with 16" wheels and tires.
Many more options in 16" tires when you need to replace again.....plus the comfort of knowing that you have enough tire capacity for the load.
I agree that JW Transmissons "rock" ......so does a 1977, 21' Tahiti Daycruiser.
2001 F550, Crew Cab, Royal Sport bed, John Woods transmission, 4.88 gears, Gear Vendor, A pillar gauges, Banks Power Elbow, 4" turbo back exhaust, Cyclone fan, Zoodad, AFE Magnum Force intake system, Westin Nerf Bars, 70 gal.aux tank(installed in the bed gravity feed), 10 wheel TireSentry pressure monitoring system, pulling a Dutchmen 35SRV toyhauler with a Harley Roadking Classic or a Polaris RZR in the "garage".
crrroger2 is offline
Old 07-18-2008, 11:11 AM   #4 (permalink)
Smiley1's Avatar
I will be getting new tires soon as well.
I noticed that the Denman cary Bias Ply ST and Radial ST in the same sizes and weight ratings. Is one better constructed than the other? Or is it towing charactaristics that are different?
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
1996 Saturn SL2 commuter (37 mpg)
Smiley1 is offline
Old 07-18-2008, 12:19 PM   #5 (permalink)
My Photos: (11)
Michelin Americas Truck Tires XTA® Page
Maxxis.com
the maxxis is a very nice trailer tire i have seen in action on alot of construction trailers
2007 Dodge 3500 4x4 QC DRW 5.9 G56 3.73
2006 f-250 4x4 V10
(Sold 3/2007)
97 f-350 4x4 xl 5spd Swamped
(SOLD 4/2005)
79 f-250 472ci
5.13's 1 tons locked f/r and chromo goodies
grooved 44 tsl's, stuff
My Gallery
85351ho is offline
Old 07-23-2008, 12:52 AM   #6 (permalink)
thanks for the input guys....I looked at the denmans..seem pretty good. Will the stock weekend warrior chrome steel wheels take 80psi? I haven't had one of the tires off the rim to check. I will do some research and let you know what i come up with. Yes i know 16's are the way to go but DAYHUUMM..the cost! the General Ameri-stars *SP* that were on there have a rating of 2350lbs or so...isnt' that pretty good? they did crack..but i've had the trailer in the sun for five years..no blowouts.....or should i still go with what you guys are recommending?
415_dezl is offline
Old 07-23-2008, 01:02 PM   #7 (permalink)
Denman Tire -
Here is a place where you can get the Denman Express 10 ply load range E tires in your size for $106.95.
Currently, I have the Power King Towmax® Radial ST Trailer load range D tires on my toyhauler, and so far, they have had no problems. They are made in China. Also the STR model is available in load range E.
TBC Corporation - Private Brands (Multi-Mile, Cordovan, Sigma, Vanderbilt)
2001 F350 XLT 4X4, shift on the fly, 38 gal fuel tank, running boards, sliding rear window, black, crew cab, long bed, 4.10, automatic transmission, 11,500 gvwr, 20,000 gcwr, 7500 gvw, dual rear wheels, 7.3l turbo diesel, completely stock, 114,00 miles when purchased, now has 125,000 miles, repairs so far: starter, batteries, cps.
DonWarkentin is offline
Old 07-25-2008, 12:03 AM   #8 (permalink)
If the tire is costly...then its probably worth it. As mentioned before, I would look into 16" wheels too..good luck!
2000 F-250 Lariat PSD, AT, 4x4, CC, SB. Autometer pillar gauges, 4" Diamond I exhaust, aFe Stage 1, TS Performance chip, billet torque converter, ATS housing, Wicked Wheel, Banks Big Head, two carseats, four cupholders.
2006 31' Wildcat Quad-Bunkhouse fifth wheel
taterkyle is offline
Old 07-25-2008, 07:25 AM   #9 (permalink)
dklein's Avatar
I have greenball towmaster load range D on my TT and so far no trouble,but I have not towed in extreme heat yet. Whatever tire you decide upon don't forget to replace the valve stems with a good quality metal type, they are just as important as the tires. Good luck with your choice and I'm sure you already know how important the proper air pressure is!
dklein is offline
Old 07-25-2008, 05:11 PM   #10 (permalink)
fastzr1's Avatar
I run the Maxxis trailer tires on my race car trailer. Good tires IMO but only load range D in a 15" 225/75 but they are good for me. I'll buy them again at just over 100 bucks a tire.
Ed
04' F250 C/C, SWB, 6.0L, 4x4, True Blue/Silver
ISSPRO Gauges, Firestone Air Bags, LEER Cap, Super Liner Spray In
I love my truck.
fastzr1 is offline
Old 07-25-2008, 05:49 PM   #11 (permalink)
M8008 ST Radial
Maxxis are available in either 6, 8, or 10 ply in the 225/75R15 size.
M8008 ST Radial
https://www.shopmaxxis.com/b2c/
$158.90 10 ply
$135.86 8 ply
Old 07-26-2008, 08:44 PM   #12 (permalink)
I use same size tire on trk and trl. This way I move trk back and always have good tires on trk. Not to mention I get to write them off that way.
early 99,67 galaxie 500 with 6.2 liter diesel
conntrail is offline
Old 07-29-2008, 10:54 AM   #13 (permalink)
lincster's Avatar
My Photos: (22)
That Warrior is a heavy trailer.
I would step up to the 16" wheels/tires if I were you.
I did on my LE3905 and am so glad I did.
Michelin XPS Ribs are the strongest E rated tire on the market.
Spend the money 1 time and you won't have to worry about them again.
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... man does this thing tow, Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
lincster is offline
