Tire Pressure for Towing - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 09-06-2005, 08:30 PM Thread Starter
285 / 75 / 16 BF Goodrich AT's on my '02 PSD crew cab 4x4. Will be towing a 16' tandem axle flatbed trailer and vehicle on it totaling 5000 pounds give or take a few lbs. What's the proper tire pressure I should be running while towing? Thanks for helping a newb out!
2002 PSD Lariat 4x4 procomp 4" lift with 285/75/16 BFG AT's on stock rims. Custom brush guard with 2" receiver.
HighF250 is offline
post #2 of 13 (permalink) Old 09-06-2005, 09:43 PM
Re: Tire Pressure for Towing
When towing you should run the maximum pressure on the tire sidewall. Others please correct me if I'm wrong, but I believe load range "E" tires are 80 PSI and load range "D" are 65 PSI.
2005 Ford Excursion 6.0 PSD,
2003 Ford Expedition
Clevelandjim is offline
post #3 of 13 (permalink) Old 09-06-2005, 10:07 PM
DezRacer's Avatar
I always run max on mine when towing, same tires, no problems. The way I see it, what can it hurt?
"I just want to be free, free to ride my machine, and not get hassled by The Man"
DezRacer is offline
post #4 of 13 (permalink) Old 09-07-2005, 09:31 AM Thread Starter
Thanks, I appreciate the help.
HighF250 is offline
post #5 of 13 (permalink) Old 09-07-2005, 10:18 AM
lincster's Avatar
My Photos: (29)
Not necessarily. There have been posts by Smokey that show tables for tire pressures based on weights.
Or you can go to some of the tire manufactures websites and look for load/inflation tables.
In order to get the pressure correct, you have to know your individual axle weights.
2012 F350 4X4 Dually, FX4, Crew Cab, Ultimate Lariat Package, Oxford White, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
lincster is offline
post #6 of 13 (permalink) Old 09-07-2005, 10:37 AM
SmokeyWren's Avatar
My Photos: (45)
First you need to know the weight on the front and rear pickup axles when on the road with the trailer. Any big truck stop with a certified automated truck (CAT) scale will give you those weights for less than $10.
Here's an example that might fit your rig:
Front axle = 4,440 pounds, or 2,220 pounds on each front tire.
Rear axle = 5,480 or 2,740 pounds on each rear tire of an SRW pickup
Load inflation table for 285/75R16 tires:
PSI Load
35 1910
40 2100
45 2280
50 2470
55 2625
60 2790
65 3000
So for that example, 2,220 pounds on each of our front tires requires 45 PSI. 2,740 on each rear tire requires 60 PSI. So for that load with those 285 tires, you should run 45 front and 60 rear.
But there's fine print to the load/inflation table. If you drive more than 70 MPH when towing, then add 10 PSI to each tire (up to the max PSI on the sidewall). So if you're dumb enough to tow at more than 70 MPH, then your tire pressures should be 55 front and 65 rear. (65 is the max pressure on your sidewall.)
All tire manufacturer's have the same load/inflation table - published by the Tire and Rim Assn. So one manufacturer's table is good for all brands of tires. Here's the Goodyear version: http://www.goodyear.com/truck/pdf/LoadInflLTMetric.pdf
SmokeyWren is offline
post #7 of 13 (permalink) Old 09-07-2005, 12:32 PM
I am towing a 13,000 lb 5er. My tires are E rated. I set my rears at 80 PSI cold and my fronts at 70 PSI cold when towing. When I am not towing I run 55 PSI rear and 50 PSI front. Seems to work fine.
2004 Expedition
2003 F250 C/C V10, Banks Power Pack, Transcommand, 4.30LS, MagHytec Diff Cover, B&M Deep Trans Pan, 16K Super Glide Hitch
2006 Thor Vortex 36' 5er Toy Hauler
FastDEW is offline
post #8 of 13 (permalink) Old 09-07-2005, 12:48 PM
haul_n_horses2's Avatar
My Photos: (17)
[/ QUOTE ]Why more in the rear than the front when unloaded? There is more weight on the front axle unloaded. Hence the reason Ford specifies a higher pressure up front than behind.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #9 of 13 (permalink) Old 09-07-2005, 06:36 PM
What Smokey said. I have 50K on my original tires, and they are 50% worn as checked at a tire store. My tires have never saw anything near 80lbs. I have a GVW of 9900lbs when towing and have never had a problem. I run 65 in both front and rear when towing and lighten up when empty. Over pressure causes a harsher ride and make the tires more prone to damage from objects on the road.
JGR [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
2000 F350, Ecab, LWB, SRW, 4X2, ZF6, Full Gauges, Ebrake, Chipped 271rwhp/584tq, Scan gauge II, Coolantfilter, fumoto valve, oil by-pass filter, CCV mod with return to intake, dahl 100, 40 gal. aux tank, straight piped, PML cover, 203 stat and billet, AIS, Zoodad
pristine is offline
post #10 of 13 (permalink) Old 09-07-2005, 07:01 PM
My Photos: (17)
Well I aired mine up to 65 front and 60 rear based on the inflation tables I was just barely adequately inflated for the 18K# of horses and trailer based on the CAT scales. [img]/ubbthreads/images/graemlins/eek.gif[/img]
post #11 of 13 (permalink) Old 09-07-2005, 10:22 PM
65 up front loaded or empty (handles better)
40 in the rear empty, 80-85 loaded (depending on load)
The pressure on the sidewall is COLD pressure that's early in the morning before the sun hits them (or the tire hits the highway), after that when loaded they go up substantially. A 265/75E16 will run at 90-100PSI fully loaded in the summer at highway speeds this is the operating pressure of the tire. I have, and continue to inflate over the max PSI on the sidewall if I know I'll be overloaded or if I'm checking pressures at any time other than early dawn.
Flame suit on...
This space intentionally left blank.
444turbodiesel is offline
post #12 of 13 (permalink) Old 09-08-2005, 11:21 AM
Hi, this sounds exactly like my set up, sig truck plus, a 16' tandem axle trailer with my 5000 lbs jeep, total pulling weight 7500 lbs, about 750 lbs tongue weight. I run 55 PSI front and 52 PSI rear on my BFG a/t 285-75-16 with a good tire thread contact, GCW at 15200 lbs.
blueangel is offline
post #13 of 13 (permalink) Old 09-09-2005, 01:10 AM
Correction.... 55 front / 50 rear unloaded.
2004 Expedition
FastDEW is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
