Old 06-19-2007, 01:25 PM   #1 (permalink)
tires or re-gear rear end
Hi, I have been reading a topic on the 3.73 V/S 4.10 rear ends. I have a 99.5 F-350 PSD that I purchased about 3 months ago. It is a stock truck 4x4 with 3:73. I bought it to pull a 10K fith wheel. Well I pulled it last week end for the first time and do not think it is up to par. I know that I am going to do some mods, but my first question is how much are my tires hurting my performance? I am running 295/75/16 on a stock rim.
I have a F-250 5.4 with 4:10 and it seems like it towes better than the PSD. I know this should not be the case so I am in search of what could be wrong. Can tires make that big of a differance?
Paul
99.5 F-350 PSD cc 4x4
2001 F-250 5.4 sc 4x4 soon to be sold (SOLD [img]/ubbthreads/images/graemlins/frown.gif[/img])
country2 is offline
Old 06-19-2007, 01:35 PM   #2 (permalink)
Send a message via ICQ to GreyHorse
Re: tires or re-gear rear end
I would try going back to the stock tire size, that's the cheaper of the two options. My 2k 4X4 pulls large trailers just fine.
Also, how are your fuel and air filters?
2000 F-350 CC, SWB, 6 speed, SRW, 4X4
1985 Mercedes 300D
1999 International 4900 DT466e 250/660 Allison MD3060
GreyHorse is offline
Old 06-19-2007, 01:47 PM   #3 (permalink)
Believer45's Avatar
My Photos: (17)
Just to give you an idea where to start (and assuming the stock tire size at 235/75 x 16), a 235/75 x 16 tire is approximately 29.7" tall. A 295/75 x 16 should be approximately 33.3" tall.
The 235/75 x 16 travels @ 7'9" per revolution, the 295/75 x 16 travels 8'9" per revolution.
The 295/75 x 16 tires with 3.73 gears will give the same effective ratio as 235/75 x 16 with 3.32 gears. This scenario is what you have now.
295 tires with a gear ratio of 4.185 would give the same effective ratio as 235 with 3.73. This scenario is what you would have with the (I believe) stock tire size.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
Believer45 is online now
Old 06-19-2007, 01:51 PM   #4 (permalink)
Air and fuel filters OK. I am going to check tubo boots this week end. I just bought these tires though and if they are a big issue I am going to try and swap them out.
I was having to turn the OD off on the slightest grade and EGTs were up around 1000 at 60 - 65 mph. With out the trailer it seems OK.
country2 is offline
Old 06-19-2007, 04:57 PM   #5 (permalink)
You'll notice a substantial difference swapping out the tires. If you are mainly using the truck to tow that would be my recommendation. If you need the width to keep from sinking in the pasture that's a different story. I think you'll find the truck to be more stable, get better fuel mileage, stop better and tow better with stock sized tires.
'94 F350 4x4 PowerStroke, 5-speed, 4.10 gears, crew cab, XLT, Luk Clutch, ZF-47, 294,000 miles
'96 F350 4x4 PowerStroke, auto, 4.10 gears, crew cab, XLT, DRW conversion, 436,000 miles
'95 Lance 11'3" Model 900
Diesel_Aggie is offline
Old 06-19-2007, 06:43 PM   #6 (permalink)
my stock tires were 265/75/16. big difference between the 265 and 295.
would there still be noticable difference
country2 is offline
Old 06-20-2007, 02:07 PM   #7 (permalink)
My math shows your current tires are 10.2% taller than the stock size. Most tire makers will have a technical specs area on their web site showing revolutions per mile, tire hieght and width. All tires of the same size don't measure out the same for some reason!
265 x .75= 198.75
295 x .75= 221.25
198.75/221.25=0.898305 for 10.2% difference in height.
There are other ways to calculate this where you compare total tire height but you come up with the same percentage.
I feel it will make a big difference. I ran 305/70-16 Dunlops mud terrains on a '94 F-250 4x4 reg cab. Major difference in acceleration and much worse pulling hills with 7000 pound flatbed trailer. Mounting a wider tire on a stock wheel causes the sidewall to be a different profile and allows more sway side to side. Mounting on a wider wheel solves most of that. Most tire makers will have recommended rim size to mount on and I bet 16x7 is not the recommended one for your tires. I have 33/12.50-16.5 BFG Mud Terrains on 9.75 inch wheels on my '94 and it also took a big hit in accelleration and towing. Stability is great with the wide wheels. I'm willing to trade off the power and 1.5-2mpg hit because I use the truck in the pasture and on logging roads. I hope this helps you out some. If you can find someone with stock rims/tires see if you can swap them to your truck for a test drive.
Old 06-20-2007, 06:58 PM   #8 (permalink)
Thanks for that info. I like the way these tires fill the wheel well and they do look good, but I bought the truck to tow and I can not sacrifice the towing performance for looks.
I plan on doing an exhaust, intake and a modest tuner or chip and a 6.0 trans. cooler. Will that off set the tires or would you still recommend stock.
I dont mean to ask redundent questions but I need to make a decision on swapping tires soon. I bought them from Discount tire and they guarantee your satisfaction.
country2 is offline
Old 06-20-2007, 11:13 PM   #9 (permalink)
You might even consider 245/75/16. They are shorter and would gear you down more yet.
06 F-250 King Ranch, 6.0, Auto, 3.73, 4x4, SWB, 18" wheels, sunroof, adj. pedals, White.
03 F-250 King Ranch, 6.0, Auto, 3.73, 4x4, SWB, Chestnut,32,500 miles Traded with owner loyalty rebate.
2000 F-250 CC Lariet, v-10, 4x4, SWB, auto, red, traded.
97 F-250 CC XLT, 460, Auto, 4x4, SWB,Red+White traded.
93 F-250 Supercab XLT,460, 5-spd,4x4, LWB, Blue, traded.
88 F-250 reg. cab, XLT, 460, 5-spd, 4x4, Blue,traded.
79 F-350 reg. cab, XLT-lariet, 400, 4-spd, 4x4, Orange+cream, traded.
74 F-250 reg. cab, custom, 390, 4-spd, 4x4, Blue, my farm truck.
I LIKE FORDS !!!!
DaveM is offline
Old 06-21-2007, 04:17 AM   #10 (permalink)
Send a message via ICQ to sandfun
my truck and trailer is 22,000 lbs gross combined.....towes good on the flat but hills kinda kill me....i tried 285/75/16....and it towed great....but couldnt live with the looks....oh vanity vanity.....anyway....the torque converter lock up mod kinda helps my situation.....if the hill is killing me ....i drop to second and locket....can to 45 in second ....on my 35s......but my advice is if you dont need the looks the tire size is absolutley you'r best option....
2001 f250 4x4 cc sb , 6 in lift, cheyenne wheels, 3.73 gears, 4 in exhaust with muff delete ,piller gagues, trans coolers, dp 6 pos chip, zoodad ,exhaust wrap insolation on air return ,air bags,ladder bars, 3 extra leaf kit ,,,,,,john wood transmission ,,,6.4 torque converter----so far
sandfun is offline
Old 06-21-2007, 05:03 PM   #11 (permalink)
Sure that will offset the tires some and maybe be better than stock tire performance. No easy calculation for that. If you do the mods and have stock tires then it's even better. It comes down to the trade offs you are willing to accept. Do you want to pull the trailer down the road or yank it down the road? Only you can set priorities and decide what is best for your needs.
Old 06-21-2007, 08:13 PM   #12 (permalink)
v_lombardi's Avatar
My Photos: (18)
i had 245/75-16E on my truck and it made a big difference for off the line power. i now have 285/75-16 and will never do that again. i took a 235/85-16 bfg a/t and a 265-75-16 bfg a/t and put them side by side, they were the same height, but my next set of tires will be the 235/85-16E's.
vince
1996 F-350 auto XLT CC SRW 4x4 off road. Hypermax dp, Hayden aux elect fan, 285/75-16 BFG at's, factory ford locking hubs, 6,900#'s empty.
Integrity: Steadfast adherence to a strict moral or ethical code. PHOTOS
v_lombardi is offline
Old 06-21-2007, 10:12 PM   #13 (permalink)
Yes, there is usualy a trade off between looks & function. It takes money to have both. Do you tow more often at 55mph on 2 lane blacktop, or on the highway at 70mph? How often do you tow & how far. How often do you drive truck unloaded?
[/ QUOTE ] These mods will definately make a difference, & I recommend them regardless. Do the mods, then decide on tire size. Add Guages to your list, Exhaust Pyrometer, Trans Temp & Boost are good to start with.
[/ QUOTE ] How much time do you have before you can't take them back? I'd get modding right away, anything is a good reason to mod.
I have a US Gear, which makes my 3.73's closer to 4.56's. With the US Gear, you can run bigger tires & Tow. Then when unloaded, you can run in stock gearing for highway mileage. One thing to remember is, Bigger tires generally result in lower fuel economy.
Don't sweat the questions, yours are normal & there are many on here who enjoy helping others. Great Site.
My Photos----- BTS BUBBA "Life Member"
2002 7.3L Excursion 4x4, FTVB, MBRP 4" SS Exhaust, Rancho 9000X shocks, "V" code Front Springs & "B" Code Rear Springs, Ride Rite AirBags, Rear Hellwig Swaybar, Cut Front BumpStops, DieselSite Ext Trans Filter Kit - Coolant Filter Kit & 203 stat, "Scotpart" mod, "Hutched & Pooned", "LandYot" Radius Rods US Gear Overdrive 75mph @ 1750rpm's
2001 7.3L F350 CC LB 4x4 5" Exhaust, pillar guages, BTS Trans, US Gear Underdrive, DP 6 pos chip, V10 Trans Cooler, DieselSite - Coolant Filter Kit, Evans Coolant, 203 stat, DI reg Fuel Return, GT38R BB Turbo, AFE 2 Intake, Banks Intercooler, Air Rite Bags,
2000 Excursion Limited V10 4x4 7" Lift
"Family of 5 saved by Grace"
Snowman269 is offline
Old 06-21-2007, 11:02 PM   #14 (permalink)
Thanks for all the input. I installed guages 2 weeks ago and am ready to start mods.
I do not know but I think I am past the return date on the tires. I am thinking about going tomorrow and push their satisfaction guarantee and try to get them to swap them for some Goodyear Wrangler silent armors, 265/75/16E. I think they have the white letters and look pretty good.
I will be towing more highway at 70 mph and the truck will tow more than not.
country2 is offline
Old 06-22-2007, 09:50 PM   #15 (permalink)
Went today and was able to swap tires. I went with stock 265/75/16E. hey are smaller and do not look as sporty but even empty I can tell a difference. It does not take near as much to get the truck rolling and it accelerates so much faster.
Thanks for the input.
country2 is offline
