Re: torklift tiedown
I have an '86 f350 crew cab with tork lift tiedowns. The truck originally had full-length steps from front wheelwell to the rear wheelwell. The tork-lift installation required getting shorter steps that ended just at the rear of the rear door.
I think the tork lift system is better than others I've seen. I now think that the weakest part of the system is the camper tie-down points, which are secured by an eyebolt. The eyebolt goes thru a 3/8 inch hole in a 3/4 inch wide 1x2. These pissant pieces of wood tend to buckle when you try to cinch the tork-lifts down to spec.
If you don't have anything to do, get a used diesel and a camper!
Truck 1: 1985 F350 dually 4WD 6.9 diesel crew cab auto with 83k original miles. C6 trans, 4.10 rear end. Mods are Banks Turbo, US Gear overdrive, 45gal rear tank, hydroboost brakes, additional leaf springs all around, Hellwig airbags, rear sway bar, GM glowplug controller, fuel Koalescer. 235/85 R16 Michelin XB Rib radials. 11ft.6in Vacationeer cabover camper, TorkLift tiedowns.
Truck 2: 1988 F250 7.3, C6 auto, 2WD w/3.55 limited slip rear axle, Banks Sidewinder Turbo, Gear Vendors overdrive, Utility box, hydraulic lift gate, lumber rack.
Auto: 1987 MBZ 300D Turbo 3.0 Liter 6 cylinder engine. 205K miles. Working on all the "little things" that previous owner neglected. Putting in wvo tank.
