I have a 2000 F-250 PSD Long bed. But they have the stock (lo profile) mirrors. Can I replace them with the newer telescoping tow mirrors without doing major re-work? Will the power mirror controls I have now work with the new mirrors? Or, should I just get the 'slip ons'? I don't have a fiv-er yet but am looking at getting one realllll sooon.
I'm not 100% sure, but you should be able to mix and match the mirrors no problem. I would also think that the plug for the electric will match up too. You are just going to spend some $$$ for the mirrors.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
I have a set of good condition power heated telescopic tow mirrors of my 00 X in the next week or so I will be selling in the for sale area on TDS.
FMT
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
My current mirrors aren't heated. If I install the heated one's how do I get power to the mirror heaters? and, how much would you be asking (round figures)?
option 1, Run the mirrors without the mirror heat.
option 2, Run a wire through the door and wire it to a switch or wire them to be on all the time like the trucks have them and tap into the power window or door locks for key on power.
The mirrors have 2 connectors, one is the round one that will plug into the same harness the power paddle mirrors use for adjusting them, the other connector is a square one for power and ground to the mirror heaters.
I will PM you on the asking price.
FMT
