Tow ratings - Diesel Forum - TheDieselStop.com
Old 09-07-2006, 11:11 PM   #1 (permalink)
Tow ratings
Can someone give me the tow ratings for both tag and 5th wheel trailers for a 97 F350 CC SRW 4x4 7.3 Powerstroke and 4.10 gears.
I cant find anything before 99.
Thanks.
Phil
1997 F-350 Crew Cab 4x4 PSD-
Currently has Superchip, downpipe, no kitty and full exhaust.
4" lift and 33" BFG AT's
TurboLark is offline
Old 09-07-2006, 11:17 PM   #2 (permalink)
Re: Tow ratings
Nevermind..found it in the faq section. Damn, only 12,500lbs.
Phil
Old 09-08-2006, 10:28 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Re: Tow ratings
And that so-called "tow rating" is very misleading. It assumes your wet and loaded truck with everything you normally have in the truck, including driver, passenger(s), toolbox full of tools, cooler full of cool, both tanks full of fuel, hitch installed, whatever, will weigh only 7,500 pounds. And I'll bet your tow vehicle weighs a lot more than 7,500.
So to determine your real tow rating, load up the truck they way it will be loaded on the road, go to a truckstop with a CAT scale, fill up with diesel, then weigh the wet and loaded truck. Subtract that weight from 20,000 pounds that that is your real tow rating. If your tow vehicle is a CrewCab 4x4 PSD, your real tow rating will probably be way south of 12,000 pounds.
SmokeyWren is offline
