Anyone towing 12k-14k with 385/65/22.5 super singles? Obviously the tires are not the week link. I want stablility and currently have a f250 with 8" Fabtech and 39 Mickey thompsons but don't want to lower the truck. What springs, sway bars or bags would be needed. Height shouldn't be an issue with a proper setup suspension f650's are pretty big.
I have towed 10k with my last truck (94 F350 CC, 9" lift, 335 80 R20 Michelin XZL Super Singles) It wasnt like towing with a DRW truck, but the stability was not an issue. GCW was 20k, and I towed this 1000 miles. As long as the springs are still 1 ton springs, and you have lengthened your factory sway bars, you should be fine.
What kind of hitch do you have? There are only a handful of receivers that will handle 12-14k of weight, in a weight carrying setup. Make sure your receiver, hitch and ball can all handle the weight.
99 F350 XLT 4x4, Crew Cab, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
Looking on the Michelin website, the 385/65R22.5 tires weigh about 180lbs. This is about double the weight of a PAIR of the 235/85R16 tires (45-55lbs/each) you would see on a dually. With the weight and the increased diameter, you're looking at a factor of 2-3+ increase in the rotational inertia of the tires/wheels. It might be prudent to investigate some brake upgrades, and perhaps some stronger wheel-bearings and steering components. (Or just swap in the axles from an f-650).
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting. webshots
Can't comment on the Super Singles. But why bother? I tow that much on Toyo Open Country MT tires. The 37x13.5Rx17 is a 10 ply tire with a 4,300 lb rating. It's a stiff tire and with anti-sway bars and air bags, towing is very stable.
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, Fox Shox, 37x13.5x17 Toyo Open Country MT on Weld Evo Velociti XT, 4.88 Gears, MagnaFlow Exhaust, AMP Research PowerStep, Auto Meter Cobalt Gauges (EGT Boost Trans), ScanGaugeII, Firestone Air Bags/Compressor/Tank, BulletProofDiesel EGR Cooler, Valvoline lubricants, Final Charge Global ELC, DieselSite Coolant Filter
I will probably build a subframe to lower the hitch mounting point rather than a huge drop hitch. Then upgrade to a larger receiver.
How was the cummins swap? What kind of costs?
Cummins swap was fairly straight forward. If I had to do it again I would use DESTROKED: Cummins Conversions products and probably put a CR motor in, instead of a 12V.
As for costs, tough to say. I rebuilt the motor during the swap with alot of aftermarket upgrades. I try not to think about the costs
How do those tires wear? The load rating is pretty impressive for a 37" tire.
It's a mud tire with a soft rubber compound. But, they do wear evenly and rotating helps keep the noise down. This is my second set and I get about 2.5 - 3 years of use (approx 30K - 35K miles).
