Towing with 2001 F350 SRW - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 05-30-2007, 06:27 PM Thread Starter
Wanted some other folks opinion on my towing issues. 32 ft tag toy hauler (Wind catching tall one), golf cart & dirt bike inside, 60 gal freash water in tank. My guess is 9500 lb or so. (6500 empty) On the 2 lanes I pull with overdrive off, up to 60 mph. Coming home I drove all freeway with some small hills, same 60mph, in OD. Truck is downshifting alot in OD, screaming to 3000 rpm, then kicking back down. Are the rest of you pulling in OD? I have a Walker BTM & k/n drop in filter (I know....) but I can pull a big tractor or bobcat & equip. very easy of the same weight range. Is the wind drag hurting me that bad? Plan on going to the Ford AIS filter/Gauges/DP Tuner 40-60-80 tow programs/6.0 trans cooler or a add on cooler in the next 60 days. It seems like the truck has too much tounge weight, or? Truck is sitting level when loaded, with the equilizing bars on the 3rd link from end of the chains. I just feel I am hurting the transmission dropping down faily often. Other than the needed up grades, anyone have any other opinions? Thanks!
Truck #1 - 2001 F-350 Red Crew Cab Long Bed SRW Auto 3.73 gear, Walker BTM, Ford AIS. Cat ELC coolant, Pulling 30+ft Tag Hitch Fleetwood Terry Toy Hauler (very heavy), New Holland Skid Steer and Massey Fergason 231. Gauges,and DP tuner soon! Truck #2 Bought new - 1986 F250 4X4 460 V-8, C-6 auto (no overdrive!) 3:73 gears. THE LAST regular fuel vehicle from Ford. Bringing this one back to life .... as gas prices soar!
oakhillbill is offline
post #2 of 10 (permalink) Old 05-30-2007, 06:45 PM
Re: Towing with 2001 F350 SRW
what size tires ????
2001 f250 4x4 cc sb , 6 in lift, cheyenne wheels, 3.73 gears, 4 in exhaust with muff delete ,piller gagues, dp 6 pos chip, zoodad ,john wood transmission
sandfun is offline
post #3 of 10 (permalink) Old 05-30-2007, 06:55 PM
That's why I don't like slushboxes: no control.
You're definitely catching a lot of wind, and the faster you go, the worse and worse that gets. Even dropping down to 55mph in over-drive may make things much easier on the truck.
Wind resistance is a real PITA. People tend to think that going 40mph produces twice as much wind resistance as going 20mph, but that's not true. Air resistance is exponential. When you're going 40mph, you're encountering far more than twice the wind resistance of 20mph. 60mph with a big sail, er... trailer, can really put a lot of strain on a truck and on your billfold at the pumps.
If the truck is wanting to downshift that much, just turn overdrive off.
2002 F250 4x4
T-444E 6-speed
Alan_Hicks is offline
post #4 of 10 (permalink) Old 05-31-2007, 12:13 AM
IMHO the problem is the 3:73 gear ratio. I travel occasionally with a buddy that has that rearend ratio along roads that I travel with my truck that has a 4:10 ratio. I was shocked at how much his truck downshifts over stretches of hills that my truck never downshifts on.
97 F250, 4X4, CC, DP, 4" Magna-Flow exhaust, Tymar Intake, BTS 4 Position Chip; BTS Tranny; Baby Swamps,Tru-Cool Max,Autometer 3 gauge A-Pillar,HX,Hot water mod, Centramatic balancers;Correct-Trak;Rhino-liner, SKY-FI, Prodigy Brake Controller, Bilsteins all around, Royal Purple in the Diff, Pro-Tech Headache Rack, N-Fab Nerf Bars, Heated Seats..aaahh. Auto-Dimming Mirror with Temp/Compass; Polk Audio with SONY Head Unit. GOS Headlight Harness with Diode Mod.
bobtaildog is offline
post #5 of 10 (permalink) Old 05-31-2007, 02:47 PM
Parts Jimmy's Avatar
Click on the link in my signature for a picture. I am at about 14-15k gross and have a lot of wind resistance Your future mods will most likely correct most of the problem. Do not allow the transmission to hunt. I use OD almost 100% of the time now with the SCMT, intake and exhaust. Ditch that K & N asap. You will be able to use OD at lower speeds with the chip but watch your EGTs. If they get too high then hit the OD button or pull it down a gear manually. I have also pulled a big tag-along toy hauler. I had no problem with the current mods. [img]/ubbthreads/images/graemlins/cool.gif[/img]
7.3 Power Stroke Diesel, 4R100, 4" MBRP Exhaust, Ford AIC, Motorcraft Air Induction System,
DP-Tuned, AIH Deleted, EBPV Deleted, Bellowed Up-Pipes, Dieselsite Coolant Filter, Bilstein 5100 Shocks, Timbren Overloads, Husky Mudflaps, Hella 700FF Driving Lights, Autometer Gauges
Parts Jimmy is offline
post #6 of 10 (permalink) Old 06-01-2007, 03:24 PM Thread Starter
Standard tire size, 265-75-16
post #7 of 10 (permalink) Old 06-02-2007, 08:10 PM
I'd guess your trailer has 3 axles if it's a toy hauler. I'd also guess that you haven't weighed it. I'd also guess that the 9500 pound figure ain't nowhere close.
I pulled my 10,500#trailer (see sig) with a 2000 SWB F-250 with 3.73 rear and it did okay. Something just doesn't make sense with your truck/trailer, and I suspect you are pulling a LOT more weight than you think.
The first thing you've got to do is weigh the fully-loaded rig so you know what each axle is carrying. I suspect you really need an F-350 with 4.10 rear end, which is what I wound up buying.
Florida Ed
2011 Suzuki Burgman 650cc Rice Rocket Scooter 49 MPG, 120+ MPH, & 2009 Honda Shadow 750cc 51 MPG, 100+ MPH
2001 7.3 F-350 Dually Lariat CC LWB 4X2 Dark Green 4.10 4R100 5'ver Hauler (32' Montana 2 slides 10,500# - 2,000# tongue weight), 106 gal aux tank, 198K miles, nephews arguing over who will inherit it 'cause I'm gonna' drive it 'til I die. Bone stock.
SOLD 2001 5.4 Gasser F-250 XLT Crewcab SWB 4X2 3.73 4R100 98K miles headed to 150K stock as the day it was made
Before these: '00 F-250 CC PSD, '97 F-250 CC PSD, '94 Ford F-150, '91 Ford E-250, '81 Ford E-150, '66 Ford F-100 (cars not included)
FloridaEd is offline
post #8 of 10 (permalink) Old 06-03-2007, 03:05 PM Thread Starter
It's a 2 axel toy hauler, 6500lb empty weight per decals. Adding 60 gal. water (500lb), gas golf cart (600lb) and 200 lb pit bike, and a 4000 watt generater. Adding 1500 lb cargo is my guess. Only a few clothes and food added to that. I do need to get on a scale somewhere next time I'm fully loaded, to get the real weight. I think the wind drag is a major issue, the front of trailer is slanted back only a bit. I do have a F350 1 ton srw truck. It just seems so odd that I can pull a known weight of 10,500lb (Tractor w/loader & trailer weight) so much better. The toy hauler pulls not bad empty, but add the extra weight of the toys, and it becomes a full load. I did get the Denman trailer tires, they seem much much smoother to pull with. Getting ready to start buying my truck hop up parts this week, gauges first!
post #9 of 10 (permalink) Old 06-04-2007, 10:16 AM
Oakhillbill:
Good luck with your travels. In my old age, I am dedicated to wearing out bearings as my primary occupation. I believe God, nature, or whomever she may be in charge adds a day to our lives for every day we spend out on the road camping.
I'd be interested in a post when you get a hard number on the weights. Remember to weigh the front truck axle, back truck axle, and trailer axles on a separate pad of the scale. Drop the trailer, and then weigh just the truck's two axles on separate pads. That way, you'll know the trailer's tongue weight and your truck's true rear axle weight without the trailer. Scales are about $7 for the first weigh, and $2-3 for a second weigh withing 24 hours. You may be in for some surprises... I have always found the sticker weights on trailers to be less than accurate.
Happy trails.
Florida Ed
post #10 of 10 (permalink) Old 06-04-2007, 11:51 AM
I have 2001 F250 and pull a 33' 5th Wheel Weekend Warrior in OD. When pulling long steep grades I will hit the OD button to make it down shift, the rpm's will rise but not that bad since the TC stays locked. Of course I have a DP Tuner chip that makes all the differense in the world.
2001 F250 cc 4x4 PSD, Monster Box tranny,Tru-cool cooler,AFE Magnum Force,ATS turbo housing,DP Tuner 3pos chip ,4" Magnaflow exhaust,Isspro gauges.
quadloco is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
