Old 04-29-2008, 08:18 PM   #11 (permalink)
Look at this link for a weight distibution, sway control system. I use one on my 28' enclosed trailer and wouldn't tow without one, even on a 20' box.
Equal-i-zer® Hitch - The “American Original” with 4-Point Sway Control™ and Weight Distribution
Ed
04' F250 C/C, SWB, 6.0L, 4x4, True Blue/Silver
ISSPRO Gauges, Firestone Air Bags, LEER Cap, Super Liner Spray In
I love my truck.
fastzr1 is offline
Old 04-29-2008, 08:33 PM   #12 (permalink)
I also use the equal-i-zer hitch for my 11,500 lb tag hitch toy hauler. It works extremely well for me.
2001 F350 XLT 4X4, shift on the fly, 38 gal fuel tank, running boards, sliding rear window, black, crew cab, long bed, 4.10, automatic transmission, 11,500 gvwr, 20,000 gcwr, 7500 gvw, dual rear wheels, 7.3l turbo diesel, completely stock, 114,00 miles when purchased, now has 125,000 miles, repairs so far: starter, batteries, cps.
DonWarkentin is offline
Old 05-01-2008, 06:23 AM   #13 (permalink)
In practical terms, the 8K closed van should be no big deal as long as you keep proper tongue weight. I tow a 16' 7K van with my sig truck without WD, and you have to remind yourself it's back there, even with passing trucks on the interstate. WD might be a nice plus, and the bigger sail area of a 20 footer might make a difference, but I wouldn't worry about trying it without first to see how it goes.
'05 F-350 PSD 4x4 CC SB SRW Manual
PineKnot is offline
Old 05-01-2008, 09:13 AM   #14 (permalink)
Ford's hitches are not over-rated. And I've never heard of one being torn from the truck, though someone surely has and will be happy to tell of the guy their friend heard of who had it happen to him. 8000 lb trailer really isnt much for a superduty. Heck, the VW SUV is rated for 7,000 lb trailers! I learned long ago not to state on here the loads we guys pulling boats do with non-WD hitches. But, safe to say I really don't think your 8000 trailer will tear your hitch off.
If the dealer is telling you this now, how can you trust what ever else he told you? This guy has lost his creditablity by making statements like that.
GM has had problems with some of their hitches recently, but that is rare. And trucks used to have bumper hitches, not frame-mounted class 3-5 hitches. The bumper hitch could tear the bumper off, but has anyone seen one of those in the past 15 years?
All that being said, a WD set up on the trailer with sway control, using the factory hitch, is never a bad idea, and will make the pulling more enjoyable. But the reality is, that is probalby more of a comfort for you than a requirement.
boatpuller is offline
Old 05-06-2008, 09:55 PM   #15 (permalink)
dmd
20-ft wont have much sway if loaded right, but you will want a WD setup.
Some WD setups are set to dampen sway too. I actually have one in a box
in the garage. I took it off when I installed the Hensley, I get NO sway
now with the 31ft TT.
'00 F350 Supercrewzer Lariet, PSD, Auto, 3.73, CC, 4x4, SWB, SRW, F250, Tony Wildman 6-pos Chip, Custom intake, 4-inch turbo back exhaust, ATS housing, ITP overboost eliminator / Packages: Trailer Tow, Camper, Off-Road. Overhead monitor VCR/TV (VCR under rear seat w/ 6 CD changer)
www.employees.org/~calridng (Offroad riding in California)
dmd is offline
Old 05-09-2008, 08:43 AM   #16 (permalink)
let me see now 2 belgians in a 4 horse trailer that sometimes doesn,t have brakes. (not the way i like to work but not my trailer or horses) F350 05 cc 4x4 diesel using non w/d hitch never had a single handling issue, then again my baby also has the camper pkg with rear sway bar etc,that might help things too. i think there may be some differences between towing pkg and camper pkg extra stuff they add. i do know that with my truck camper fully loaded i can go around any corner on any road in British Columbia at or above speed limit and the wife doesn't even notice, corners like my old Trans Am
nitrogen is offline
Old 05-09-2008, 09:31 PM   #17 (permalink)
88beast's Avatar
the torn from the truck story started in a dodge dealership as i hear a guy tried to pull a tractor out and got the truck stuck then both at the same time with another tractor in wyoming or somewhere
but towing is a user preference
does it feel right
does it feel safe
the empty trailer will not need a wd hitch but loaded it may
but some ppl think 8000 lbs is 8 tons which it aint its 4 tons and he may thing you said 8 tons/16000 lbs
buy a hitch that can convert to wd they are out there i think reese has a good one then if you see the need then get it if it tows fine leave it be
and you realy want safe reliable and stable look at the hensley arrow hitch its top of the line
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter, deezee runningboards (cab only), 2 trucklight worklights on front stake pocket each side, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
<span style="color: red">i have created a website for old ford diesels please check it out and tell me what you think</span>
http://oldforddiesels.googlepages.com/home
88beast is offline
