Old 04-28-2008, 08:43 AM   #1 (permalink)
Towing 8000 GVW trailer with F-350
I'm in the process of purchasing a 20" 8000 GVW enclosed trailer. Trailer dealer tells me Fords towing receiver ratings are inflated and unless I purchase a frame mounted weight distribution setup also, the combination will handle squirelly and likely tear the hitch off the truck.
Any of the haulers out there care to offer an opinion if this guy is blowing smoke, or offering sound advice.
Stealth03TDI is offline
Old 04-28-2008, 09:01 AM   #2 (permalink)
I just bought a new 08 F350 V10 and am under the impression that the hitch is rated for 15000lbs. This is a dually LB that I will be getting so it may tow more but I think the dealer is just trying to make a quick buck off you.
collieguy is offline
Old 04-28-2008, 10:17 AM   #3 (permalink)
If you read the fine print, yes it may rated at 15,000 lbs, but probably with a weight distribution setup. Almost every sticker I've seen on the hitches for the rated capacity have 4 numbers: Weight Carrying (straight ball or pintle hitch) GVW, Weight Carrying Tongue Weight, Weight Distribution GVW, Weight Distribution TW. Figuring 10% tongue weight, a 15,000lb trailer will have a TW of 1500lbs. That's a lot. To the OP, an 8000lb trailer will have a TW in the ballpark of 800lbs loaded which is fine for the hitch, but it will give you a much better ride and much more stable towing platform with the WD setup. Trust me, I've been there.
'05 F-250 XLT 6.0 auto CC/SB 4x4 ESOF riding on BFG Rugged Trail's. Bone stock 'cept for the Sirius radio and tonneau cover 82k miles. Turbo replaced during previous ownership. HPOP fitting let loose, recall at 75k.
joshb159 is offline
Old 04-28-2008, 12:13 PM   #4 (permalink)
Looking at weight distribution hitches, they look the same as the OEM hitch the 08's come with. Are there additional rods or something that doesn't show in the picture? It would appear the stock receiver is already a load distribution type.
Educate me!
Old 04-28-2008, 12:37 PM   #5 (permalink)
Here's some homework: || REESE PRODUCTS || Click on "Products" then "Weight Distribution" in the Main Menu.
2008 F350 PSD XLT S/Cab 4x4 SRW L/B Job 2
2006 FR 29RLBS Wildcat
DXprowler is offline
Old 04-28-2008, 08:28 PM   #6 (permalink)
100% correct. The numbers Ford lists are the maximum using a weight distributing set-up. None of them are rated to handle a 8K trailer in weight carrying form...
Here are the specifications for factory '08 Super Duty receivers...
F-250/F-350 Super Duty SRW and F-350 DRW w/5.4L engine (12.5K Receiver - 2")
Weight Carrying - 5,000 lbs. (500 lbs. Tongue)
Weight Distributing - 12,500 lbs. (1,250 lbs. Tongue)
F-350 Super Duty DRW w/6.8L or 6.4L engines (15K Receiver - 2.5")
Weight Carrying - 6,000 lbs. (600 lbs. Tongue)
Weight Distributing - 15,000 lbs. (1,500 lbs. Tongue)
F-450 Super Duty DRW (16K Receiver - 2.5")
Weight Distributing - 16,000 lbs. (1,600 lbs. Tongue)
NOTE... When using the 2.5" to 2" adapter with the 15K or 16K receiver you must follow the 12.5K receiver weight guidelines...
Rear step bumper rating for those who are interested...
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
Old 04-28-2008, 09:19 PM   #7 (permalink)
20" trailer? I'm thinking you could just haul it in the box!
2005 F-350 Crew Cab Lariat 6.0 4x4
2008 F-350 Crew Cab Lariat 6.4 4x4
2006 Jeep Grand Cherokee SRT-8 425 hp 425 lb/ft torque
2004 Jeep Grand Cherokee Limited 4.7 H.O.
2006 Triumph daytona 675 (track use)
2006 Yamaha R6 (track use)
2005 Triumph Speed Triple 1050
2004 Aprilia RSV Factory
2004 Yamaha R1
2000 Triumph Daytona 955i
shawnl is offline
Old 04-29-2008, 07:36 AM   #8 (permalink)
Thompson's Avatar
Weight distribution bars will help transfer tongue weight back to the trailer to lighten the weight on the rear of the truck but you may want to look at a sway bar set up after towing a bit to see how it handles.
Thompson is offline
Old 04-29-2008, 08:13 AM   #9 (permalink)
Stealth,
I wholeheartedly agree with PowerstrokeHD and Josh. Josh hit it on the nose about the weight distribution hitch. With an enclosed trailer when you encounter side winds, or big trucks passing you; you'll feel the trailer give you a bit of excitement. To say it'll tear the hitch off is blowing the smoke out of proportion however. I think you will be satisfied with a weight transfer set up on the enclosed trailer. Get the trailer out and get some pull time on it and see how it handles at highway speeds. If you can test drive someone's unit with a weight transfer/anti-sway unit.... give it a spin. I think you'll agree with Josh, they are nice!
fordson1 is offline
Old 04-29-2008, 08:11 PM   #10 (permalink)
gamudslinger88's Avatar
Thats what I was thinking, Hell thats the smallest trailer I have ever heard of, You could even put it up front with you then you wouldnt have to wory about a hitch. 20 inch trailer......just add water
gamudslinger88 is offline
Old 04-29-2008, 08:18 PM   #11 (permalink)
fastzr1's Avatar
Look at this link for a weight distibution, sway control system. I use one on my 28' enclosed trailer and wouldn't tow without one, even on a 20' box.
Equal-i-zer® Hitch - The “American Original” with 4-Point Sway Control™ and Weight Distribution
Ed
04' F250 C/C, SWB, 6.0L, 4x4, True Blue/Silver
ISSPRO Gauges, Firestone Air Bags, LEER Cap, Super Liner Spray In
I love my truck.
fastzr1 is offline
Old 04-29-2008, 08:33 PM   #12 (permalink)
I also use the equal-i-zer hitch for my 11,500 lb tag hitch toy hauler. It works extremely well for me.
2001 F350 XLT 4X4, shift on the fly, 38 gal fuel tank, running boards, sliding rear window, black, crew cab, long bed, 4.10, automatic transmission, 11,500 gvwr, 20,000 gcwr, 7500 gvw, dual rear wheels, 7.3l turbo diesel, completely stock, 114,00 miles when purchased, now has 125,000 miles, repairs so far: starter, batteries, cps.
DonWarkentin is offline
Old 05-01-2008, 06:23 AM   #13 (permalink)
In practical terms, the 8K closed van should be no big deal as long as you keep proper tongue weight. I tow a 16' 7K van with my sig truck without WD, and you have to remind yourself it's back there, even with passing trucks on the interstate. WD might be a nice plus, and the bigger sail area of a 20 footer might make a difference, but I wouldn't worry about trying it without first to see how it goes.
'05 F-350 PSD 4x4 CC SB SRW Manual
PineKnot is offline
Old 05-01-2008, 09:13 AM   #14 (permalink)
Ford's hitches are not over-rated. And I've never heard of one being torn from the truck, though someone surely has and will be happy to tell of the guy their friend heard of who had it happen to him. 8000 lb trailer really isnt much for a superduty. Heck, the VW SUV is rated for 7,000 lb trailers! I learned long ago not to state on here the loads we guys pulling boats do with non-WD hitches. But, safe to say I really don't think your 8000 trailer will tear your hitch off.
If the dealer is telling you this now, how can you trust what ever else he told you? This guy has lost his creditablity by making statements like that.
GM has had problems with some of their hitches recently, but that is rare. And trucks used to have bumper hitches, not frame-mounted class 3-5 hitches. The bumper hitch could tear the bumper off, but has anyone seen one of those in the past 15 years?
All that being said, a WD set up on the trailer with sway control, using the factory hitch, is never a bad idea, and will make the pulling more enjoyable. But the reality is, that is probalby more of a comfort for you than a requirement.
boatpuller is offline
Old 05-06-2008, 09:55 PM   #15 (permalink)
dmd
20-ft wont have much sway if loaded right, but you will want a WD setup.
Some WD setups are set to dampen sway too. I actually have one in a box
in the garage. I took it off when I installed the Hensley, I get NO sway
now with the 31ft TT.
'00 F350 Supercrewzer Lariet, PSD, Auto, 3.73, CC, 4x4, SWB, SRW, F250, Tony Wildman 6-pos Chip, Custom intake, 4-inch turbo back exhaust, ATS housing, ITP overboost eliminator / Packages: Trailer Tow, Camper, Off-Road. Overhead monitor VCR/TV (VCR under rear seat w/ 6 CD changer)
www.employees.org/~calridng (Offroad riding in California)
dmd is offline
