I am going to purchase an RV. It is between 31 and 34 feet long and weights in right at 7-8 thousand pounds, depending on one of several models I am looking at. The one that I am most interested in comes with the EXACT same floor plan and features both in 5th wheel and conventional bumper hitch. For whatever reason I can buy the bumper hitch model, which by the way, the salesman said are the most purchased type, for about 4800 LESS than the 5th wheel model and I am telling you the only difference is the hitch. I plan to tow with a SRW 1997 F-350 7.3 automatic. Of course this truck will handle the weight of this RV with ease. The dealer tells me he will install all appropriate sway bars and equipment to make the bumper hitch model tow real well. Now from hauling cattle around for years with the truck I know that a goose-neck/5th wheel makes for a real easy tow, but is there any reason I should not save the 4800 bucks and tow this thing with the regular hitch. Any thoughts would be appreciated. [img]/ubbthreads/images/graemlins/confused.gif[/img]
I tow a 31' travel trailer which weighs around 8,000 lbs. I use a Reese Dual Cam which has the sway control built into the weight distribution. No issues for me with this set up. I think the big difference is the 5th wheels usually have more outside storage, and the tag leaves the bed of the truck open.
It sounds like you've answered your own question and I concur with your summary. The 5th does tow a little nicer and has the basement storage area, but the conventional trailer frees up the truck bed ( especially nice if you have an ATV)and $4800 dollars buys a lot of camping fun! -- P.S. I'd be surprised if either unit didn't weigh closer to 9,000lb. Perry.
2011 F-350 Lariat, SRW, C.C., LWB, 4x4, Dark blue pearl metallic
2010 Montana Mountaineer 345 DBQ (5th)
I AGREE I HAVE towed both, and a fifth tows better but not 4800 bucks worth. and also in the event you have an issue with your truck, and a friend could move or tow the bumper trailer if needed. my next one will probably be a bumper pull, its just easier for me, and i could use the space in my truck bed, after all thats why i have a truck and not a wagon.
08 f450 KR 4X4, no roof, no tv, everything else
05 KZ New Vision 41ft toy hauler
03 harley roadking classic
03 honda rubicon
05 bombardier DS650 http://i5.tinypic.com/4ue76eq.jpg
Is your weight correct? I have a hard time accepting a 34' trailer only weighs 8K. My folks 31' alumilight (sp) grosses over 10K. The 5th they just bought is 33' and grosses 14K.
Eithor way the truck will do it. Bumper pulls only get hard when backing into tight places, and get swayie (Is that a word?) when OTR trucks pass you.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
Well you get another 3-1/2 foot of trailer with a 5th. All trailers are measured from the pin to end of coach. On a tag trailer you have the 3-1/2ft tongue to consider in the length that's not liveable space, so a 30ft 5th wheel is 3-1/2ft longer than a 30ft tag trailer.
A 5th/GN hitching just pulls better, period.
I've always liked tag trailers for my past uses and they always pulled well without WD/sway bars but I've always used custom made hitching and I load the trailer correct. The past couple years I've switched to 5th/GN's as my needs have changed and I just like this set-up better.
I can see 8k for a alumimum skined trailer but not for fiberglass skined trailer. Any way for two people plan on about adding 2500lbs on gross weight if your full timing and 1500lbs if not.
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run Define Union: A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
Get the bumper pull, as noted above you then retain full use of the bed for other cargo etc. You can keep all the large, heavy, dirty, etc. stuff out of the camper. I pull a 2200 pound equipment trailer (pintel hitch) with 3+ tons of hay so 8200+ Lbs total weight, across the Cascade passes with no problem. You will NEED to keep plenty of weight on the hitch and the brakes well adjusted or things can get interesting [img]/ubbthreads/images/graemlins/blush.gif[/img].
2004 F350 Lariat CC LB FX4 Auto, camper package, superhitch, rear susp air bags, Rancho 9000 shocks, 800W/1600W 115v power converter, Ultralite gauges in overhead 4 gauge pod, 04/04 build and engine Reman shortblock at 34,000 Due to oil leaks, MBRP turbo back, SCT extreme street by ID
10.5' camper, 20.5" Bayliner Cuddy 5.0 V8
1999 Kawasaki ZRX1100
You don't say if your truck is a short be or long bed. If short, you will probably need to spend some bucks to get a sliding fiver hitch. I mention this only because you could also spend this same money on a TT hitch setup to improve the handling. We have a 34' TT with a Hensley hitch and it pulls just as good as a 5er. This setup is pricey and probably overkill but my point is that you may also spend a good chunk of money setting up your truck with the fifth wheel hitch.
You say the floor plans are identical but there are going to be some subtle differences... Whatever is in the front of the trailer is going to be up steps in the 5er. How is the headroom up there? If there is plenty of headroom, the outside profile of the trailer is going to be MUCH higher the the TT equivalent which can mean clearance problems and more box to pull through the air (mile/gal considerations).
As others have mentioned, with the TT you keep the use of the truck bed too. 5er's certainly have their advantages too: typically more storage space, some have room for (or even come with) generators, shorter overall rig for the same living area, among others.
Hope this helps.
(Oh, and our 34 footer is also around 8000... EMPTY! Once we put all our camping gear in it we will approach the max trailer weight of nearly 10k.)
'06 F-350 PSD/CC/Fx4/SWB/SRW/Auto/20" Wheels/King Ranch/Dark Copper Met
Added: Eclipse nav w/iPod, Rear DVD sys, Turbo-Liner, Retrax, DEBO Step
I had a 31' Travel Trailer and I just chaged to a 32' 5th wheeler. I have pulled my travel trailer from Oklahoma to Florida, then up to South Dakota & back to Oklahoma. What I have noticed is that when pulling the TT (I had the weight distributuion hitch & sway bars installed) it would sway when I would get passed by the big rigs. The 5th wheeler seems to tow alot better - no sway, easier to back into tighter places & my overall length is shorted than before since I don't have that 10' gap between the cab and the leading edge of the trailer. I do have more storage in the fifth wheeler than I did in my TT. Which makes up for the loss of space in the truck bed - but I don't have an ATV.
With my short bed I did have to dump 2K on a superglide hitch. It works great and I am definitley glad I bought it but it was an additional expense. As always - I guess it depends on your situation & needs. For long distance hauling I would go with the 5th wheeler - hands down....my 2 cents
__________________ www.totaldieselperformance.com, Tony Wildman 4 pos chip, 2003 7.3L F250 Lariat, Swamps 175/146 single shots, MBRP exhaust, AIS w/fender sleeve & Zoodad, ISSPRO A-pillar 3 gauge kit(pyro/boost/tran temp), DiPricol HPOP & Fuel, oilguard bypass filter, CCV mod, extreme duty tranny (by Jon Faubion-Richter69), BTS (PI) Torque Converter, AIH delete, 6.0 trans cooler, van turbo w/wicked wheel, Gutted EBPV, DI Intercooler, ITP Overboost Kit , HX mod, Bilstein Shocks, Firestone Ride-Rite air bags w/compressor, Dieselsite Coolant Filter, Schaeffer's 15W-40, ITP in tank mod/pre-pump filter, Harpoon mod
For whatever reason I can buy the bumper hitch model, ..., for about 4800 LESS than the 5th wheel model and I am telling you the only difference is the hitch.
Get out your calculator.
The "good" hitch for a 5er towed by a long-bed pickup will cost less than $1,000 installed. The "best" hitch for a TT is the Hensley Arrow, that will set you back about $3,000 installed. So apply the difference in hitch cost and the TT is only 2,800 less than the 5er. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
And no, I don't believe the only difference is the hitch. Does the TT have a basement to match the basement storage area in the 5er? No, of course not. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
Towing 'cross country, the TT with the Hensley Arrow hitch will tow just as good - with no sway - as the 5er with a Reese 16k 4-way-tilt Classic hitch. There is some difference in turning and backing, but you can get used to whichever one you buy.
The Hensley Arrow hitch is more difficult to hook up than the Reese 5er hitch, but not enough difference to make it a deal breaker.
I would NOT buy a TT unless I could have the Hensley Arrow hitch to go with it. www.nosway.com
For a 5er towed by a longbed pickup, the simple Reese 16k Classic hitch is all you need. For a shorty pickup, you need at least a "slider" hitch, and preferably the Pulliam PullRite SuperGlide hitch. But the SuperGlide is going to cost you almost as much as the Hensley Arrow. [img]/ubbthreads/images/graemlins/crazy.gif[/img] http://www.pullrite.com/superglide.htm
I tow a 31' TT. I have a regular reciever hitch with wieght distribution bars. I do not have sway control on mine & I haven't needed it. It tows stable even when being passed by a semi. I wouldn't hesitate to tow mine anywhere. It just depends on what you want.
'96 F-350 Crew Cab Dually XLT, E4OD w/sonnex & tricume springs, 4:10 gears, Western diesel down pipe & HX hose. B&M Hi-Tek trans cooler w/fan. DP Tuners F5. Tymar intake & 4" exhaust.
You don't need a 3K Hensley!!!!
I pull a similar size and weight trialer and the Reece dual cam does a fine job!!! Not worth 5K difference for the fver!!
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
Gees I must be doing something wrong. I tow a 30 ft fifth wheel with a short bed (always have) and everything is kool. It has worked on a 3/4 GM and the now 3/4 psd short bed extended cab [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Early 99 F 250, Walker Big Truck Muffler, Otherwise bone stock at present.
