Towing with beadlocks - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 03-29-2007, 01:59 PM Thread Starter
Anyone ever towed with beadlock wheels on their truck? Can it be done? Pros-cons?
2004 Ford F250 Lariat FX4 6.0 Powerstoke Diesel SCT Xcal 2 aFe Stage 2 Cold Air Intake 4" Pro Comp Lift Firestone Air lift
35 x 12.50 x 16 Toyo Open Country A/T
2003 Excursion Limited 6.0 Powerstroke Loaded!
Powerslot Cryo'd Rotors and Hawk pads.
Destinsb is offline
post #2 of 13 (permalink) Old 03-29-2007, 04:08 PM
Re: Towing with beadlocks
towing what? a jet ski sure...
this maybe a dumb question, but are they real beadlock or do they just look like beadlock...
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
super cab
18x,xxx miles.
Purchased 9-22-06
luckys420 is offline
post #3 of 13 (permalink) Old 03-29-2007, 10:42 PM
I suppose it depends if the wheels are rated for highway speeds and the weight.
I don't believe beadlocks are DOT approved, since they are a specialized off-road wheel so they are probably not built for speed. The manufacturer would have to be contacted for a definite answer.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #4 of 13 (permalink) Old 03-30-2007, 12:00 AM
they will be stamped on the back of the wheel with a load rating.... if they are Robby's or Walker's they are 3000lbs.... if they are KMC's they are 3200lbs.... I will be running KMC's on my new truck.... and towing up to 17K of 5er.....
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ Black Interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Icon Lift Kit, Icon 2.5" Piggy-Back Shocks, KMC Beadlocks w/ 33" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Line-X, MotoBar, Gentex Temp/Direction Mirror, Baja Designs 22" Onx Pro Light Bar
RRose is offline
post #5 of 13 (permalink) Old 03-30-2007, 08:14 AM Thread Starter
luckys,I was talking about towing a gooseneck,5vr, or large trailer. Real beadlocks not simulated.
Mr_Roboto, I don't believe any beadlocks are dot approved. But Im not worried about the speed rating, speeds well in excess of 100mph are common in offroad racing.
RRose, I thought Walker's were rated for 3800 lbs? So you do tow with yours? Any issues, burping, loosing air? I'm thinking about buying a set of Walker's and I tow with my truck quite a bit.
Thanks for the replies guys!
Destinsb is offline
post #6 of 13 (permalink) Old 03-30-2007, 02:34 PM
I'm almost positive that Walkers are rated at 3K..... but if they are rated at 3800..... I'll be getting those! I need a high rated wheel.
RRose is offline
post #7 of 13 (permalink) Old 03-30-2007, 04:16 PM Thread Starter
3800#. I looked again
http://www.walkerevansracing.com/beadlocks.wheels/
Destinsb is offline
post #8 of 13 (permalink) Old 03-30-2007, 10:21 PM
Willie's Avatar
What's a beadlock wheel ?? [img]/ubbthreads/images/graemlins/shrug.gif[/img] I'm not very brite. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Bob
1984 Bronco II 4x4 day to day driver : Winter
2005 Explorer Sportrac 4x4 day to day driver : Summer
1991 F350 / Crew cab , Engine 7.3,E4OD tranny. No Turbo but has propane and pyro gauge. The truck is American, complete with a Miles per Hour speedo. Digital trans. temp gauge and voltmeter. Front Captain seats. Control switches for DRL's , Fog lites, High speed idle, Engine kill and scene lites. On board " York " compressed air, Air horns and built in hose reel behind the rear seat. Power bar distribution box from a 1999 Ford Explorer . Checker plate running boards and Frieghtliner mud flaps. LED turn signals in the factory mirrors. DC to AC inverter to run the coffee maker <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> Soon to be updated with more toys as time & $$$ permit. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Willie is offline
post #9 of 13 (permalink) Old 03-30-2007, 10:25 PM
They are used for off-road use. Basically the outside tire bead is clamped on to help prevent the bead from popping off with the normally low air pressures of off road use.
They are a lot more necessary with 16.5" tires which have a steep bead angle that pops off easily. (Ask me how I know).
post #10 of 13 (permalink) Old 03-31-2007, 12:00 AM
good find destin.... I'm going to look at those and KMC's for my truck.
RRose is offline
post #11 of 13 (permalink) Old 03-31-2007, 01:02 AM
I feel you on the 16.5's popping beads. I also learned the hard way. It took hours one day to get home in the snow. If I aired up I couldnt make it down the road, if I aired down I could make it about 1/4 mile and kept blowing the bead. This was only 10 lbs. differnece-about 25 vs. 15 lbs. I will never buy 16.5's again. I have run much lower than that(as low as 3-4lbs.) without beadlocks crawling rocks on the Rubicon with 15 and 16" wheels.
2005 F250 6.0 PSD CC torqueshift,XLT,FX4,white, rubber floors, tow command,spray-in bed liner, Weathergaurd rv tool box, Weathergaurd PakRat tool box, Michelen HD floor mats, Rack-it lumber rack, Fumoto valve, XM, Pop-Up G/N hitch, 62,000 miles already!
1994 KDX 250
2001 TTR 225
2003 Honda Recon
1999 PW 50
1988 KD 80X
jwoops69 is offline
post #12 of 13 (permalink) Old 03-31-2007, 10:29 AM Thread Starter
No prob RRose. I really likethe walkers, but I'm still not sure about towing.
Destinsb is offline
post #13 of 13 (permalink) Old 03-31-2007, 01:23 PM
I can't really say..... my last truck had the robby gordon wheels with simulated beadlocks..... I have a ford ranger that has 15K on beadlocks and I've never had an issue..... but I don't tow with it.
RRose is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
