Towing capacity of 01 7.3 F250 - Diesel Forum - TheDieselStop.com
Old 11-15-2007, 07:51 PM   #1 (permalink)
I have a 01 7.3 F250 auto trans stock 75k miles. I have been asked to help a friend haul a peice of equipment that weighs about 7k not including the trailer. They need it hauled over the mountains. The truck has a stock hitch but I am unsure of what the capacities are.
I regulary tow a 6k travel trailer but one time fully loaded with water, fuel, and 4 peoples gear I overheated the tranny and it released tranny fluid. This issue was completely my fault I was pushing the truck to hard on real rough slow and steap 4X4 terrain for a couple of hrs.
I don't want to over do it again. So I want to know what my max towing capabilities are off the bumper. Thanks for any help
Ncotton is offline   Reply With Quote
Old 11-16-2007, 09:56 AM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Re: Towing capacity of 01 7.3 F250
Depending on the weight of the empty trailer, it sounds like you'll probably max out the weight capacity of your F-250 and it's receiver hitch.
Towing 10,000 pounds or more is serious business, especially over mountains, so don't try to get by without the right equipment.
It's posssible your loaded trailer will gross less than 10,000 pounds if it's a light-weight trailer with tandam 5000-pound or 6,000 pound axles and not more than 20' long. You need to know the empty weight of the trailer.
Crawl under the rear of the tow vehicle and find the embossed area with the weight capacities stamped into the frame of the receiver. The big number will probably be 1,000/10,000 WD. That means your max receiver capacity is 1,000 pounds hitch weight and 10,000 pounds gross trailer weight provided you have a weight distributing hitch.
So rule 1 is do not try to tow 10,000 pounds unless you have a weight-distributing hitch.
If your empty trailer grosses more than 3,000 pounds, and if your receiver is rated 10,000 pounds WD, then you don't have enough receiver for the job. So replace your receiver with a Reese or Drawtite Tow Beast class V receiver, which has a WD capacity of 14,000 pounds and costs about $300. Click here then scroll down to the Tow Beast.
If you don't already have a weight-distributing hitch for that trailer, then you can get one from any RV or trailer hitch store - even from a U-Haul store. Be sure you get one for a hitch weight of at least 1,000 pounds. Click here for one on-line source. Note that the "shank" is probably separate, but you have to have one that matches the rest of the hitch and receiver. The shank is the part that fits into the receiver.
So with the proper receiver and weight-distributing hitch to tow a 10,000-to-12,000-pound trailer, your next concern is the tranny.
You shouldn't have any tranny overheating problem towing a 10,000 pound trailer over the mountains provided you can keep the speed up over 40 MPH. But if there's any chance the road is too crooked or slow for you to maintain over 40 MPH, then I wouldn't try it without an aftermarket tranny temp gauge. Put the sender in the pressure port on the side of the tranny, and don't allow more than about 225º or 230º tranny temp. If the tranny temp exceeds 225º for more than a minute or so, then pull over and stop, put the tranny in park or neutral, and elevate the idle RPM to 1,200 or so until the tranny temp gauge shows 210º or less.
If you add a tranny temp gauge, then you want one with clear markings around the red line of 225º. I like the ISSPRO Enhanced Visibility gauge. Click here.
Then I hope you replaced all the tranny fluid shortly thereafter. If not, then do it before you try to tow 10,000 pounds over the mountains. Buy 20 quarts of MERCON or MERCON V ATF, and follow the procedures in the '99-up FAQ to replace virtually all the ATF. Click here for those procedures.
SmokeyWren is offline   Reply With Quote
Old 11-16-2007, 11:11 AM   #3 (permalink)
Thank you, that is a great reply. They don't have the trailer lined up yet but at least now I know what to look for and feel a little more comfortable. I did replace all my tranny fluid and filter after I overheated it.
Old 11-20-2007, 11:13 PM   #4 (permalink)
I've never towed with a weight distributing hitch with the factory ford hitch and have had no issues. The factory hitch is only good for 5K lbs without a dist. hitch and 10K lbs with.
Most of the tows I make are on flat land, on mountains I'd take the guru's advice!
Just an FYI the factory hitch is better than what the sticker says. Towed many loads in excess of 20K lbs but it's white knuckle driving even with the DRW. Never went past 65 mph with those loads. The motor can do it it's the auto tranny that will suffer.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited triple pod
00 BMW 328CI 2dr silver fully loaded
65 Mustang 289 V8 4brl
69 GTO 400 4spd
04, 09, 12 PJ 15k dump trailers 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline   Reply With Quote
Old 11-21-2007, 07:38 PM   #5 (permalink)
"the mountains" covers a lot of territory. I wouldn't be hauling your rig over a lot of places in Washington and Oregon.
Just my wussy 2 cents...
Florida Ed
2011 Suzuki Burgman 650cc Rice Rocket Scooter 49 MPG, 120+ MPH, & 2009 Honda Shadow 750cc 51 MPG, 100+ MPH
2001 7.3 F-350 Dually Lariat CC LWB 4X2 Dark Green 4.10 4R100 5'ver Hauler (32' Montana 2 slides 10,500# - 2,000# tongue weight), 106 gal aux tank, 159K miles, nephews arguing over who will inherit it 'cause I'm gonna' drive it 'til I die. Bone stock.
2001 5.4 Gasser F-250 XLT Crewcab SWB 4X2 3.73 4R100 98K miles headed to 150K stock as the day it was made
Before these: '00 F-250 CC PSD, '97 F-250 CC PSD, '94 Ford F-150, '91 Ford E-250, '81 Ford E-150, '66 Ford F-100 (cars not included)
FloridaEd is offline   Reply With Quote
Old 12-03-2007, 11:36 PM   #6 (permalink)
bigfords's Avatar
whats the gcvwr of a 99.5 f 250 srw?
99.5 F250 Supercab, shortbed
S&B Intake, 4" straight pipe, DP Tunes: 60 tow, 80 economy, 140 smoke, CCV mod from ITP, 203* stat, AIH mod, foil delete, ISSPRO boost and tranny guages with Banks 6 gun for my EGTs,(don't use it but for the guage) Lund Genesis trifold, 7 clearance lights, 285 BFGs, AMSOIL
"Because HE Lives"
bigfords is offline   Reply With Quote
Old 12-04-2007, 09:10 AM   #7 (permalink)
SmokeyWren's Avatar
My Photos: (44)
GCWR = 20,000 pounds = max combined weight of wet and loaded trailer and tow vehicle when sitting on a CAT scale
GVWR = 8,800 pounds = max total weight on the axles of the tow vehicle, including hitch or pin weight, when sitting on a CAT scale.
No such thing as gcvwr unless you mean GCWR.
CAT = Certified Automated Truck
Old 12-12-2007, 11:55 AM   #8 (permalink)
Parts Jimmy's Avatar
I believe you will probably need a Class V hitch unless you plan on a weight distribution setup for your trailer. A trailer to haul 7k will probably weigh at least 2500-3000k.
2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Donaldson M085171 Muffler,
Transgo Equipped 4R100, Autometer Guages,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer,
Timbren Overloads, Code L Front Springs,
Bilstein Shocks, BFG Commercial TA Rubber,
Hella 700FF Driving Lights, C-Betr Mirrors
2004 Mustang GT
Parts Jimmy is offline   Reply With Quote
Old 01-27-2008, 10:31 PM   #9 (permalink)
bigfords's Avatar
smokey wren,
so if my truck's dry weight is 7,000 lbs, I can only put 1800 lbs in the back of my truck? if so, that is pathetic. thanks much.
"Because HE Lives"
Old 01-27-2008, 11:01 PM   #10 (permalink)
MrJimi's Avatar
My Photos: (9)
Originally Posted by richiewh3 View Post
smokey wren,
And thats over 3/4 of a ton
don't forget to add for fluids, tools and passengers, like it says. DRY WEIGHT
F-550 pickup
MrJimi is offline   Reply With Quote
Old 01-29-2008, 05:20 PM   #11 (permalink)
i haul a full bed of gravel with mine all the time, long distances too, but i have TREMBLENS, they work great.
2002 f350 crew cab short box 3inch tuff country level kit 315 toyo mudd terrains on 8 inch nitto rims afe stage11 intake with pre filter window tint leer canopy auto meter quages . 4 inch mbrp exhaust. superchips 1805 tuner. towinn our 2004 27 ts komfort tt.
http://community.webshots.com/user/rws444psd
rws444psd is offline   Reply With Quote
Old 08-10-2011, 06:05 PM   #12 (permalink)
I have a scale at work and weighed my 96' F350 CC 7.3L Diesel, with my 8' camper and trailer hooked up to the trailer, I'm 9960 on 4 wheels thats with 1/2 tank of gas and no one inside, and I'm 16840 when I get on with the trailer. So I am over weight GVWR when I fill up and put 4 guys in there, and under weight on the GCWR.
I see people all the time pulling 12' Campers and towing something also, how can you be legal then? What would be required to make it possible for me to tow correctly?
I haven't had a problem towing at all, so it also makes me wander what are the true numbers really are.
Thanks!
Kronlundace is offline   Reply With Quote
Old 08-10-2011, 10:19 PM   #13 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Originally Posted by Kronlundace View Post
... I'm 9960 on 4 wheels thats with 1/2 tank of gas and no one inside... What would be required to make it possible for me to tow correctly?
Your problem is not enough GVWR with your current truck. It has a GVWR of 9,200 pounds. You need a truck with minimum of about 11,500 GVWR for your load. Even a '96 F-350 DRW has a GVWR of only 10,000 pounds. So you need a newer truck with more GVWR.
A '99-'04 F-350 SRW diesel has a GVWR of 9,900. Not enough.
An '05-up F-350 SRW diesel CrewCab 4x4 has a GVWR of 11,500. A '99-'04 F-350 DRW also has a GVWR of 11,500. That's the minimum you need. If you insist on single rear wheels, then look for an '05-up F-350 SRW. If you want to stick with the tried and true 7.3L Powerstroke engine and can "make do" with a dually, then you should look for a '99-'03.25 F-350 DRW with the 7.3L engine.
An '05-up F-350 DRW would give you some wiggle room and fudge factor. An '08-up F-450 pickup would be overkill with that camper and trailer, but would give you the option later to enlarge either the camper or the trailer or both without being overloaded.
Old 08-11-2011, 12:02 AM   #14 (permalink)
Thanks SmokeyWren, overall just need a truck that handle that.
Old 09-15-2011, 05:24 AM   #15 (permalink)
He needs to go buy a new F150 Eco or 6.2L. Then he can tow more then his diesel
I have a 2010 F150 4.6L 3v and I tow 8500lbs once a week. To be honest it tows as good as my 1997 Fsuperduty (f450)
Deepwater is offline   Reply With Quote
