Old 02-21-2007, 04:32 PM   #1 (permalink)
Towing in the High Performance Superchips program
Can I tow in the high performance mode? I have a boat that overall weight is around 7200lbs. Is it safe?
2002 crew cab 4X4 PSD, DIY Tymar, Walker BTM, AIH delete, superchips.
1997 Chris Craft 26 Crowne cabin cruiser.
racegun is offline
Old 02-21-2007, 05:48 PM   #2 (permalink)
Re: Towing in the High Performance Superchips program
I have the older Superchips (60 & 80 hp) tuner in my truck. If you dont have gauges DO NOT TOW WITH THE SUPERCHIPS IN "OFF ROAD" MODE. I towed with mine in the 80 hp mode before I got gauges and I ended up replacing my turbo shortly thereafter. After I bought my gauges I found out why. In the performance mode you can hit 1300 degrees real fast pulling an empty trailer (24 foot gooseneck stock trailer) Loaded...it just gets worse.
I know that there are different computer codes that the Superchips tuners work better with...maybe I just have the wrong code. If not, you can learn from my $1000 mistake.
If you have gauges, you might get by with it if you watch your egts and get ready to back out of the throttle when needed. Generally if I am pulling something heavy, I just go back to stock to be safe.
Good luck,
Jay
99 XLT,PSD,CC,SB, 4x4, Manual T-case and hubs, auto trans, 3:73 Limited slip, 235/85/16E Yokahama Geollander AT/S, Straight piped, Amsoil and Dodge LS Additive in the rear, Diamond B Brush Guard, BIG Lightforce lights, AFE MAgnum intake/Pro guard 7 filter, Sony deck, Isspro Gauges on A-piller, Rancho RS 9000's on Back, Monroe reflex on front, SCMT 60 or 80hp, 203 T-Stat, Billit Housing
IF YOU HAVE EATEN TODAY, THANK A FARMER!!
Jay Brunson is offline
Old 02-21-2007, 07:17 PM   #3 (permalink)
Good luck,
Jay
I would hope he allready has gauges towing with a programmer.
O5 F-250 SuperDuty CC SWR 4x4 Lariat
8' box 6.0 PSD Tow Comand new 04/05
2001 40' Alfa Toyhouse
Pulls better stock than my 01 with a programmer
New engine at 42k . Hope my luck with this 6.0 is changed .
firesoutmatt is offline
Old 02-21-2007, 07:41 PM   #4 (permalink)
I would not reccomend towing that heavy in any tune other than tow-safe. If you have an auto, the tranny can barely handle that tune unloaded, much less with 7200 pounds behind it. Also, why do you need that much power when you are towing and your truck has just became a 15,000 lb. missle?
99.5 F-350 4X4 reg. cab flatbed dually 6spd., Tunes by MCN diesel, Wicked Wheel, dieselsite brv, HX mod, LUK clutch upgrade, Dipricol pyro,boost,fuel. Tymar intake, CCV mod.
2000 F-250 crew cab auto 4X4. Traded on 5-8-07 because of crappy trans for:
2007 Dodge 5.9 cummins 4x4 6-spd. CC dually
1987 F-250 6.9 IDI, Old Smokey
phale is offline
Old 02-22-2007, 01:19 PM   #5 (permalink)
I have gauges on order. I would never tow in that mode, but I have heard other people do it. I have only towed the boat once and I used the tow safe mode.
Thanks for the replies.
racegun is offline
Old 02-22-2007, 02:38 PM   #6 (permalink)
When I had the Superchips I once forgot to change the program from hot to tow,, EGT's climbed very quickly and was a PIA to drive. I pulled over and re-programmed,, much better. I have since gone to a 4 position chip from DP tuner. It made a HUGE!!!!! difference in towing low egts and great power.
Brian
2000 PSD Lariat 4x4 SC,, 111k miles, AFE pg7 stage II w/outerwear, ATS turbo housing, Wicked Wheel, gutted EBV, Banks BHA, 4" turbo back exhaust Aeroturbine , A-pillar gauges, Swepco in the tranny, BD torque lock, FTVB, 203* T-stat & billet housing, DP Tuner Tuning (4 pos; stock, econo, tow, perf), AIH plug, Powerslot Rotors & Hawk pads, Ride Rite air bags, PML rear diff cover, Filters: Dahl fuel, Dieselsite tranny & coolant, Amsoil dual remote oil. Rancho 9000's w/in cab controller(that needs install) on board air & horns,, done!!
I believe in Santa!! He drives a Big Brown Truck and wears a Brown shirt and hat!!!
All this to tow the 33' toy hauler loaded with fun!!!
dunesday is offline
Old 02-22-2007, 04:15 PM   #7 (permalink)
Blue Water Runner's Avatar
I use the 90hp program and I have had no EGT issues. I probably could go to the 110hp program but I don't like the way the transmission shifts using that program. It feels like the engine is going to tear the transmission apart using the 110. I rarely exceed 1100 degrees towing with the 90hp program.
2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Straight Pipe,
SCT X3 w/DP-Tuner 60T-80T-80E ,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer
My Pictures
Blue Water Runner is offline
Old 02-22-2007, 04:28 PM   #8 (permalink)
I have towed in my 100 setting with the sniper programmer I had. But you NEED TO HAVE GAUGES. As long as you keep it under 1250 you will be fine.
Andrew
Ford F550 Crew Cab 4x4 with Fontaine Bed and Air
00PSD1 is offline
Old 02-24-2007, 10:22 PM   #9 (permalink)
Supporting Member
detroitfd's Avatar
Programmer = gauges. Period.
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ serviceable S&B filter - Zoodad mod - B&M HD Trans rebuild w/ TransGo Shift kit & Amsoil Fluid- BD Triple Disc Billet Torque Converter - Exhaust : 4" Turbo Back (w/ 4" down pipe) Stainless Steel Magnaflow - ATS housing and 4" intake sleeve - Turbo Master Wastegate Controller - Dieselsite HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
Old 02-24-2007, 10:37 PM   #10 (permalink)
Blueridgerunner, do you have that post turbo or pre turbo. Those temps sound a little low. I can hit 1200 stock pulling a decent load.
Early 99 Ford F-350 4X4 Extended Cab Dually, 4 in lift, 6spd, dual 5in stacks,ts 6 stage, zoodad, ccv, tymar,
240,000 miles and counting
1993 Ford F-350, 4X4, Fuel Injected 460, MUD TRUCK, 40in super swampers, Dana 60 Front, Dana 70 Rear, 10in home made lift.
1982 Mustang 302 HO
HOURS TO BUILD, SECONDS TO BREAK
mflores is offline
Old 02-25-2007, 08:45 AM   #11 (permalink)
I've never hit 1200* pulling anything stock. With the superchips 1705, I've never hit 1200* in Tow Safe or in Tow-Perf (but I watch it close pulling the big hills). I've never towed using the Performace tune. My pyro is in the drivers manifold. Some trucks just seem to run hotter or cooler than others.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
Old 02-26-2007, 12:47 PM   #12 (permalink)
Early 99 6 speed. In the 90Hp Tow Performance mode I don't have any EGT problems. Only got to 1250* one time on a long steep grade pulling our 34' Keystone Cougar fifth wheel at a weight of about 12,500#. I have a Tymar Intake and straight exhaust. Pyrometer is in the drivers side up pipe.
Chris
Early 99 (3/98) Extended Cab F 250 XLT 4X2, PSD, 6 Speed, LWB, SRW. 140,000 miles. LUK Clutch, C-BETR Tow Mirrors, Muffler Delete Pipe, Removed Catalytic Converter, Autometer Dual A Pillar Guages with pre-turbo Pyro and Boost, SCMT 1705 Max Tuner, Tymar Intake from Airflo.com. 265/75/16 Firestone Transforce A/T's. Fumoto Drain Valve.
2006 Volkswagen Jetta TDI (wifes car)
2004 Keystone Cougar 314EFS
2004 Kubota M4800 W/Bushog Loader
1969 Mustang Mach 1 351W
1990 Jeep Wrangler
firefighter9208 is offline
Old 02-26-2007, 11:49 PM   #13 (permalink)
i tow FREAKIN MASSIVE all the time with my 1700 in the hot setting. it was not doable till i did afe stage 2 and 4" turbo back. but now even towing 30k it is very maneagable. now i could go WAY over 1200 if i wanted but dont need to. then running with that weight at about 65 it stays steady at 1100. keep in mind flat lands down here. afe stage 2 brought it down 50-100 degrees or so and 4" brought it down prolly around 250 degrees. it used to get up there quick. now very maneabeable. i usually tow about 20k a few times a week. no probs so far. drive by the gauges.
sgrem is offline
Old 03-03-2007, 11:44 AM   #14 (permalink)
Cool_Canuck's Avatar
My Photos: (12)
The scmt is pretty good at doing what it advertises. IIRC, 7,000 lbs is the cutoff point between the tow settings. Gauges are good insurance but not totaly necessary if you stay with in scmt parameters.
I run in "Tow Perf" all the time, however, I have gauges. You can get to 1,200 empty in any of the settings.
Here is most of what you need to know on getting your 7.3L started and how to operate it in the cold winter months. These posts use to readily available, but they've been hid in a subforum top of the 7.3 Power Stroke Engine and Drivetrain forum.
Winter Operation (How I Do It)
Hard/No Start? Check here first
2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Cool_Canuck is offline
» Network Links
