Re: Towing regs "Smokey"
As long as your tow vehicle does not have Company signs you will be safe, According to US DOT regs any vehicle that can gross over 10,001 lbs to further company business or hauling for hire is subject to DOT regs.(US DOT covers interstate transportation not intrastate transportation, tho most states have adopted the US DOT regs with some exceptions- E.G. in Tx you arent regulated until you gross over 26,001 lbs, unless you travel interstate or its HAZMAT.) So if its just your personal stuff on a personal move, no probs. You can double check with each state you will be driving through, if was me I wouldn't worry about it. One thing though DOT wants the containers chained down at each end, and 2 straps going across the top last I read. Agriculture has their own set of exemptions, I believe its if you gross over 56,000lbs--- not sure onthat but the weight limit is up there.
interstate- meaning you cross state lines
intrastate-- meaning you travel your home state only
Oh yea, the doors can be padlocked, but IF for some reason a task force unit pulls you over and wants to see inside be prepared to open it. Not very likely but ya never know these days.
