Old 05-28-2008, 05:39 PM   #1 (permalink)
calfroper1's Avatar
trailer brake problems
I bought a used trailer with elec. over hydraulic brakes. They work good when you apply the brake but then they dont relase all the way,it takes about a minute for them to release. I checked to see if when I let off brake pedal the brake actuator quites running and it does. So I pulled the hubs and all the brake return springs are in place everthing is moving freely. Does anyone have any ideas.
Jim
2008 F-350 XLT, 4x4 crewcab.shortbox,swd.black with chrome pack.6 speed manual,3.73 gears.
http://photos.thedieselstop.com/showgall...=1&ppuser=45952
calfroper1 is offline
Old 05-28-2008, 07:28 PM   #2 (permalink)
fulltimer50's Avatar
My Photos: (13)
A factory brake controler( if you have it) doesnt work correctly with most electric over hydrolic systems. What kind of controller and what trailer brake/axle system do you have?
George
99(9-98)F250XLT/SC/LB/4x2/3.73LS/A-Pillar mounted Tranny tempgauge,PreturboPyro,Boost gauge/JNB BypassReg/ Ford AIS/ Airlifts/Rancho 9000s/PFP mod/HD Heater shutoff/DS Predator Tuner/HX/Spin-on tranny filter/203*TS/Ford Gold Coolant/Coolant filter/Jimmyjammers/Cyclops antistart/Oilguard/MBRP 4"turbobackSSexhaust/Suncoast Extreme tranny/BD exhaust brake/08 Diff Cover/Ford02-04 Headlights/Wrangler 265x75x16 ProGrade.
06 Newmar Cypress 29KSRE 5th wheel/MorRyde IS,Kodiac Disc Brakes.
fulltimer50 is offline
Old 05-28-2008, 08:15 PM   #3 (permalink)
calfroper1's Avatar
It does not have factory ford controller in it. The controller is a P-3
Old 05-28-2008, 08:21 PM   #4 (permalink)
My Photos: (13)
As you may know the pressure has to bleed off before the brakes can release. I would look at the acuator, though I know nothing about them.
George
Old 05-30-2008, 10:49 AM   #5 (permalink)
Hensley Ron's Avatar
If you know the brand of actuator, I've got a few contacts in the industry. E/H brakes are nice, but when they go down, they go down hard. E-mail me at ron@hensleymfg.com and I'll get you a number to call.
Ron Estrada
Hensley Mfg., Inc.
Home of the Hensley Arrow and TrailerSaver
800-410-6580
Hensley Ron is offline
Old 05-30-2008, 12:06 PM   #6 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Why are there all the electric over hyd systems out there? Personally I have them because of the initial surge before the brakes begin helping.
Am I crazy for being a fan of strict electric? I guess I wouldn't mind air, but that never comes on a pick-up.
MarkEkberg is offline
Old 05-30-2008, 12:19 PM   #7 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Sorry I vented a little. I forgot to mention that there could be blockage in the wheel cyl's, or in any of the lines from the front actuator.
A real good bleed might help you out?
Old 06-01-2008, 10:55 AM   #8 (permalink)
The little bit I've dealt with them, I'd guess one of 2 things - either the actuater is sticking and not returning fast enough (what brand do you have?) or your wheel cylinders are seizing up and not popping back in the way they're supposed to. I had that happen on a Toyota pickup, not a trailer, but I guess it could happen with it, too. Where did the trailer come from? If it's been in the salt, I'd guess cylinders, or if it's humidity I'd worry about the actuater.
Copper is offline
Old 06-06-2008, 09:03 PM   #9 (permalink)
calfroper1's Avatar
It is a Ausco brake actuator which are no longer in buisness. I have had the drums off and everthing looks really good. So I think I am going to buy a new actuator does anyone have prefernces. I am looking at the dexter or the carlise.
Old 06-07-2008, 07:46 AM   #10 (permalink)
My Photos: (13)
E/H systems are what works when the axle has disk brakes.
From what I have read, most of the problems with brake delay comes from a brake controler that is not compatable with the accuator.
George
Old 06-08-2008, 12:43 AM   #11 (permalink)
calfroper1's Avatar
This is what I thought the problem was,so I called the manufacture of brake controller. They had me check to make sure the actuator quit running when I let off of the brakes. Which it did so that says that the controller is working properly. So that leds me back to the actuator.
Jim
