Trailer Brakes - Diesel Forum - TheDieselStop.com
Old 10-02-2009, 09:14 AM   #1 (permalink)
jetsonic's Avatar
Trailer Brakes
Gentlemen,
Wondering if you could advise me on you're opinions on what is the best trailer brake controler available and is compatible with my vehicle?
I pull a 18' car hauler with my 02 F-250 7.3.
The trailer has brakes on all 4 wheels...
Thanks alot...
jetsonic is offline
Old 10-02-2009, 12:22 PM   #2 (permalink)
LTFFNREMTP's Avatar
Tekonsha Prodigy if you are willing to pay that much for it. Second on my list would probably be the Tekonsha Voyager. Both are a quick hook up to your Ford with the appropriate wiring harness to plug in under the dash.
'99 F250 CC-SB 4x4, AFE Stage 2 intake with Pro-Guard 7, Dieselsite coolant filter, DiPricol Full gauges, AIC, On board air + Buell emergency series air horns, Striker turbo timer, Striker I module, Cyclops anti-theft module, TC lockup and 6.0 trans cooler. Powerslot Cryro'd rotors and Hawk LTS pads.
LTFFNREMTP is offline
Old 10-02-2009, 12:29 PM   #3 (permalink)
chuckster57's Avatar
X2 on the prodigy. Plug and play..I take it out of the truck if I am not going to haul for a while and when I put it back in I just hit the boost button to level 2 and it's done. It finds it's own "level" so you don't have to mount it and adjust a pendulum.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 10-02-2009, 01:07 PM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Asssuming your trailer has ordinary electric brakes, then several different brands of electric brake controllers are available. Mine is a 10-year-old Drawtite Activator II, and it works fine on both my 25' fifthwheel RV trailer and my 7x14' tag enclosed trailer you see in the photo below.
A quick look shows that Drawtite still sells the Activator II:
Draw-Tite Hitches & Accessories - Brake Controllers
If your trailer has hydraulic disk brakes along with a high-priced electric over hydraulic brake system, then you need a more expensive controller. Hensley makes a couple that will control electric over hydraulic brakes:
TruControl Gold Electric Trailer Brake Controller by Hensley Mfg. Inc.
SmokeyWren is offline
Old 10-02-2009, 06:07 PM   #5 (permalink)
Actually you do have to set the level initially. I justed installed 2 Prodigys last week.
the directions are here. http://www.tekonsha.com/product/pdf/N90195.pdf
Adjusting the Power to the Trailer
Brakes
(Prior to setting Boost)
Once the control has been securely mounted, it is
necessary to set the power needed to stop the trailer
during a braking event.
1. Connect trailer to tow vehicle.
2. With engine running set power (with Power
Buttons) to indicate 6.0
3. Drive tow vehicle and trailer on a dry level paved
surface at 25 mph and fully apply Manual Knob.
If trailer brakes lock up:
Turn power down using Power Buttons.
If braking was not sufficient:
Turn power up using Power Buttons.
4. Repeat Step (3) until power has been set to a point
just below wheel lock up or at a sufficient force as
to achieve maximum braking power.
5. Using the brake pedal, make a few low speed
stops to check the power setting. Trailer braking is
initiated and terminated via the stoplight switch.
When the brake pedal is released, trailer braking
will cease.
The prodigy will also control hydraulic over electric.
It is a much better controller than the "manual" one it replaced
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 10-02-2009, 08:53 PM   #6 (permalink)
OT
OT's Avatar
Voyager I used did have a level adj. & really touchy. Prodigy I just installed has auto. leveling, but it need's to be mounted correctly (not lop sided) Prodigy not exactly same as P3. Anyhow, glad I finally upgraded. Boost feature is nice touch. ETrailer had a sale on um. Good luck!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 10-02-2009, 10:52 PM   #7 (permalink)
MaxBrake Go ahead and get one of these and be through with it. Since getting this controller I have an old Prodigy and a Voyager just gathering dust. Best money I have spent on this issue. Can't imagine bothering with anything else.
GOD BLESS OUR TROOPS!! - GOD BLESS AMERICA!!
Rick M is online now
Old 10-03-2009, 10:33 AM   #8 (permalink)
Two of the trucks have Voyagers one has the Prodigy. The Voyager has been in the F250 for about 7 years and it's been very reliable. The Excursion has had the Voyager for about 4 years but it rarely tows.
At first I didn't like the Prodigy in the dually but the more I played with it the more I liked it. At first it didn't seem to have the stopping power of the Voyager but I soon found out it's got plenty of stopping power. I was leaving a site with a huge load (28,600 total lbs) and an old timer pulled out in front of me. I had one option slam on the brakes and to my amazement the four trailer tires locked up and stopped very quickly. With the Voyager may not have been able to stop in time unless of course I had the brakes cranked up all the way.
The Prodigy was bought off Ebay for under $100 shipped.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited triple pod
00 BMW 328CI 2dr silver fully loaded
65 Mustang 289 V8 4brl
69 GTO 400 4spd
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 10-03-2009, 12:24 PM   #9 (permalink)
I installed 2 P3's not prodigys. Getting confused. CRS settting in!!!
TXANGLER is offline
Old 10-03-2009, 04:59 PM   #10 (permalink)
olddieseldude's Avatar
My Photos: (16)
I've had very good luck with my Prodigy. Had it for a few years now. I think one testament to it is that I don't tow very often, when I do the loads can vary considerably in weight, and it is very easy to set up, consistent, and most of all predictable.
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline
Old 10-04-2009, 06:57 AM   #11 (permalink)
Here are my comments on Brake controllers:
BrakeControllerSelection
Here are links to brake mfgs and online stores for price shopping:
Collection of links related to RVing
Bruce & Carolyn Wittmeier
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, DP-Tuner 40/80/120HP, Chrome Step, Line-X bedliner, Jordan Ultima 2020, AirLift 5000 Airbags, DiPricol gauges
wittmeba is offline
Old 10-04-2009, 09:52 PM   #12 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Hey Bruce -
Good job. That puppy required some blood, sweat, and tears.
If you start a new thread with that link in it, I'll make it a sticky. Then you can maintain it.
Old 10-05-2009, 05:36 PM   #13 (permalink)
Thanks, Smokey. Yes it is an accumulation from several years, but always a hot topic.
I guess now Ill have to keep it current
wittmeba is offline
Old 10-05-2009, 08:24 PM   #14 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Okay, it's a sticky now. I left it open so folks can fuss at you.
