Old 03-19-2006, 11:25 PM   #1 (permalink)
trailer lights wont work, 4 pin harness gone...
well when i bought this truck someone must have cut the 4 pin harness off and just taped up the wires. i had assumed the 7 pin would still work, but it doesnt. none of the trailer lights work. is there something i need to rewire etc to get these to work? oh its a 03 6.0, thanks.
2003 6.0 Ext cab FX4 loaded XLT
March 03 build with 39,000 trouble free miles (so far)
4" turbo back SS MBRP, RSX3.5 alarm
8" Superlift with Bilsteins
37" Nitto Mud Grapplers on 17x10 Mazzi Hulk rims
weraracer is offline
Old 03-20-2006, 07:58 AM   #2 (permalink)
My Photos: (13)
Re: trailer lights wont work, 4 pin harness gone...
Have you checked fuses?
2003 F-350 Crew Cab, V10, 4X4 ESOF, 4 Speed Auto, Long Box, 3.73 Regular Axle, heavy duty front suspension with W code springs, SRW, Lariat options package- Leather seating for six, cruise, heated seats, single disc player, Chrome tubular cab steps, keyless entry, full power. Newly added- Prodigy brake controller.
And TTT mirrors with heat and turn singal.
Also- Wireless keypad, Century Royal Series Truck Topper and Putnam Class V Trailer Hitch.Truck Photos
Recently turned 32,000 miles.
Pulling a 18' flatbed with 3 ATVs.
Berol is offline
Old 03-20-2006, 09:09 AM   #3 (permalink)
well not yet, it was late last night and i assumed that the 4 pin hack job would have been the cause. i will get a closer look today. thanks.
Old 03-20-2006, 03:16 PM   #4 (permalink)
My Photos: (17)
Are the wires that are taped up shorting out each other?
West Deptford, Gloucester County, Southern New Jersey
2002 Black Excursion XLT 6.8L V10 ( Pics) - Timbrens, 2WD Lift Gate Struts, PIE adapter, Cell Phone Harness.
2002 Ford Explorer - Wifey's ride.
1999 Sunline T24 Saturn 25' TT (Pics) - Every option avail at the time.
obonaventure is offline
Old 03-20-2006, 08:54 PM   #5 (permalink)
If the 7 pin plug wasn't used by the previous owner, it may need the relay added to the fuse panel under the hood. When I ordered my truck with the towing package, the 7 pin adaptor came in a bag with the light relays in the glove box. Still there, as I haven't had to use the 7 pin plug yet.
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2003 VW Jetta TDI auto, 90k miles, all stock, no mods, 41 mpg most days. A rocket in disguise...
Repairs: alternator, brake switch (x2), power window wire harness, #4 glow plug, glow plug wire harness -TRADED as of 11/24/2008
Newest purchase - 2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available yet)
short_stuff is online now
Old 03-20-2006, 09:36 PM   #6 (permalink)
i would say it was used since he had a 5th wheel in the bed. i checked the fuses and they look fine. i need to pick up a test light and see if there is any power at the plug.
Old 03-20-2006, 11:14 PM   #7 (permalink)
i amnot getting any power to any wires in the back. the fuses look good, relays are there. any idea what to check next??
Old 03-21-2006, 09:56 AM   #8 (permalink)
If the previous owner had a fiver hookup then he may have had a in bed connector for his trailer. It's pretty common for folks with fifth wheels or goose neck trailers to do that to keep the trailer wiring from draping over the tail gate. Is there a connector in the bed of the truck? If so he probably cut the wires going to the connector at the bumper instead of splicing into them.
03 F250 SD PSD Lariat 7.3, FX4 Crew Cab Short Box, 3.73 Gears, Auto Tranny, Jody Tipton 80 HP Econo Tune, Turbo Back 4" Exhaust W/5" Tip, Home Made Tymar, Isspro Gauges, T/C Lock Up Switch, 203 Degree Thermostat, Coolant Filter, Upgraded Headlight Wiring Harness, Diode Mod for Dims, Bilstein Shocks, Kenwood Head Unit, Sirius Radio, Valentine 1
Down South is offline
Old 03-21-2006, 10:42 AM   #9 (permalink)
hmmm, i have had the truck for 1 year now, and there isnt a plug in the bed, but there may have been at some point. would he have possible cut the wires further up in the system? the 4 point harness at the rear was certainly cut off (like someone needed one and took it) but the wires were not grounding out and were just blunt ends). i guess i will need to trace the wires back to the cab and see if they have been cut. thanks for the reply. if there are any other ideas, please post, thanks.
Old 03-22-2006, 09:49 PM   #10 (permalink)
alright so i played with the wires tonight. they arent cut anywhere that i can see up along the frame. the power comes sometimes and they work fine, then other times, most of the time, there is nothing. i jingle the wires around and nothing changes. i have NO IDEA what the problem is - maybe a bad ground???
i have an ABS sensor out in the rear, is that tied in somehow??
