Trailer Running Lights won't work - Diesel Forum - TheDieselStop.com
Old 07-12-2006, 02:23 PM   #1 (permalink)
I have a 2000 Super Duty with factory trailer tow package. Trailer running lights won't work. With trucks lights on, I have full voltage at pigtail, but as soon as I plug trailer lights in voltage drops to zero. Same thing happens when I try 3 different trailers and all 4 trailers light properly with other vehicles towing them. Has anyone had this problem, or know what to look at next?
davidfife is offline   Reply With Quote Quick reply to this message
Old 07-12-2006, 02:35 PM   #2 (permalink)
Conner's Avatar
Re: Trailer Running Lights won't work
Check to see if the pigtail wires match up with the wires on the trailer
1999.5 F350 7.3L 6 speed ext. cab 4x4 flatbed. magnaflow 4in exaust. php chip stock, lope 65 tow 80 eco 100 140hp with insight monitor. Snow performance stage 3 water/meth, ats ported compressor housing. wicked wheel, ccv mod, diy tymar air filter. southbend clutch and flywheel.
dyno on 10-23-2010 at 357 hp and 800 tq at the wheels.
1986 F-250 H/D 6.9l non-turbo, 4x4, 4 speed manual, 3.55 ratio, 4 in. exaust to 5 in tip. no soup bowl,homemade front bumper, flatbed, JVC cd player, Galaxy DX919 cb with Wilson 2000 antenna and 900 watt Texas Star Linear. IF IT DONT BLOW SMOKE IT AINT RUNNING
I WORK FOR CUMMINS AND DRIVE A POWERSTROKE!
Conner is offline   Reply With Quote Quick reply to this message
Old 07-12-2006, 02:36 PM   #3 (permalink)
They do. I have checked them multiple times. The running lights worked on all trailers previous to the problem beginning.
Old 07-12-2006, 02:43 PM   #4 (permalink)
Conner's Avatar
Check your ground on the trailer. We had a problem like that some time ago but the lights would work one minute then they wouldnt, then sometimes the marker lights would work with the brake lights. The other vehicles may be grounding the trailer through the truck. But the most common problem with lights on a trailer not working is in the ground wire coming from the trailer plug.
Old 07-12-2006, 02:51 PM   #5 (permalink)
I have the same problem happening on every trailer. I have a good ground (not using just the ball). Turn signals, aux power, etc always work correctly. Just not the running lights.
Old 07-12-2006, 02:58 PM   #6 (permalink)
Conner's Avatar
It sound to me like you have a grounding problem. On ours everything worked like it should but the marker lights. Make sure the ground wire is in the plug good and that the screw is tight and follow that wire back and make sure its in good condition and not broke. But to know for sure is to run another wire and ground it to the neck of the trailer.
Old 07-12-2006, 03:00 PM   #7 (permalink)
At this point it can't hurt to try that. I will let you know.
Old 07-12-2006, 03:14 PM   #8 (permalink)
Use your jumper cables for the test ground wire.
2001 7.3L F450 4x4 CC Automatic Fontaine Conversion 4:30 Limited slip Reyco Granning Full Air Ride Supension, Transfer Flow Fuel System, 4" MBRP turbo back, gages, pryo pre turbo.
Build Date 03-12-01 in KY. Towing a 34 foot Thor Tahoe toy hauler 5er.
2004 F250 CC SB XLT 6.0 Automatic Gauges Big Walker Truck Muffler towing a 23 foot American Freedom with a buggy inside
OldmanII is offline   Reply With Quote Quick reply to this message
Old 07-12-2006, 03:33 PM   #9 (permalink)
That is still not it. I used a piece of new 10 gauge wire directly from the battery negative terminal to the trailer's ground input. Still no lights. Also double checked impeadance from truck pigtail ground back to negative terminal, resistance is near zero.
Old 07-12-2006, 03:36 PM   #10 (permalink)
batkerson's Avatar
This may be a little off the wall but check for corrosion on the fuses or where the wire attaches to the plug (on the truck end) for looseness or corrosion?
1995 F-250 4X4 SC LB E40D 4.10 LS: gutted EBPV, tru-cool 4590 trans cooler, ISSPRO Trans., PYRO and Boost gauges, 3"-4" down pipe, 4" exhaust , Tymar intake, Bilstein 5100s, Silver Star Ultra headlights, 4-position switch (stock, high idle, economy and towing), rebuilt trans (myself).
batkerson is offline   Reply With Quote Quick reply to this message
Old 07-12-2006, 03:41 PM   #11 (permalink)
Can you disconnect the marker lights from the trailer plug or where they are spliced to the cable and check if you have voltage without the lights in the circuit?
Old 07-12-2006, 03:48 PM   #12 (permalink)
Batkerson: I have checked for corrosion or burning on the wires all the way back to the battery junction. Everything is clean. I have disconnected and reconnected all of the connectors in the circuit.
OldmanII: Yes, without the lights connected I have voltage. As soon as the lights are back in, there is no voltage. Same thing happens with the other trailers as well.
Old 07-12-2006, 03:56 PM   #13 (permalink)
batkerson's Avatar
Do the lights on the truck still work with the trailer plugged in? Do the running lights blink when you turn on the turn signals or step on the brakes? Still sounds like a loose/corroded connection to me (had that happen on a house breaker panel when the contact between the breaker and the panel had corrosion between them. Would carry voltage but no current).
Old 07-12-2006, 04:06 PM   #14 (permalink)
Truck lights work perfect when trailer is plugged in. Running lights do nothing when turn signals or brake lights are turned on.
Old 07-12-2006, 04:21 PM   #15 (permalink)
Have you taken out the bulbs and checked the voltage at the lights inside the socket?
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
