Re: Travel trailer brake controller needed...
It may not be the controller. Check the output of the brake wire in your trailer hookup with a voltmeter. No volts on application of the brakes means it is in the truck. Check the relays and fuses first. Brake controller is not a wear item. If there is power at the connector, use a small compass and hold it at the wheels with brakes. As the brakes are applied, the compass needle should deflect towards the activated magnets. No juice to the brakes means the trailer wiring is suspect. Maybe some critters munched on the wiring in storage.
