Old 12-22-2005, 02:40 PM   #1 (permalink)
trouble codes & exhaust brake
diy exhaust brake works well on '02 f350, but ses is triggered...dtc from odo shows d027 and d262, all systems seem to work okay...any thoughts?
Mike
Mike
ovrcr is offline
Old 12-22-2005, 09:57 PM   #2 (permalink)
Re: trouble codes & exhaust brake
You need to get the codes that are stored in the PCM. The odo trick won't do that. Those codes don't mean anything in relation to the SES light.
Casey_1 is offline
Old 12-26-2005, 12:06 PM   #3 (permalink)
thanx for the info, i didn't realize the odo codes were no good!! cel has extinguished itself, stll no problems...while i was testing the ebpv brake, i put a load against it with brake engaged...i figure i probably induced a high back-pressure sensor to trip...my bad!! all is well...
Mike
ovrcr is offline
Old 12-26-2005, 08:48 PM   #4 (permalink)
What odo trick is this your talking about?
lebeouflimousin is offline
Old 12-27-2005, 12:07 AM   #5 (permalink)
Its not uncommon to get a SES light when using an exhaust brake. When you say its a DIY I'm guessing you're using the factory warmup valve. I also (had) an '02 with such a system and it would usually,but not always, turn the light on. After several starts and stops without using the brake the light will go out. I just learned to ignore it- as long as I knew it was from brake usage. Perry
2006 F-250 4X4 Lariat, C.C. / SWB -- Torreador red
PerryB is offline
Old 12-27-2005, 12:34 PM   #6 (permalink)
I assume that you are using the Exhaust Backpressure warm up value? I have mine disabled and would like to use it as an exhaust brake. Does it work well for you? I was thinking that I would buy the product from spdiesel.com to keep the sensor happy.
1992 E350 7.3 IDI, 3.73 club van - 160K
1998 Quad cab 2500 12V Cummins, 4x4,auto - Fathers
2000 F350,DRW converted to SRW,4x4,6 speed,Lariat,Napa 6642 airfilter,Edge Juice w/Attitude,Cody Cushon gooseneck, 165K, Prodigy, 3.73 gears
Truck and Trailer
2002 TDI Jetta Manual 155K
2002 TDI Jetta Manual 169K
2003 TDI Jetta Maual 65K
2002 TDI Jetta Auto 112K
1999 Polaris Diesel Quad
2004 Kubota BX 1500 599cc diesel
(yah I like the old mechanical diesels)
Westro is offline
Old 01-09-2006, 07:57 PM   #7 (permalink)
I have an exhaust brake made by Western Diesel I installed in June 2001. I pull in the mountains every summer and it works great. To be effective you need to either buy one that locks the torque convertor or wire a TC lockup switch like I did. I don't think Western Diesel is around anymore. I forgot to mention this brake uses the EBPV.
2000 F350 CC 4WD
WD exhaust brake
TC lockup toggle switch
Magnaflow Performance Exhaust
AIH heater delete
Pyro gauge
Boost gauge
Zoodad Mod
36' Raptor 5th wheel
pt4557 is offline
Old 01-14-2006, 10:37 AM   #8 (permalink)
observations: with auto tranny, my tc stays locked ok for brake to work in effective range (2k-3k rpm), efficiency drops off at lower r's. cel does reset after a few non-uses..odo trick: hold odo reset button in while inserting key, turn key on, odo will soon begin display of various functions (do a search)...I only use this brake on 6% or greater grades with 10-12k 5th, works great to hold speed without constant brake applications...od off, brake on, nice easy descent... would do it again in a heartbeat! oh, yeah, truck warms up quicker when engaged...
Mike
ovrcr is offline
