Truck getting older ..... Towing getting tougher - Page 2 - Diesel Forum - TheDieselStop.com
Old 01-20-2008, 07:58 AM   #16 (permalink)
Parts Jimmy's Avatar
That surly could be the cause BUT check out that fan clutch also. Taking the transmission out of OD is a good way to keep the tranny cooler by moving fluid through the cooler and the tranny faster. It also keeps the EGTs down and radiator cooler. I would also suggest a change of location in the sensor for the EGT gauge. Pre-turbo is much better for accuracy. I would also look at lower gears for the diff also.
2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Donaldson M085171 Muffler,
SCT X3 w/DP-Tuner 60T-80T-80E ,
Transgo Equipped 4R100, Autometer Guages,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer,
Timbren Overloads, Code L Front Springs,
Bilstein Shocks, BFG Commercial TA Rubber,
Hella 700FF Driving Lights
6.0-6.4 PSD Motorcraft Filter Comparison Video
Fuel Quality Video
Parts Jimmy is offline
Old 01-22-2008, 02:22 AM   #17 (permalink)
big_blue's Avatar
When the engine is hot I can turn the truck off and the fan stops on a dime. I think the fan/clutch is working.
Since I'll probably turn over 253,000 this week, re-gearing probably won't happen! Unless I shred the rearend. That would be a great excuse!
Thanks guys.
'99 F250 PSD 4wd CC LWB, 355+K Hard Miles!!!
Never been in the shop in it's life!!!
big_blue is offline
Old 01-22-2008, 07:37 AM   #18 (permalink)
bersa45's Avatar
Originally Posted by techkdb View Post
snip snip .... the hardware cloth ... snip snip snip ....
Whats this? Can you describe it?
I use a winter grill guard/cover that has a summer screen. Had to be installed with snaps drilled/screwed into plastic/chrome grill.
I just used a piece of window screen and cut it to fit the front of the radiator. This works great to keep everything clean.
2005 F250 CC 6.0 3.73 rear end white/silver short bed 4x4 lariat loaded, Sirius radio,cb,locking glove box,Ruger SR9,harpooned fuel tank pulling 33' Rockwood TT, with 116,000 comfortable miles!!
bersa45 is offline
