Old 08-05-2008, 10:30 AM   #16 (permalink)
My Photos: (27)
They're so long and involved with many pics it would be about impossible to Email. I've seen the big blowup pics of the system posted on one of the IDI forums and I think one of the guys has them on his "how to" site. If you don't find them on the factory sites, you might ask over there. The Banks and ATS are similar enough, the info from either would give you a good idea about both.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 08-06-2008, 12:15 PM   #17 (permalink)
Steve250's Avatar
Does the sound of the truck change when you put a turbo charger on it?
'92 F-250 7.3 IDI Diesel 4:10 (just hit 90k) 4x4 ext cab (Prodigy brake controller)
'98 Ranger 4x4 ext cab - wheelin' in the mud
Steve250 is offline
Old 08-06-2008, 02:07 PM   #18 (permalink)
Steve250's Avatar
I just talked to a guy from ATS and a guy from Banks, it would cost me $2,178 for an ATS system and $3800 for a banks system. Why is there such a drastic difference in cost? Does it have to do with the muffler system?
Thanks again,
Steve
Steve250 is offline
Old 08-06-2008, 03:42 PM   #19 (permalink)
My Photos: (27)
Doesn't suprise me. I researched both systems to death before I chose the ATS. I talked to the "expert" Banks reps numerous times and the time was most spent insulting and bad-mouthing the other two competing brands by the sales staff so rather than quote their various claims, etc, and getting my post deleted, I won't go into it. When I said I heard that Ford was going with ATS from the factory in '94, the reasons they told me why that was happening rather than chosing Banks was a real knee-slapper.
The ATS kit does not include a pyrometer or boost gauge, but I think Banks does. They can both be bought and added later from any truck parts house, even Napa.
The new wastegated ATS kit had just come out when I installed mine and I ended up talking to the owner of ATS (at that time) by phone a couple times and he was really informative and helpful in regards to how they engineered their latest system, how they arrived at the the ideal boost PSI, etc. The ATS exhaust is 3" with a straight-thru muffler, I think Banks is the same unless you order their Monster Exhaust which I guess is 4".
You got me curious and I just dug around, found my reciept. I was wrong, I paid $2700 for the complete kit at an Oregon truck shop way back in around '93. He had priced out the exhaust separately is why the under $2500 figure stuck in my mind. There's not quite the demand now like then so maybe that's why they're going for $2100, but make sure that includes the complete 3" exhaust.
With the straight through muffler you get just a touch more throaty exhaust, not loud by any means, the turbo vans have an muffling effect. You also get a slight turbo whine out the exhaust under a light throttle around 1200-1800 RPM. However, if you're coming down a grade and stay in about the 2500RPM range with a load behind you, that baby REALLY raps all the way down like a big truck Jake Brake before all the noise restrictions.
LMJD is offline
Old 08-06-2008, 04:24 PM   #20 (permalink)
Steve250's Avatar
What's a pyrometer do?
The guy at ATS said that it doesn't come with an exhaust system - it comes with a down pipe that hooks up to our muffler system.
What should I do?
EDIT: I just talked to the guy from ATS and he said it would be an extra $374 for the exhaust system bringing the grand damage to $2,468.
Any other thoughts?
Thanks,
Steve
Steve250 is offline
Old 08-06-2008, 06:45 PM   #21 (permalink)
pyro tells how hot the exhaust is---which you need, and dont push the temps over 1200. less you want melted pistons----and yes--you want the exhaust upgrade---as that amount is quite a bit less than if you buy it later!!!!!!!!!! then push up the boost--and up the fuel--and it will run--but youll still have to watch that exhaust temp!!!!!!
94_turbo is offline
Old 08-06-2008, 06:52 PM   #22 (permalink)
Steve250's Avatar
So do I have to get a pyrometer? Or can I measure a different way? How much does it cost and where can I get it?
Thanks a mil,
Steve
EDIT: I just talked to the guy from ATS and he said that a pyrometer is pretty much a necessity and it would run me $189 bringing all the damage to $2,657.
Now, since I have the turbo, exhaust and pyrometer cleared... is there any other add ons that I NEED to make this work?
Steve250 is offline
Old 08-06-2008, 06:58 PM   #23 (permalink)
dakotajeep's Avatar
nope, pyro is the only way. My guages should be at my door in the next few minutes. Ensure that you get quality guages since you dont want to have a engine issue/failure due to a $100 part....
1994 F350 XL Crewcab 4x4 SRW 7.3 NA
Dana 60 Sterling 10.25 3.55 285/75 16 Dayton Timberlines
TC lockup Mod
Pyro Installed!!!
TO DO: Boost guage, Tekonsha Voyager Brake controller and Turbo when I acquire one!!!
A little rough but its a truck not a show car!!!
PICS of my rigs and random stuff: http://s230.photobucket.com/albums/ee67/dakotajeep/
dakotajeep is online now
Old 08-06-2008, 07:00 PM   #24 (permalink)
Steve250's Avatar
Do the gauges come with the pyrometer?
Steve250 is offline
Old 08-07-2008, 11:28 PM   #25 (permalink)
My Photos: (33)
is your truck stick or auto?
if its an auto i would highly recommend getting a bigger trans cooler as the factory cooler is a JOKE. The factory power steering cooler on a 99 Up is larger.
Also a shift kit would be higly recommended.
My 94 factory turbo would eat transmissions like crackers. The mods made it worse.
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
Dualie is offline
