Re: Turbo & Injector info
I run between 600 and 900 normal driving and if I throttle hard on it and run it from 0 to 100 I get a hair over 1200 on my EGT
Alot of your lower EGT's have to do with the H2E, that you have.
I am pulling a 38 Foot Fifth wheel, unloaded its 12k loaded its 17k.
What are you EGT's when towing?
I am looking for advice from someone actually running these instead of trying to sell me some.
I have a set of injectors and a chip. I can run it pretty hot, easily in excess of 1200 degrees when pulling our 28ft 5er on long hills. You learn to watch the pyrometer. You may be able to get away, staying in the throttle longer and harder with the H2E? [img]/ubbthreads/images/graemlins/shrug.gif[/img] I would assume so.
Your truck is equiped with split shot injectors. There's only a few companies out there, that truely know what they are doing with those injectors. I'd would talk to them all; and make a educated decisions. I would ask, do they have a flow bench? What type of service do they provide(tech,moral support, install, etc)?
I hope this helps, and good luck with your injectors. Carl
97 F-350,4wd,cc,long bed,4.10,35's,rebuilt E40D,H2E,3" intakes,Head studs,,pyrometer,boost,trans temp,home made open intake,Joe servo IDM, Inner cooler retro,Baby swamps 170/146, Bills 3 position chip,Updated HPOP, home made oil bypass filter system, A/C mod, updated super duty fuel system, 60 gal/toobox combo.
