UPHILL TOWING - Diesel Forum - TheDieselStop.com
Old 05-21-2007, 02:50 PM   #1 (permalink)
BRG
UPHILL TOWING
I tow a 37' 5th wheel with my Power Stroke, 5sp auto. Coming back from Pismo, I was in Tow/Haul mode going uphill when my engine temp gauge went to hot and a temp warning beep went off. I pulled over for a couple minutes, dropped into 3rd and pulled up the hill just fine. Is this a gauge malfunction, or should I have been in 3rd to begin with?
BRG is offline   Reply With Quote
Old 05-21-2007, 04:00 PM   #2 (permalink)
Re: UPHILL TOWING
Did you get any other signs; like smell or see anything abnormal?
Did you hear the fan engage?
I don't have the newer transmission but with mine it will generally find the gear it needs to be in. I may hold it in a gear if it is just going to go back into that gear anyway.
I know if I was you I would want to know for sure if it overheating.
99 F350 PSD,4x4,reg cab, auto,built 08/98,Gemtop,
rear Reunel bumper & winch, John Wood transmission, DP tuning.
White 99 is offline   Reply With Quote
Old 05-21-2007, 06:13 PM   #3 (permalink)
BRG
Re: UPHILL TOWING
I heard the fan kick in, but then I heard a high pitch noise that sounded like it came from the fan also, then it got hot. The temperature remained normal the rest of the way home.
Old 05-21-2007, 07:34 PM   #4 (permalink)
Re: UPHILL TOWING
What year is it?
Bill
Received from Bobby @ Sunrise...
2005 F350 CC Lariat LWB, 6.0L, AT, 3.73 LS, Lariat Luxury, Chrome Cab Steps, Block Heater, AM/FM 6 Disc, Stablizer Package, Rear Vehicle sensor, 12.5K Hitch, Towcommand system,Adjustable Gas/Brake. ARE K Series Cap with Bedrug bedliner.
BillD is offline   Reply With Quote
Old 05-21-2007, 10:56 PM   #5 (permalink)
Re: UPHILL TOWING
Could the high pitch noise been the fan belt (serptine belt) slipping?
I am thinking maybe the fan wasn't doing it's job and possibly the pump wasn't either because the belt was slipping.
On the 7.3's the belt tensioner sometimes goes bad and causes problems. On mine it is not too hard to remove belt and check tensioner and pullies.
On the other hand the slipping is usually at the higher RPM's so it would be more likely to do it in 3rd than 4th.
Old 05-21-2007, 11:47 PM   #6 (permalink)
Re: UPHILL TOWING
My 06 did that and they replace the fan clutch...or whatever the part is that engages the fan. Once replaced, never had an issue with heat and no more squealing.
2007 F350 White King Ranch Crew Cab 4x4
7" EDGE 4 Link Suspension, Fox Remote Reservoir Racing Shocks all the way around with Duals up Front, and Dual Steering Stabilizer. 37" Toyo MT's on 20" wheels.
Fully polished MBRP T304 turbo back exhaust finshed off with a 6" x 18" tip from ITP Diesel...Thanks Dennis!
Future mods, DePricol White Faced Gauges and a 24 volt inverter and power supply mounted in the bed,
NFA_Fun is offline   Reply With Quote
Old 05-22-2007, 10:02 AM   #7 (permalink)
BRG
Re: UPHILL TOWING
It is a 2006.
Old 05-22-2007, 12:55 PM   #8 (permalink)
My Photos: (30)
Re: UPHILL TOWING
For a question such as this you need to provide a lot more information on your truck. Is it a 250, 350, a dually? Mods, etc - 37'(dry weight? Have you been to a scale yet?) is a big 5th wheel and if you have invested in a toy (and truck) the least you should have is gauges telling you when what your truck is doing. The standard dash gauges are idiot lights (for lack of a better term here). Trans, EGT, and Boost are the minimums. These trucks run hot, so I have invested in aftermarket parts to aid in keeping the truck cool. i.e. water meth injection larger trans pan, and shortly an additional trans cooler from B & M.
And no you don't shift the gears in your 5 speed for towing or start in 3rd. These transmission are computer controlled and do an excellant job. I am constantly adjusting my driving based on what my gauges are saying. My 5'er is just 10,000 pounds and I must tow thru mountains to go anywhere so without my gauges I would have surely burned up something by now.
Also check your manual if you are indeed running a F250 I bet your overloaded by a large margin..
Matt
03 KR F250 6.0 ltr CC Sb AFE, pro flaps, MBRP 4" duals, Cobalt/VDO gauges, Water/Meth. Coolant Filter, Custom Airbags w/ Comp. & 5 gall tank. Weathgd. box, Alarm system, St sys w/ cam & Nav, 52 gall tank. BD Exh brk, CB, Cryo'd Pwr Slt brks Custom LED lights
http://photos.thedieselstop.com/show...0/ppuser/60588
patchzx7r is offline   Reply With Quote
Old 05-27-2007, 12:12 AM   #9 (permalink)
Re: UPHILL TOWING
Sounds to me like he was towing too much with a performance tune. Or just plain towing too much.
2009 F450 Lariat 4x4
2007 F350 KR DRW CC 4x4-Gone
2005 Mobile Suites 36TK3
wingnut60 is offline   Reply With Quote
Old 05-27-2007, 11:38 AM   #10 (permalink)
Re: UPHILL TOWING
Hi BRAGNF250,
I live in the country so mine gets alot of dust on the belt and clutch. I've learned to hose off my engine and radaitor before making a road trip. That made a huge difference of my belt not slipping and the fan clutch not overly working it's self.
Are you holding the fuel pedal at WOT while climbing grades? Try 3/4 of fuel pedal while climbing a grade and let the transmission downshift.
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run
Define Union:
A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
T_Bone is offline   Reply With Quote
