Old 02-22-2007, 01:05 AM   #1 (permalink)
Using trailer brakes with 4prong wiring
My brother has a 98 Explorer and was looking at buying a trailer with brakes on it, but his Explorer doesn't have the wiring in it.. yet... Looking around all's I see is the 4 prong connectors not the 7 way... Is it possible to use trailer brakes with the 4 prong connector? If not is there a way to put in a 7 way connector versus the 4 prong?
<font color="red">2005 F-250 4x4 Crew Cab PSD "SOLD"</font>
2006 F-250 4x4, Crew Cab, Diesel, Lariat, Short Bed, 3.73,. Captain Chairs, Tow command, Upfitters, Moonroof, Alarm system with remote start, Rhino Liner, bug shield, mud flaps, and Ziebarted! <font color="blue"> Sold!</font>
ljack10270 is offline
Old 02-22-2007, 02:10 AM   #2 (permalink)
Re: Using trailer brakes with 4prong wiring
No the 4 way only has lighting capacity you should use the 7 pin connector, you could wire it with only 4 pins but it would not work with other vehicles and using 7 wire would make it easier, you will have to add a brake controller and the wiring, on the upside its not real complicated to do
1995 F-350 Powerstroke 7.3 300000 miles
neepsjeeps is offline
Old 02-22-2007, 12:39 PM   #3 (permalink)
Hmm. Know of any how-to's we can find on it?
Old 02-22-2007, 08:10 PM   #4 (permalink)
Hmm if there is a pigtail on the truck somewhere that I could plug into to have a 4 prong plug couldent I just cut the end of the 4 prong plug and plug them in their appropriate spots on a 7 way and run a wire from the brake controller and put it in it's spot on the 7 way??? I have no clue what the other 2 are... (left turn, right turn, brake lights, trailer brake, ground,?,?
Old 02-22-2007, 08:29 PM   #5 (permalink)
Thats what I did on my old Chevy. Bought one of those trailer kits that comes with a tee that plugs into the wiring, then gives 4 pin flat. Just cut the wires off and plugged them into the 7 pin. Think 7 pin is LT, RT, Brake controler, backup lights, constant 12v, ground and tail lights. Just need a brake controller and run a wire back to the plug. I used an outdoor extension chord. Used one wire for the 12v and one for the brakes. Gets the wire double insulated. Just ran it along the frame with zip ties. Pretty simple.
Aaron SEIA
My Truck:
94.5 F350 dually crew cab psd 5 speed
0-35 lb DiProcol Boost gauge
DIY Intake
3" MBRP DP
AaronSEIA is offline
Old 02-22-2007, 08:37 PM   #6 (permalink)
Aaron SEIA
Where did you run the 12v wire from?
Old 02-22-2007, 09:19 PM   #7 (permalink)
Went right to the battery and put a 30 amp inline fuse in it.
Aaron SEIA
My Truck:
DIY Intake
3" MBRP DP
Old 02-22-2007, 10:09 PM   #8 (permalink)
SmokeyWren's Avatar
My Photos: (33)
I'll check more, but I think this is right:
4-pin =
ground,
running lights
right turn
left turn
Both turn signals at the same time makes brake light or emergency/hazardous flasher
6-pin adds:
brake control
12-volt hot (battery charge wire)
7-pin adds:
auxiliary (backup lights?)
On edit: I was wrong before I edited this. [img]/ubbthreads/images/graemlins/blush.gif[/img]
SmokeyWren is offline
Old 02-22-2007, 10:38 PM   #9 (permalink)
G BURDICK's Avatar
Hey Smokey,
I think the marker lights would be on with the tail lights and the six pin adds reverse lights and brake control. I don't remember. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2001 F350,XLT,CC,4x4,PSD,6-SPD,SRW,156"WB,OFF-ROAD,LS,PTTTM,AIC,HAYES GENESIS BRAKE CONTROLLER,BILSTEIN SHOCKS,BRIDGESTONE DUELER A/T REVOS,POWERSLOT ROTORS AND HAWK LTS PADS,PML REAR DIFF COVER,RHINO LINING,GARMIN STREETPILOT 2720,SIRIUS RADIO,TRUE BLUE
2006 F350,XLT,SC,4x4,6.0L,TORQSHIFT,SRW,142"WB,FX4,LS,E SOF,TOW
COMMAND,UPFITTERS,LINE-X,WEATHERTECH MATS,GARMIN GPS V,DARK GREEN SATIN W/SILVER
G BURDICK is offline
Old 02-22-2007, 10:56 PM   #10 (permalink)
Hey thanks guys.. I'll just run the 4 prong adapter from in the tail light and cut the 4 prong plug off the end and run one from the brake controller and run a 12v hot one into a 7 prong plug... Which tail light is the pig tail in? Is there anywhere else you can run the 12v hot from besides the battery?
Old 02-22-2007, 11:02 PM   #11 (permalink)
Hey Smokey,
RV's and OVR trucks are differnt
Yeah on an RV its backup lights
On the big rigs its marker lights like Smokey said
Big rigs have it seperate so they can flash the marker lights .
O5 F-250 SuperDuty CC SWR 4x4 Lariat
8' box 6.0 PSD Tow Comand new 04/05
2001 40' Alfa Toyhouse
Pulls better stock than my 01 with a programmer
New engine at 42k . Hope my luck with this 6.0 is changed .
firesoutmatt is offline
Old 02-22-2007, 11:05 PM   #12 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Hey Smokey,
I think you're right. According to http://www.rverscorner.com/wiring/ the standard 7-pin RV plug includes:
1. white = ground
2. blue = brake control
3. green = running
4. black = power (battery charger?)
5. red = LT and stop
6. brown = RT and stop
7. yellow = Aux (backup?)
The 6-pin doesn't have the Aux wire, and the colors are different:
white = ground
brown = running
yellow = LT
green = RT
blue = brake controller
black = power
The 4-pin is lights only:
white = ground
brown = running
yellow = LT
GREEN = RT
Old 02-23-2007, 12:36 AM   #13 (permalink)
here try this
http://www.ontheball.com/wire_installation_tips.htm
http://www.etrailer.com/faq/wiring.aspx
http://www.accessconnect.com/trailer_wiring_diagram.htm
http://www.hitches4less.com/trailer-...-diagrams.html
see i have always been taught and always wired up trailers i built using this method:
1. white = ground
3. green = RT and stop
5. red = aux
6. brown = tail/side marker
7. yellow = LT and stop
not sure why you would want to switch the brown, yellow, and green wires around just because you have 3 more pins. i have had to replace plugs on pre-built trailers from Big Tex and they were wired with 7-way plugs the way i have been using.
not stepping on any toes, just another point of view
-cutts-
My Picasa Web Album
96 F350 PSD 4x4 CC/LB 5spd XLT Ranch Hands F/R, 6637 mod, 4.5" straight pipe, tymar 3-4" DP, Dominator 66 turbo, Banks IC system, DIY Stage-I's, TW 4-pos chip, 37" SuperSwampers, autometer gauges,RAM laptop mount w/AI OBD diagnostics, fold down g/n hitch, OBA system with York and dual trumpet air horns, bronco 33gal fuel tank
72 bronco 302/435/twinsticked D20/D60/10.25 welded F/R, hydro assist, 39.5" stretched WB to 105", 1410 yokes/shafts, Staz custom double beadlocks, CroMo shafts front shafts with 35 spline outers and sexy lady drive slugs, GLO diamond tread diff covers, custom cage, mesh floor, custom diamond aluminum dash overlay, wristed radius arm, homemade shackle ladder bar
Fishmanndotcom is offline
For advertising information, please visit our
