Old 05-12-2006, 08:18 PM   #1 (permalink)
Using a turbo wing???
Is anyone using a turbo wing or any air deflectors when towing a bumper hitch trailer? I'm getting a 35' travel trailer and was wondering if they are worth the money? I have an F350 short bed and was thinking,would it be too far apart to be affective ? Wing to trailer would be ruffly 9'+-. I can see using it on a 5th as the trailer is so much closer. What are your views on this? Thanks
2006 Ford F350 Super Duty Lariat,V8 6.0L Turbo Diesel W/29K Miles, Automatic 4WD FX4 Off road Pkg.,Short bed,Towing Pkg., Front Stabilizer bar ,Power 4 wheel anti locking disk brakes,3.73 Axle ratio,AC,Moon Roof,Cruise Control....I love my truck!
http://www.injuredmarinesfund.org/index.asp
http://www.superdutydiesel.com/forum...eferrerid=2351
eddieo is offline
Old 05-12-2006, 08:28 PM   #2 (permalink)
Re: Using a turbo wing???
Not worth the money or time to put it on. It can reduce the amount of bugs on the front of a 5th wheel if adjusted right.
Capt Ron
May 2003 F-350, CC, DRW, 6.0L, 6sp man, LB, Al Wheels, Moon Roof, 52gal tranfer tank. Hitches: Draw-Tite 16K 4X and B&W GN, 8040lbs GVW. Towing 35' Newmar Kountry Star 5th Wheel Camper, 14,000lbs GVW, or Wells Cargo 24' Car Hauler, 12,000lbs GVW.
CaptRon is offline
Old 05-13-2006, 10:06 AM   #3 (permalink)
I've got one on mine, I pull a 5th wheel.
The reason I ended up with one, is that I was down at my RV dealer looking for a used tailgate, the one's that are slotted and let air pass through, because everything in the back was being tossed around like match sticks. He said he didn't have one, but he had a used wind deflector cheap that would do the same thing, so I bought it and it did do the job. I can put stuff in the back of the truck now and expect it to remain where I put it. If it helps me get a few mpg more than that's a bonus.
1995 F-350 XLT Crew Cab Dually 5 spd - Basically Stock - Used everyday for work & play (pulling 1989 36' Airstream Landyacht 5th wheel around the countryside to stock car races). I've owned the truck since new. I'm fortunate enough to be the 4th owner of the Airstream.
Randy
CascarFan is offline
Old 05-13-2006, 07:09 PM   #4 (permalink)
Well we picked up our new trailer today. On the way down we averaged 19.4 mph and with the trailer on the way home,we had 10.5 mpg. I was hoping for a little bit better, but.....The tow package they put on works great!!! Now to find a way to get better fuel mileage.
eddieo is offline
Old 05-13-2006, 09:18 PM   #5 (permalink)
I recently did a 1600 mile towing road trip with my horse trailer (see sig.). I still have not weighed it, but my best guesstimate is that the trailer weighs somewhere around 13K# loaded with two horses and stuff. I usually drove at the prevailing speed of traffic and averaged 11.13 hand-calculated MPG. Your 10.5 is not too bad. I've seen some on here post MPGs down to 7 or so.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
Old 05-13-2006, 10:49 PM   #6 (permalink)
I get about 11mpg towing the 5th wheel in my sig and I run pretty hard. My truck has 34,270 miles on it now.
Capt Ron
CaptRon is offline
Old 05-13-2006, 11:46 PM   #7 (permalink)
Keep your foot out of it. I know its hard, but at 62 I get 14 w/ my 26' TT. At 70, I get 12. Secret to economy is 2k rpms.
OMCUSNR is offline
Old 05-14-2006, 07:56 AM   #8 (permalink)
I'm getting 8.5 pulling my 33' 5th wheel from Ontario to Daytona or Ontario to Bristol. I probably need to ease my foot off the pedal a bit too. I usually travel 60-75 mph. Trailer loaded weighs about 12000#, and truck loaded with generator, etc., about 8000#. Pulling thru the mountains doesn't help I suppose, also I noticed when I switched to Mud & Snow tires on the rear, my mileage went down a bit too. The dual wheels and 410 rear end cuts her back a bit too, I guess. I've been told even my sun visor will help me loose a mpg or two. A friend in a camp site at a local race told me to loose the sun visor and put a front valance on below the front bumper, said I'd pick up a few mpg. I think he's right, it would stop a lot of air from getting in underneath and causing drag.
Randy
Old 05-16-2006, 05:06 PM   #9 (permalink)
NCHornet's Avatar
Those that have had them on the RV forum didn't notice any mpg difference. Think about it the wing is about 5ft wide and the trailer is 8ft!!!
I only get about 9mpg towing my 8500 bumper pull. must be the 4:10's.
Kevin L. Mnt Airy, NC.
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
