Old 05-14-2006, 10:06 PM   #1 (permalink)
My Photos: (28)
Vibration when towing
I am towing a 7500 lbs tandem axle trailer with a diesel tractor with loader on it. I have a weight distributing hitch and use it. I get a vibration that is on for a second and a half and off for a second and a half that vibrates quickly through the whole truck. This happens in drive under power and when coasting in neutral telling me it is not drivetrain. It seems to stop if I squeeze the trailer brake controller and apply trailer brakes only.
Is this maybe due to where my load is distributed on the trailer. Lack of tongue weight or not enough? I tend to put my tractor rear axle over the forward set of wheels with the tractor and loader facing forward.
It is an annoying vibration, makes the passenger seat back shake when no one is in it and reverberates through the truck.
With no trailer truck is perfect.
Any ideas?
2007 GMC 3500 4x4 Dually Duramax/Allison
Sold F350 6.0L TS SRW SWB 4x4 King Ranch FX4 Loaded 409SS MBRP Cool-Duals Isspro Pyro
2005 VW Passat TDI Wagon
2006 VW Jetta TDI
My Truck
My 67 RS/SS Camaro
My Day Job
Armypilot is offline
Old 05-14-2006, 10:13 PM   #2 (permalink)
FINE69's Avatar
Re: Vibration when towing
Maybe you have something wrong with the trailer. Could be a brake or bearing problem, being that it stops when you push the brake controller.
2005 F-350 4x4 Supercab, Lariat, LWB, SRW, FX4, 6.0, Auto. Oxford White/Arizona Beige. MBRP SS Turbo-back Cool Duals-Cat Delete Pipe, DieselSite coolant filter, Mag-Hytec dif cover, Royal Purple Syn. lube in axles, 325-65/R18 Nitto Terra Grapplers on Weld Evo Cheyenne-8 18x8.5 wheels. Fabtech 2" Leveling kit, Bilstein 5100's. Precision Billet grille, Lund Interceptor, Husky liners, Rhino liner, Weatherguard toolbox, 8' Western Ultramount Poly Pro snowplow, 15% tint. Built 12/04
http://community.webshots.com/user/FineFord
FINE69 is offline
Old 05-14-2006, 10:19 PM   #3 (permalink)
My Photos: (28)
I didnt even think of that, the trailer has about 600 miles on since new. And it is less than a year old. I'll have to look into it.
2006 VW Jetta TDI
My Truck
My 67 RS/SS Camaro
My Day Job
Old 05-15-2006, 01:15 AM   #4 (permalink)
It could be a balance problem with the tires on the trailer.
03 F250 SD PSD Lariat 7.3, FX4 Crew Cab Short Box, 3.73 Gears, Auto Tranny, Jody Tipton 80 HP Econo Tune, Turbo Back 4" Exhaust W/5" Tip, Home Made Tymar, Isspro Gauges, T/C Lock Up Switch, 203 Degree Thermostat, Coolant Filter, Upgraded Headlight Wiring Harness, Diode Mod for Dims, Bilstein Shocks, Kenwood Head Unit, Sirius Radio, Valentine 1
Down South is offline
Old 05-15-2006, 08:52 AM   #5 (permalink)
My Photos: (28)
I drove the trailer unloaded with the weight dist hitch bars installed, same vibration but worse.
2006 VW Jetta TDI
My Truck
My 67 RS/SS Camaro
My Day Job
Old 05-15-2006, 11:23 AM   #6 (permalink)
There have been threads on this problem before and I believe that the inclination of the rear axle to the driveshaft was the problem.
Nice Day Job btw.
Capt Ron
May 2003 F-350, CC, DRW, 6.0L, 6sp man, LB, Al Wheels, Moon Roof, 52gal tranfer tank. Hitches: Draw-Tite 16K 4X and B&W GN, 8040lbs GVW. Towing 35' Newmar Kountry Star 5th Wheel Camper, 14,000lbs GVW, or Wells Cargo 24' Car Hauler, 12,000lbs GVW.
CaptRon is offline
Old 05-15-2006, 01:01 PM   #7 (permalink)
i get this problem only when towing a friends trailer witch sounds a lot like what u have.. we noticed that the more u put the weight on the tongue the better the ride.. now i towed this trailer with and with out brakes so it was not the brakes, also towed it loaded and unloaded and yes it was much worse unloaded. now i tow my bosses work trailer and no mater what i never get this problem i think it has something to do with the trailer axles. i don't use any weight distribution hitch and if u note my truck is a dually.. i tow any where from 2000lb's up to 14,000lb's and don't get problems only with that one trailer.. my thought is maybe one of the axles is not aligned with the other and its causing the tire to bounce a little.
2001 F350 SuperCrew Long Bed Dually.
7.3L turbo Diesel, automatic transmission, goose neck hitch, fifth wheel hitch, stainless steel back rack, 315/75-16 BFG A/T's, AUX back up lights, euro-lite driving lights, upgraded fog lights, dp-tuner, auto-meter ultra-lites, 5in stacks no muffler, whelen towmans light bar, DIY tymar intake, DIY coolant filter, 2M ham rig, DIY AIC,
( egauges )
My truck pic's
cdacaraudio is offline
Old 05-15-2006, 05:03 PM   #8 (permalink)
SteveRacer's Avatar
Location: Rockland Co. NY KC2JLJ on 147.165 MHz Design Engineering Machine Shop Owner
Capt Ron might be right ... a racing buddy of mine had the exact same problem, and after several visits to the dealer they replaced the driveshaft and adjusted the angle of the diff housing. Now it only does it empty instead of loaded with trailer.
We have almost identical trucks and trailers, and I've never had a problem. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
HTH-
-steve
S.A McChesney
'72 BMW 2002tii Fprod Race Car --- '82 Bitter SC 5-spd
'01 Volvo V70 T5 5spd, The Official SCCA Volvo Historic Racing Series Pace Car
'95 EB 351 Bronco --- '69 Lotus Europa --- '87 Merkur XR4ti --- '85 Bitter SC 3.9</font>
'02 F350 Lariat CC Dually Longbed PSD 4x4 6spd
Tekonsha Prodigy -- Icom 2100H -- Retrax -- B&W Turnover 5er Kingpin -- Letter to Santa "US Gear" . . .
32' invert 5er Britton/Transport Sys 12K GVWR Toybox,Honda 3kw Gen,Fridge,Micro,5kw Inverter,ColemanPolarCub
__________________________________________________ _______________________
Foglights on with High Beams '02-'08 Superdutys
SteveRacer is offline
Old 05-16-2006, 02:49 PM   #9 (permalink)
My Photos: (28)
Ok here is some more pertinent info maybe.
The trailer even with the load is about 3-4 inches high in the front due to my draw bar does not drop enough. So when I add the equalizer bars it is even more nose high. After re reading the hitch instructions it seems important that the trailer is level.
Could that be inducing my vibration? The trailer not being level?
2006 VW Jetta TDI
My Truck
My 67 RS/SS Camaro
My Day Job
Old 05-16-2006, 05:32 PM   #10 (permalink)
That would be more conducive to sway than vibration.
Capt Ron
CaptRon is offline
Old 05-16-2006, 10:58 PM   #11 (permalink)
I don't know about inducing a vibration, but you'd be putting a lot more weight on one axle vs the other and if you're loaded to the max, risk blowouts on the overloaded axle, I would think???
1995 F-350 XLT Crew Cab Dually 5 spd - Basically Stock - Used everyday for work & play (pulling 1989 36' Airstream Landyacht 5th wheel around the countryside to stock car races). I've owned the truck since new. I'm fortunate enough to be the 4th owner of the Airstream.
Randy
CascarFan is offline
Old 05-17-2006, 04:23 PM   #12 (permalink)
pilot
You are definitely running a lot more weight on the rear axel if the trailer is nose high.
HenryE is offline
Old 05-18-2006, 05:31 PM   #13 (permalink)
My Photos: (28)
Well I have ordered an extended drop bar that will correct my geometry. After that is correct I will then go to other issues if the vibe is still present.
Thanks guys
2006 VW Jetta TDI
My Truck
My 67 RS/SS Camaro
My Day Job
