Old 08-14-2007, 10:07 AM   #1 (permalink)
Weighed My Truck (F250 CC KR)
SmokeyWren will like this...
Weight for:
F250 CC Short bed King Ranch (leather etc)
Gym bag (10 lbs)
Tools (30 lbs)
2 sets golf clubs? (60 lbs)
Cooler (10 lbs)
Other (10 lbs)
Line-x liner
Retrax bed cover (80 lbs)
Full tank of fuel
Me (220 lbs)
4700 front axle
3360 rear axle
8060 total.
Now if I add a 5er hitch (250)
2 more people plus stuff (350)
I can have a max pin weight of 1340, or about an 8k trailer.
SuperDuty...ha
Maybe I should put 4" blocks on it...
2005 F250 6.0L CC FX4 King Ranch Dk Copper Color Matched LineX and a Retrax cover
gecko2424 is offline
Old 08-14-2007, 12:15 PM   #2 (permalink)
Re: Weighed My Truck (F250 CC KR)
Sounds like you need on 1 ton [img]/ubbthreads/images/graemlins/smile.gif[/img]
1992 E350 7.3 IDI, 3.73 club van - 160K
1998 Quad cab 2500 12V Cummins, 4x4,auto - Fathers
2000 F350,DRW converted to SRW,4x4,6 speed,Lariat,Napa 6642 airfilter,Edge Juice w/Attitude,Cody Cushon gooseneck, 165K, Prodigy, 3.73 gears
Truck and Trailer
2002 TDI Jetta Manual 155K
2002 TDI Jetta Manual 169K
2003 TDI Jetta Maual 65K
2002 TDI Jetta Auto 112K
1999 Polaris Diesel Quad
2004 Kubota BX 1500 599cc diesel
(yah I like the old mechanical diesels)
Westro is offline
Old 08-14-2007, 02:27 PM   #3 (permalink)
I was surprised at how heavy these trucks are.
Mine was 5250 FA and 3950 RA. I had probably 250lbs of junk (chains, binders, clothes, cd's. My front tank was about 3/4 full and my rear tank was empty (60 gal.) So with full fuel I'm pushing almost 10 grand! [img]/ubbthreads/images/graemlins/eek.gif[/img]
2006 Job 2 F-350 Crew cab King Ranch single wheel 4x4 92k
2007 Dodge 3500 6.7 4x4 14k
Former diesels: 91 D250, 93 D350, 95 F350 PSD, 96 Dodge 3500, 2000 F350, 05 D-max: Fire, 2004.5 Dodge 3500, 2005 Dodge 3500
TXGooseneck is offline
Old 08-14-2007, 03:11 PM   #4 (permalink)
9320 full fuel, no driver [img]/ubbthreads/images/graemlins/laugh.gif[/img]
5220 front axle
4100 rear axle
Good thing my gvwr is high!
2008 F550 6.4 w/ pickup bed
kehale is offline
Old 08-15-2007, 12:50 AM   #5 (permalink)
DezRacer's Avatar
They must have got heavier. My 01 PSD CC LB 4wd came in at:
Ft axle: 4340
Rr axle 2940
Total: 7280.
That is with a full tank of fuel (topped off at the CAT scale) and little else. I was inside paying. I don't keep any junk in my truck.
"I just want to be free, free to ride my machine, and not get hassled by The Man"
DezRacer is offline
Old 08-15-2007, 12:57 AM   #6 (permalink)
Mine ways 7230 with a half tank and me and nothing else, rides like a truck. Normal load, tool box with normal stuff, me and a half a tank 8500 rides quite a bit smoother.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
Old 08-15-2007, 02:35 PM   #7 (permalink)
my3wags's Avatar
3420# rear, 4480# front 7900# total. 1/2 tank of gas, 5th hitch, tools and me.
Big E and family of Three
2002 F250 4X4 CREW CAB PSD 4" LIFT
4" turbo back exhaust*custom tymar*DP tunes*Polished ATS housing*6.0 intercooler*Chromed intercooler pipes*H/O chromed Alternator*Dieselsite boots*203 thermostat*40K Trucool*FTVB*Manual TC lock-up*EBPV brake*AIH delete*boost Annihilator*Custom CCV*ITP/KCM (HPX)*Coolant filter*08 diff cover*DI fuel shim kit .055 @68 psi*engine mounted fuel gauge*custom engine cover*triple gauge*((XM))
297Hp dyno 2/11/07 (I need more power Scotty!!)
Waiting for install
pre-pump mod
2004 Keystone Sprinter 297fwbhs 5th wheel
with most of the goodies
my3wags is offline
Old 08-15-2007, 06:22 PM   #8 (permalink)
bogg's Avatar
My Photos: (5)
Thats the main reason I moved up. 800# of load capacity? Not funny
07(built 06/06) 6.0 Lariat/Moonroof/Camper Pkg/ FX4/DRW/5spd TS/13K GVWR/4.10LS/CC/LB/F350: Accufab Elbow/Mag-Hytec/AutoMeter Tripod(EGT/Trans/Diff)/PIE-Sirius-IPOD/Infinity Speakers/Zoodad/Fumoto/IH-HFCM/Precision Grill/Special Edition UT Weatherguard Crossbox/Coolant flush@25k/Coolant in-line Filter/MBRP 4" Duals/ My Truck Pics:
http://good-times.webshots.com/album...ost=good-times
bogg is offline
Old 08-16-2007, 10:01 AM   #9 (permalink)
My truck weighs 7200 empty with me and half tank. Is the reason a F250 weighs that much more because it is 4wd?
02 F350 7.3SD Crew/LB/SRW DP-F5 (stock, 60t, 80e), Fumoto valve, gauges on A-pillar, XM Radio, Happijac tiedowns
99 Jeep TJ / lockers / 37s
KVOM is offline
Old 08-16-2007, 10:54 AM   #10 (permalink)
I think it is more the options that comes with the King Ranch and the truck frame, engine weight etc. They just pack it in. My truck weighs around 7500 lbs with me, couple hundred pounds of tools, aluminum ladder rack, plow subframe, and half a tank of fuel. If I ever bought another SRW truck it would be an F350 no question.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
NickKent is offline
Old 08-16-2007, 12:50 PM   #11 (permalink)
I weighed my 06 F350 a couple of weeks ago, It had a full tank of fuel, line-X bedliner and a UWS tool box, not nuch in it. it was 7860 lbs.
07HEMI4ME
Purchased a 2007 Dodge, ThunderRoad Edition, QC, 4x4, 5.7L HEMI on 11/30/07.
Traded in my Travel Trailer for it, so no need for a Diesel.
2003 EB Expedition 5.4L
2006 F350 Lariat, 6.0L PSD, Crew Cab, FX4, 4x4 PURCHASED BACK BY FORD! on 8/28/07.
07HEMI4ME is offline
Old 08-16-2007, 11:38 PM   #12 (permalink)
Smiley1's Avatar
Me (170) and a bed full of broken up concrete weighed in at 10200 with truck in sig. I was a bit over but the truck sure didnt care.
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
1996 Saturn SL2 commuter (37 mpg)
Smiley1 is offline
Old 08-17-2007, 01:07 AM   #13 (permalink)
Now that's a load, bet you were squatting a bit. That's what I have found, the body might not like it but the motor just flat ass doesn't care. If you ask, it will move.
Andy
arisley is offline
Old 08-18-2007, 01:10 AM   #14 (permalink)
Smiley1's Avatar
It was the first and only time the back has ever sat slightly lower than the front. It came with the camper package which includes overload springs.
Smiley1 is offline
Old 08-18-2007, 01:22 AM   #15 (permalink)
I also have overloads, two wheels on each side, I was concerned when I was going to pick up two pallets of sod. After I saw how it handled that load, if it will fit in the bed, load it up, I aint' skeered.
Andy
arisley is offline
