Old 05-02-2006, 12:24 PM   #1 (permalink)
Weighing a rig
I need to weigh my truck and trailer, for peace of mind, to be sure that I'm not over my max weight.
There is a Flying J that I pass daily but I don't know what their procedures are for weighing and I figured someone on here has done this. I tried calling them but found myself on eternal hold........
Can someone explain the procedure, do I contact them first, just drive on the scale and go in to get my weight or what????
Thanks in advance for the help
Bama
1999 F350, bought used 1/2001, Crew Cab, DRW, 7.3 PSD, 3.73 gears, lighted running boards, Sony CD w/ two 10's and 1500 watts. Pulling a 32' Enclosed Gooseneck trailer.
BamaPSD is offline
Old 05-02-2006, 01:37 PM   #2 (permalink)
Re: Weighing a rig
If it is a Certified Cat Scale just slowly drive onto it. There should be 3 seperate pads for you steer axle, drive axle and trailer axles. Push the button and talk to the attendant. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
brassc is offline
Old 05-02-2006, 01:52 PM   #3 (permalink)
Re: Weighing a rig
I believe it is a Cat scale.
What information do they need?
Bama
BamaPSD is offline
Old 05-02-2006, 02:25 PM   #4 (permalink)
Send a message via AIM to Jerryc
Re: Weighing a rig
They just need to know that you are there so they know to print a ticket. At my flyng J, there is a phone close by. If they need to know anything else, they will ask you when you call.
JC
F-450, 4wd, club cab, 4.88, KR, satellite, navigation, hi-capacity trailer towing, reverse sensor, memory mirrors/pedals/seats and tailgate step. Also Linex, TruckCoverUSA bed cover, CrimeStopper Remote Start and Alarm and a 25K Air Safe Air Ride 5er hitch.
Jerryc is offline
Old 05-02-2006, 02:58 PM   #5 (permalink)
Re: Weighing a rig
Thanks for the help
Bama
BamaPSD is offline
Old 05-02-2006, 03:37 PM   #6 (permalink)
lincster's Avatar
My Photos: (22)
Re: Weighing a rig
Pull up on the scale, push the button. They will ask you what your truck number is, tell them private.
They will tell you to come on in.
You go in, pay them your money and get your print out.
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... man does this thing tow, Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
lincster is offline
Old 05-02-2006, 03:46 PM   #7 (permalink)
Re: Weighing a rig
Make sure you fill up first. Also make sure your trailer is loaded the way it is when you go camping or your just guessing. At least fill your tank.
If you can read this, thank a teacher, THANK A VET. it's in English: 04/04 F350 6.0 PSD Lariat CC 4X4 LB SRW Auto 3.73 rear end. All options except:moon roof-PTO-roof lights. Mods... MBRP,Line-x, White nite, Windows double tinted, 3 DVD system, Highway products 5er box, Pro-comp leveling kit, Pro-comp wheels/tires, MX-6 shocks,Viper 791XV remote start security system,Line of fire,Fumoto oil drain plug,Alaska tent and tarp bug screen,Rapid hitch drop hitch,Cobra 29 CB, Norcal Powerstrokes Member #5 http://www.norcalpowerstrokes.com/Events.html
SAVAGESAM is offline
Old 05-02-2006, 05:35 PM   #8 (permalink)
Re: Weighing a rig
What do truck stops normally charge for use of their scales? Do most people also weigh their trucks without the trailer?
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
Old 05-02-2006, 05:38 PM   #9 (permalink)
lincster's Avatar
My Photos: (22)
Re: Weighing a rig
Here in AZ, I paid $8.
I weighed my truck all by itself. It is the correct way to determine pin weight. Just have to make sure things are kept constant. i.e. full fuel, same stuff in bed, same passengers (or no passengers) etc.
lincster is offline
Old 05-02-2006, 05:53 PM   #10 (permalink)
Albin's Avatar
My Photos: (24)
Re: Weighing a rig
BamaPSD,
This should help:
http://www.catscale.com/
http://www.catscale.com/howtoweigh.shtml#STA
Good luck.
Al
(Madison, AL)
'06 F-350 SRW 6.0 PSD
Albin is offline
Old 05-02-2006, 08:43 PM   #11 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Re: Weighing a rig
Flying J calls their certified automated truck scale a "J Scale" instead of a "CAT" scale. But it's identical to a CAT scale, with three or four pads for different axles.
Cost is around $7 to $10, and a second weighing (a reweigh) a few minutes later is usually free. So fill up with fuel and weigh the entire rig, then collect and pay for your scale ticket. Tell the clerk you plan to reweigh in a few minutes. Then drop the trailer in the parking lot and reweigh just the tow vehicle without the trailer. Take your first scale ticket with you when you go to collect your "free" scale ticket - the clerk may have changed shifts or gone on break while you were messing around, and the first ticket will prove that this ticket is a reweigh.
The intercom to the desk is usually way up in the air, so the big boys can simply reach out and mash the button. But when I'm in the pickup, I must stand up on the window sill to reach the button. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
SmokeyWren is offline
Old 05-02-2006, 11:04 PM   #12 (permalink)
Re: Weighing a rig
Might also be a good deal to "axle out" your truck too. Weigh each axle individually. Give you a good idea of where the weight of your load is. Most places re-weigh for free or just a buck. Might as well take advantage of it. Your scale ticket will always be at the fuel desk where the big boys pay.
Just eating rainbows and butterflies
01 F350 dually 4x4 CC auto.
311 hp 610 torque a while back.
My Pickup
Some Photos and Sound Clips
Diesel Power & Performance Derby Ks.
#46
Kanman is offline
Old 05-02-2006, 11:21 PM   #13 (permalink)
Re: Weighing a rig
What I do is fill up the tanks and then go in and tell them I want to get weighed, and that I will be doing a second weigh in too. I give them my credit card and my name and when I get to the scale I press the button and say my name so forth. They then say ok or whatever and I go unhook my trailer and come back with just the truck and weigh that. Then I go get my ticket and pay. You might as well figure out the tongue weight, because the extra weigh in is only a $1 or less usually.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
NickKent is offline
