Weight capacity of my 5er pooper tube bumper on a fleetwood? - Diesel Forum - TheDieselStop.com
Old 08-29-2006, 07:51 PM   #1 (permalink)
468LC's Avatar
Let say I weld a standard 2" reciever onto the back bumper of my trailer to mount a motorcycle rack onto.
Would said motorcycle break off from the back bumper?
Motorcycle would be around 300 pounds.
Thoughts and ideas would be appreciated.
Steve
2006 F350 Lariat, 6.0 PSD CC LB 4X4. 77k miles.
Wix/Baldwin coolant filter, Dynomax Ultraflow exhaust, cat mod, Edge Insight CS/with EGT.
Mag-Hytec trans pan, 08 Diff cover.
2" leveling kit. RS9000 Shocks. B&W Turnover Ball/ Companion Hitch. Airlift 5000 airbags.
LineX, 20% tint, Weathertech liners.
2006 Forest River Sierra 5th wheel. 31' @ 11k pounds.
468LC is offline
Old 08-29-2006, 08:04 PM   #2 (permalink)
Gravel's Avatar
Re: Weight capacity of my 5er pooper tube bumper on a fleetwood?
I saw several fifth wheels pulling little trailers behind them while going through either Idaho or Montana, can't remember. Gotta be possible!
01 F-250 4x4 PSD Auto
FJ40 468bbc
Gravel is offline
Old 08-29-2006, 08:06 PM   #3 (permalink)
468LC's Avatar
I have also heard of guys pulling doubles in the south as well.
Never seen it and I cannot believe it is legal. [img]/ubbthreads/images/graemlins/blush.gif[/img]
468LC is offline
Old 08-29-2006, 08:18 PM   #4 (permalink)
Cool_Canuck's Avatar
My Photos: (12)
That bumper is pretty thin. Said motorcyle would have scratch. Very big scratch.
My receiver is actually bolted to the trailer frame and has a metal strap around the bumper which gives it the appearance of being attached to the bumper.
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Cool_Canuck is offline
Old 08-29-2006, 08:23 PM   #5 (permalink)
468LC's Avatar
Thank you canuck.
Is this something you bought or had fabricated?
Any pics?
Steve
468LC is offline
Old 08-29-2006, 08:28 PM   #6 (permalink)
ritschner's Avatar
Send a message via AIM to ritschner
Don't do it. The standard 4 inch bumper is only 3/32 inch steel. You will tear it off. I know [img]/ubbthreads/images/graemlins/eek.gif[/img]. There are two options, either a separate hitch assembly welded to the frame of the trailer or you can remove the current bumper an install a heavier 3/16 or 1/4 inch steel tube to replace it and then weld up a reciever plate. If you use a heavier replacement you will need to cut it short and double butt the ends of your current bumper to be able to still use it for your sewer hose.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
Old 08-29-2006, 08:36 PM   #7 (permalink)
468LC's Avatar
I can weld and I can fabricate.
Just might have to bust out and buy some materials.
I like the whole new bumper idea Uturn.
Anybody with pictures would be awesome. That is how I learn the best.
Steve
468LC is offline
Old 08-29-2006, 08:59 PM   #8 (permalink)
ritschner's Avatar
Sorry no pictures. That particular setup was on a 95 Jayco. I took a 4 inch 3/16 steel tube and cut it 16 inches short and then beveled the inside edges so I could slide the sewer hose in and not tear it. I then cut 8 inches off of each end of the old bumper and welded them to each end of the larger tube using the aluminum bumper cover as a guide. You can also do just one end, but the reason for butting the old tube is that the sewer hose end fitting will not fit into the heavier tube and neither will the same end caps. Then you can weld the new bumper to the trailer frame. Depending on trailer frame thickness (the Jayco's was also 3/16 inch retangular steel tube) you should also use some gussets between the inside of the trailer frame and a spot a few inches in on the new tube along with any other reinforcing deemed necessary. Weld up the reciever plate, install the pretty aluminum bumper cover and you are ready to go.
Old 08-29-2006, 09:09 PM   #9 (permalink)
468LC's Avatar
That explanation helps a ton.
Thanks again.
I now understand what you were talking about for making the sewer hose fit right.
Steve
468LC is offline
Old 08-29-2006, 11:17 PM   #10 (permalink)
My Photos: (12)
Thank you canuck.
Any pics?
This might be factory even though Jayco says not to tow with the trailer. It was on the trailer when I bought it.
Sorry, no pics. There is a 3X1.5" U member that runs between the trailer frame. It has end plates which are bolted to the frame. It is mounted ahead of the bumper and the top of this U member is somewhat level with the bottom of the bumper. (The frame is deeper than the bumper) The receiver is welded into the U of this and runs under the bumper. There is a 8" wide metal plate welded to the top of the receiver that sits under the bumper. A 8" wide U shape strap fits over the bumper and is bolted down to the receiver plate with 4 - 1/4 bolts on each side. The trailer plug and chain hooks are also attached to this receiver plate.
While this works good for towing, I wouldn't want to mount anything heavy on it.
Old 08-30-2006, 03:14 AM   #11 (permalink)
You could try something like this: http://www.hitchesonline.com/rv_hitch.htm
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
V10 man is offline
Old 08-30-2006, 07:36 AM   #12 (permalink)
My bumper has a sticker on it that says:
"Direct and rotational load not to exceed 250 lbs"
So I would say NO
07HEMI4ME
Purchased a 2007 Dodge, ThunderRoad Edition, QC, 4x4, 5.7L HEMI on 11/30/07.
Traded in my Travel Trailer for it, so no need for a Diesel.
2003 EB Expedition 5.4L
2006 F350 Lariat, 6.0L PSD, Crew Cab, FX4, 4x4 PURCHASED BACK BY FORD! on 8/28/07.
07HEMI4ME is offline
Old 08-30-2006, 10:34 AM   #13 (permalink)
468LC's Avatar
Thanks to all the great ideas in here.
V10 man got me searching and found some other links.
My tentative plan is
build a new 4 inch tube bumper that is 3/16 wall thickness and cut it short like Uturn mentioned. Then weld on pieces of the old bumper to the ends so that the poop tube and end caps still work.
I will then add this piece to it and weld it on.
http://www.drophitch.com/index.asp?P...amp;ProdID=238
New bumper mounts will have to be fabricated as well.
Steve
468LC is offline
Old 08-30-2006, 12:24 PM   #14 (permalink)
I have Curt Hitch that bolts to my TT rear bumper, I put a rear carry rack in the hitch, I carry my generator, Gas Cans(2) and Ice chest. Total weight approx. 400lbs. I have don this for 4 years and about 15,000 miles of travel, no problems at all. My only warning is that the rear of a trailer bounces drasticly and anything that is on the back will have to straped down well.
My Truck - 1994 F-350 Crewcab 7.3 Factory Turbo
ATS upgraded Turbo Exhaust Housing, 3" Exhaust Outlet Housing and 3" downpipe, 3.5 the rest of the way back.
DPS Stage 1 Injectors
LGF Propane Injection
Pyro,Boost,water temp,trans temp gauges
K&N Filter
Wife's ride- Red, 2003 Excurision, Eddie Bauer, 6.0l 4x4, 63,000 Miles, Bone Stock
31' Salem LE Travel Trailer
My Pics
bsays is offline
Old 09-01-2006, 05:40 PM   #15 (permalink)
I Have seen were they install hitches and wiring from the factory on fifth wheel trailers, I pull a 28 ft Cardinal with a 20 ft trition bass boat behind that, have been all over the south, and as far west as New Mexico, with no problems. been all the way to the Hudson River in upstate New York also.
Just got to know what your limits are and make sure you keep your equiment checked and maintained
1999.5 F-350 SRW Crew-Cab
Bank Stinger Plus with Transcommand Chip Banks 3 gauge
Replace motor and tranny with 2002, motor and tranny 25,000 miles and running great and tranny
Moving Campers
justruck is offline
