T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run Define Union: A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
Re: Weight capacity of my 5er pooper tube bumper on a fleetwood?
T_Bone
You bring up a very valid point and that is something I would have to experiment with.
At this point I would like to make it work though, buying a TT or a toyhauler 5er is not really an option. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
468LC,
I had the same problem a couple of years ago, what you need to remember is the weight of the motorcycle is hanging off the bumper so it is actually increasing the load put on the bumper. What I did was bought a piece of 1/4" thick 4x4 square tube and welded it directly to the frame where I cut the old bumper off. Then I welded the receiver to the bumper with extra braces and gussets. You can still keep your sewer hose in the new bumper and the whole set-up is as strong as your frame. It worked great and looked factory....
1997 F-250 4X4 Powerstroke, ext cab, 3:55 gears, E4OD tranny, DiPricol gauges and 3 pillar pod,Tru-Cool 4739 Max trans cooler, 3" downpipe, dead kitty, Rotella Synthetic,Mobil-1 synthetic ATF,Warn manual lockouts, ..1995 29'Carri-Lite fifth wheel.
Like T-bone said, watch the weight on the back. A friend of my co-worker put a quad back there and it shifted too much weight behind the rear axle. He lost control and flipped the truck and trailer. Thankfully, everyone walked away.
2004 6.0 PSD CC Lariat FX4, Bulletproof Diesel EGR Cooler upgrade, Scangauge II, High Idle Mod, Tow Package, Air Lift Bags, 2006 Jayco Eagle 325BHS 5th Wheel
See my signature for a photo of what I tow.
Here is a link to the Hidden Hitch 82201 install I did. I added some .188 wall tubes under the frame and bolted the hitch to them. It gave me a nice drop too. My trailer sits high as it is. It weighs in around 11.5k and is about 32'-8" long. It has a looong rear overhang. There is some bounce associated with weight back there, but a 25' fifth wheel trailer shouldn't have a huge rear overhang. I only notice it when the jetski trailer (1200#) hits a bump. I can feel a slight nudge. It it were a TT, then the effect of the weight would be an issue.
2000 F350 XLT 4x4 CC LB SRW, PSD, 4R100, MSOF, 3.73 TrueTrac, OTC, wired keypad, AIC, DRL, Gauges, DP F6 Live Tuned, Ford AIS w/ sleeve & Zoodad, ATS housing, 31-row trans cooler, HPX line, Magnaflow & BrakeSmart.
