Can anyone advise me if either are any good? The reason I went to JC Whitney is because I have a 20% off coupon.
BudMan
BudMan5
"A couple of quarter sticks of dynamite can turn an otherwise dull day fun!"
2006 F350 Crew Cab 2WD DRW 98 gal Transfer Flow aux tank, Crew Cab Sleeper, Ride Rite Air Bags with Dual Air Command II compressor and tank, B&W Companion 5'er and Gooseneck, Garmin GPS, XM Radio
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: BudMan5</div><div class="ubbcode-body">I need to buy a weigfht distributing hitch for my factory Class 4-5 receiver.
BudMan </div></div>Why not buy a <u>True</u> Class 5 receiver like this Putnam XDR http://search.cartserver.com/search/sear...gl1790&GO=GO%21
Good for 15,000 pounds without WD set-up for $169 AND still uses a 2" ball mount. No drilling, uses existing factory holes. Installation time is 15 minutes.
I don't know about Curt. Hidden Hitch is made by Reese/Drawtite, and they make good stuff at competitive prices.
Generally, you get what you pay for.
So realize you're looking a "cheap" hitches. Reese, Drawtite, Putnam, EAZ-Lift, Curt, Hidden Hitch and others all make those cheap weight-distributing hitches in the $300 price class without sway controls. Add a coupla hundred dollars more for the optional sway controls and you're in the $500 price range. Reese and some of the others also make better hitches with sway controls that will run on up into the $1,000 price range.
The excellent weight-distributing hitches are much more expensive, closer to $3,000. But you'll have absolutely no sway with a Hennesy Arrow or PullRite hitch. Sway is the killer, and those less-expensive hitches simply don't give you the guarantee of no sway the way the expensive hitches do.
Personally, I would not want to drag a tag trailer that weighs more than about 5,000 pounds unless I could tow it with a Hensley Arrow or PullRite hitch. I've witnessed too many travel trailers upside down in the barrow ditch.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SmokeyWren</div><div class="ubbcode-body">I don't know about Curt. Hidden Hitch is made by Reese/Drawtite, and they make good stuff at competitive prices.
So realize you're looking a "cheap" hitches. Reese, Drawtite, Putnam, EZRide, Curt, Hidden Hitch and others all make those cheap weight-distributing hitches in the $300 price class without sway controls. Add a coupla hundred dollars more for the optional sway controls and you're in the $500 price range. Reese and some of the others also make better hitches with sway controls that will run on up into the $1,000 price range.
Personally, I would not want to drag a tag trailer that weighs more than about 5,000 pounds unless I could tow it with a Hensley Arrow or PullRite hitch. </div></div>
BudMan5
Smokey makes good points. I personally use a Reese/Drawtite hitch. I went this route because I much prefer the "round" bar style hitch simply because they're so easy to insert and remove. Just swing the bar around under the bumper and it will fall out. No need to mess with the "clip. I don't like the trunion styly hitches because of their cast iron construction. I actually saw the results of one "blowing apart" (cast iron is far more brittle than steel) probably from too much tension on the bars.
The other high dollar hitches like the Hennsley Arrow are nice, but It would be difficult justifying such an expense, especially in your line of work. I'd hate to have to move all that Hennsley stuff from trailer to trailer, that would be a huge PITA.
__________________ TurboDave, EWCS(SW)USN Ret H&N Turbo 6 Racing
Seviervile TN A MAN AND HIS TRUCK, IT'S A BEATUFUL THING 01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner) 86 GN (original owner) 87 GN (second owner) 08 Honda Accord EX-L
I choked on the price of the Hensley Arrow when I was looking into this last week; so just this afternoon UPS delivered the 12K lb -rated Equalizer that I purchased instead. Equalizer claims the hitch addresses both sway as well as weight distribution.
I have been absolutely happy with the way my 10,000 lb car-hauler 20' trailer has felt on several tens of thousands of miles of wretched roads so quite frankly I wonder if sway is more a function either of bad trailer design/construction, or more simply because a live-in trailer's high profile brings on sway through a combination of higher center of gravity and wind on its profile. So for me, the weight distributing feature of the hitch probably will remain more important than the anti-sway capability, at least for that trailer. My second trailer does present a high profile but I've not hauled much with it. My third trailer is the gooseneck, for which of course this hitch is not relevant.
Sold: 1999 White Lariat CC SB F-250. Sold to next-door neighbor in 2001....received final payment 2007! Still going strong at 198Kmiles as of Dec'07
Sold: 2001 Bright Amber Lariat CC LB F-250 with 4 million candlepower of LightForce lights in the bow. Line-X bedliner. Dual alternator. Clearance lights. Glass-tite cap. 250-gallon auxiliary tank for trips to the Lesser 48. 70-gallon auxiliary for trips around Alaska. Rec'd Dec'07: '08 ForestGreen/Gold F-350 CC LB. Handshaker, as always, Rear stabilizer, rear static video, rear step, dual alternators. B&W turnover ball on its way; soon to be Line-X'd. LightForces on their way.
I've used Reese WD hitches for years and years without a problem. My current trailer weighs about #4500 with just the tools & stuff in it and the gross is up to #12K depending what car/tractor/junk etc is inside. I've also had several flatbed bumper-pulls over the years using Reese equipment and NEVER had a sway problem. My current trailer has the optional anti-sway friction device that I quit using right after I bought the trailer because it's just not needed.
I'm sure the Hensley Arrow and Pullrite are fine products, but I can't see spending $3000 when the setup I have now is doing the job. A lot of sway problems are due to poor trailer design and engineering, too small/light tow vehicle, improper loading etc.
'06 Ram 3500 4X4 QC CTD 6sp LB
'01 F350 PSD 4X4 6sp Crew Cab (sold)
'68 F250 C/S 4X2 C6/428PI
Stidham 24' enclosed car hauler
Bunch of big old cars
In theory, practice and theory are the same.
In practice, they are not.
I have the Reese with 1,000lb bars and sway control. The WD and bars was 360 bucks and sway was 120 bucks. Mine is a 61009 here is a good exploded pic. I love it I have pulled 12K enclosed with no problems and good solid control. http://www.reese-hitches.com/products/Re...Hitch_Bar,61009
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Way too many people think that a "true class 5" enables you to forget about needing equalisers because of "added strength" of the hitch. The static forces downward of a typical 10000 pound trailer ,if setup correctly,should be 1000 pounds 10 %. During hard braking,the trailer brakes cause a huge amout of trailer nosediving weight onto the ball. The net result, on a typical 3/4 ton to one ton truck is a resulting 25 to 40 percenct lifting force at the nose of the truck. Severe braking on a turn could be disastrous without equalisers.(when you need more steering traction....you get less).
Trailer brakes cause nose-diving weight onto the ball and 40% lift? Although I’ve never heard of such a formula, I guess you learn something new everyday but, 10,000 lbs has no business behind a ¾ ton truck in the first place and I’ve never experienced this phenomenon you speak of with up to 12,000 lbs behind a DRW 1-ton.
I have experienced a bit of sway in heavy braking on a curve, but nothing that was not under control. However, I’ll have to agree with Packard, “A lot of sway problems are due to poor trailer design and engineering, too small/light tow vehicle, improper loading etc.” and I can see how one would benefit from using a WD to aid in control in high crosswind conditions.
I only suggested that Budman5 equip his ride with a hitch to match the capacity of the truck.
Its rather easy to determine what the lifting ratio is on any given vehicle. To use the details of my F250 (rated as configured for 12,500 lbs) is as follows. The wheelbase is 141 inches. The distance from the ball to the approximate center of the axle is 55 inches. This is a simple lever. Every pound of downward force will result in a lifting force at the front wheels of 39 percent.
Nosediving forces would be much more complicated to calculate. If you should try braking with trailer brakes alone,its pretty easy to get a feel for how much force is nosediving onto the trailer hitch.
Vehicles with brakes...even trailers, nosedive when you apply the brakes.
My larger rental travel trailers go out with either a 10K Equalizer or a 12K Equalizer for the toy hauler. Nobody has every said anything about sway or weight distributing problems.
__________________ 2004 EB X 6.0 2WD, everything except 2nd row caps and 4WD, 6" Pro Comp, Hellwig rear sway bar, 285-65/20 BFG KO, Air Raid intake in factory box, MBRP cat back 4", 30% tint, color match splash guards, Prodigy, Sirius
Youre looking for a good WD hitch to haul all them towable RV's around to dealers. You need to find a good WD hitch. Everyone has their own expirience and opinion on what to best use. You have a big enough rig to haul just about any length tow behind TT. I dont think Ive ever seen one weigh over 12000 lbd up to 35 ft. Most are less than 10000 lbs you commonly see out there on the road. A good Reese or Drawtite will do. I also even though I pull my 33ftr (9000lbs) with a dually I also installed a dual cam sway control sway bar to my rig which I like real well. You just barely feel the vaccum of a big rig when they pass you and it is a self centering sway bar that will keep your rig and trailer straight with each other. It serves as a WD hitch and sway bar....Its really neat. I bought it after my accident. My brother was all over me for not having one. The reason I like it so well is that when you happen to have to swerve your rig to avoid something on the road the TT will stay right with you and not fish tail....
Here is the link or address for the dual cam sway bar http://www.pplmotorhomes.com/parts/r...ay-control.htm
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: mrnecsteve</div><div class="ubbcode-body">Its rather easy to determine what the lifting ratio is on any given vehicle. To use the details of my F250 (rated as configured for 12,500 lbs) is as follows. The wheelbase is 141 inches. The distance from the ball to the approximate center of the axle is 55 inches. This is a simple lever. Every pound of downward force will result in a lifting force at the front wheels of 39 percent.
Vehicles with brakes...even trailers, nosedive when you apply the brakes. </div></div>I have noticed more of a nose-dive on the F350 but not as much with torsion bar suspension. With the mass of the towing vehicle thrust forward in braking, would this not offset the feel of any additional downward force to the rear from a braking trailer?
