Old 05-04-2005, 06:20 PM   #1 (permalink)
Weighted the F-350 today...Wow
Well I finally got around to weighing the new ride. I was quite surprised, with full fuel and me in the seat (178) scale says 8000#. Does this seem about average? By the time I add the family I'll be at 8600# without hitch weight. We just ordered a WW LE 3705 and factory says build weight is 10,100# with a gross of 15k. I have approx. 3600# of toys and stuff and I haven't even figured in pin weight, fuel and water. Seems like I am running out of truck very quickly. I will have to travel to the dunes without water and fuel, have to fill up in Yuma. I think I will be over the 23K gross and probably over on the rear gawr of 7000#. I am going to have to get creative with the load. Cliff
2005 F-350 Lariat, SRW, FX4, LB, 4x4, 6.0L PSD, TorqShift, Tow Command, Luxury Package, Camper Package, Inyati Liner, Autometer Guages (3), Banks Monster Exhaust, Trans Cooler w/ Electric Fan, Pullrite 20.5 5th Hitch, God Bless America, Semper Fi
tacobuilder24 is offline
Old 05-04-2005, 06:36 PM   #2 (permalink)
Send a message via ICQ to MudHog
Re: Weighted the F-350 today...Wow
Here's my scale ticket weight
I weighed in at 7660 lbs. with me in the driver seat (160 lbs.)
'03 F150 Supercrew FX4. Little 1/2ton that gets 15 MPG on 23 gallons.
'06 F250 FX4 CC SWB
MudHog is offline
Old 05-04-2005, 08:05 PM   #3 (permalink)
My F-350 in my sig weighed 8040# with 2 fatboys in the front seats.
I gross just under 23,000# with the 5ver.
Capt Ron
May 2003 F-350, CC, DRW, 6.0L, 6sp man, LB, Al Wheels, Moon Roof, 52gal tranfer tank. Hitches: Draw-Tite 16K 4X and B&W GN, 8040lbs GVW. Towing 35' Newmar Kountry Star 5th Wheel Camper, 14,000lbs GVW, or Wells Cargo 24' Car Hauler, 12,000lbs GVW.
CaptRon is offline
Old 05-04-2005, 10:27 PM   #4 (permalink)
wheelbase's Avatar
I have a F-350 4X4 SuperCrew LB full tank and it weighted in @ 8100.
Front axle was 4740 lb and the rear was 3360 lb. I was outside when I hit the 8 foot semi-truck call button. Oh yeah, my dog (100 lb) was in the truck. Also, had my weight distribtuion hitch on.
8100 minus 100 minus the hitch 50? for an estimate of 7950 lbs.
You just gotta love this website. My wife does. Yeah, right!
2005 F350 Superduty 6.0L CrewCab LB 4x4 Black Lariat Loaded w/ S&B Cold Air Intake / 2008 Telescoping Mirrors / Recon Cab Lights & Side Markers / Toyo Open Country A/Ts / Bilstein Shocks / Cab off repair replaced every gasket in engine after buyback process ended with a nice big check from Ford (Oil Leaks) / Run Rotella T 15W 40 / Stanadyne Performance Formula in every tank
2005 Denali (Dutchmen) Travel Trailer 29RK-DSL
2003 Black Lab (Magnum) 105 LBs and runs on Pro-Plan
wheelbase is offline
Old 05-04-2005, 11:45 PM   #5 (permalink)
the 10,100lb. figure you posted is VERY optimistic for the 37' LE. i would suspect that once you have all the options in the coach (that is where the "dry" weight is misleading, as it is weight of the unit withOUT any options -- ie. AC, genny, etc.), that you will be closer to 12k. put in a few toys, water, fuel, food, clothes, etc. and i think you will be pushing 15k easy.
i have the LE3505, and i know that i am very, very, very close to maximum weight without adding much stuff...
ps. i would suggest that since you are running heavy, that you ditch the 15" wheels that come with the trailer, and move up to 16" rims so that you can get some E rated tires...
2003 Ford F350 Crew Cab Long Bed 4x4, 6" Edge all spring lift with Adjustable Panrod Bar and Dual Steering Stabilizers, 37" BFG Mud Terrains, 4.56 Richmond Gears, DPPI Turbo Back Dual Exhaust, Autometer C2 Gauges on A Pillar, aFe Proguard 7 Intake, Reese Titan V Hitch, B&W Turnover Hitch, BrakeSmart controller, ORU Air Overload System
My truck pictures
double is offline
Old 05-05-2005, 05:27 AM   #6 (permalink)
Tacobuilder, OT but who in town did your Inyati Liner? Would you recomend them again? Bout how much was it? Thanks.
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
V10 man is offline
Old 05-05-2005, 06:32 AM   #7 (permalink)
Not much difference for a F250. Front 4240 rear 3200 total 7460 with me onboard.
05 F-250 Lariat SC LB 6.0 4X2
Camper Package
Upfitter Switches
A.R.E "Z" Shell
Lakota 29FKS (30' & 10,000 lbs)
subdriver is offline
Old 05-05-2005, 09:04 AM   #8 (permalink)
Mine tipped the scales at #8,200 and me OUT of the cab.. You are looking at quite a load there. IMHO, I think it would be a lot better if your truck was a DRW..
Best to you.
'04 F-350 DRW, 3.73 gears, LB, CC, 4x4 6.0 TS Lariat w/moonroof, shiny black and all stock except for ISSPRO trans and EGT gauges in cubby mount.
2006 Cherokee Lite 285B+S 5er
2005 HD Ultra Classic, Smokey Gold/black
2007 HD FXD Super Glide, Red
LeeChristianson is offline
Old 05-05-2005, 11:00 AM   #9 (permalink)
Weight sounds about right..With my wife and I and 80 gallons of fuel on board mine weighs in at 9000...5 on the front and 4 on the rear...with the 37' 5r i'm right at 23000 GCWR....
1997 F-350 Crew Cab 4X4 DRW 215,000 Miles 4:10 gears,Ford AIC,Shimmed Fuel Regulator, Missing Kitty, Tymar Intake,3"-4" Downpipe,Pre Turbo Autometer Pyro,Trans Temp guage, Hypermax Intercooler with H2E turbo,2002 HPOP,4" Exhaust, Tru-cool 4590, EBPV Removed, CCV Mod,BDP Tranny Savers(130's), 4 Pos.chip, BTS Tranny
TerryCapurso is offline
Old 05-05-2005, 01:10 PM   #10 (permalink)
8400# for my truck with full tank, running boards, fiver hitch, no people, etc. I also have the Inyati. Very happy so far and the install was very well done. I believe all the Inyati shops in Phoenix are owned by the same guy. I had mine done up at the Deer Valley location as it was the closest.
2005 F350 CC Dually 4X4 Toreador Red/AZ Beige with Lariat Luxury
TheSequel is offline
Old 05-05-2005, 04:48 PM   #11 (permalink)
V10man
The dealer installed my Inyati liner, part of the deal. However, Custom Bumper in downtown Mesa on Main St. is a Inyati dealer. Cliff
Old 05-05-2005, 11:14 PM   #12 (permalink)
lincster's Avatar
My Photos: (22)
I had my Inyati sprayed by a place on Country Club and Elliot. They are who Earnhardts in the East Valley uses.
Seems the 05's are quite a bit heavier. Anyone know why?
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... man does this thing tow, Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
lincster is offline
Old 05-07-2005, 10:54 AM   #13 (permalink)
I think they're using a stronger/thicker frame. [img]/ubbthreads/images/graemlins/confused.gif[/img]
2003 6.0L F250 XLT S-Cab 4x4 FX4 White/Black
my97TJ is offline
Old 05-08-2005, 12:04 AM   #14 (permalink)
My scale slip says my 00 is 140# heavier than my 05, but the 00 is a
6 spd handshaker. Not sure what it all means but i think thier both close to the same weight
Y2K,F350,DRW,CC,6-spd,3.73,4x4,LariatDI4 pos,homemadeTymar,
Autometer boost & EGT,CCV bipass,DIY Xbrake,HXmod,PS2000,WalkerBTM,LUK clutch,
IH Jasper reman.w/forged rods,ATScomp.shroud W/W
Psycho Pump on order, or maybe not
New 05 is here, and im luvin it!
05 F350,DRW,CC,FX4,Lariat,4:10 gears,Torqueshift,4x4,
AutoMeter Cobalts,pyro/trans above the r/v mirror
popup g/n hitch,CCV reroute,MotorGuard M30 bypass filter,Muffler delete,Sirius,
Not a single engine perf. mod,i dont think it needs any!
jombi1 is offline
Old 05-08-2005, 09:57 AM   #15 (permalink)
Tacobuilder, add firestone air bags. They make a huge difference with that pin weight you're gonna have. Will ride like a dream!
'03 F250 CC 4x4 PSD 7.3L Auto
AFE Stage 2 Proguard/Zoodad
4" exhaust
Isspro 3 guage pillar
boost relief
AIH delete
DI 6 Position
ATS Housing
firestone air bags
coolant, trans, oil bypass
transgo shift kit
royal purple front to back
Tru-Cool Max
Home away from home: '02 Montana 3295RK
fisher4206 is offline
