Old 11-26-2006, 09:26 AM   #1 (permalink)
What is the difference between an exhaust brake and a engine brake?
If you can read this, thank a teacher, THANK A VET. it's in English: 04/04 F350 6.0 PSD Lariat CC 4X4 LB SRW Auto 3.73 rear end. All options except:moon roof-PTO-roof lights. Mods... MBRP,Line-x, White nite, Windows double tinted, 3 DVD system, Highway products 5er box, Pro-comp leveling kit, Pro-comp wheels/tires, MX-6 shocks,Viper 791XV remote start security system,Line of fire,Fumoto oil drain plug,Alaska tent and tarp bug screen,Rapid hitch drop hitch,Cobra 29 CB, Norcal Powerstrokes Member #5 http://www.norcalpowerstrokes.com/Events.html
SAVAGESAM is offline
Old 11-26-2006, 09:55 AM   #2 (permalink)
olddieseldude's Avatar
My Photos: (15)
Re: What is the difference between an exhaust brake and a engine brake?
Engine/Compression Brake...
Exhaust Brake...
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline
Old 11-26-2006, 10:22 AM   #3 (permalink)
My Photos: (9)
An exhaust brake is a simple butterfly in the exhaust pipe that restricts exhaust flow to cause braking.
An engine brake (Jake brake) changes exhaust valve timing to match that of the injectors so that when the piston is at the top of the compression stroke, the exhaust valve(s) open and blow down the pressure that would have otherwise sprung the piston back down on the return stroke.
There are some new engine brakes by Mercedes and International that hold a valve open through the entire cycle of the engine and make less noise but supposably the same retarding force as a Jake style brake.
Anyway the engine brake (Jake style) works much better than the exhaust brake.
However it cannot be used for engines like ours because the brake taking the load off the exhaust side lifters when it lifts the exhaust valves out of time with the camshaft will cause the lifters to pump up and possibly the pistons to hit the valves.
Birken
Birken Vogt is offline
