Old 09-01-2006, 03:46 PM   #1 (permalink)
My Photos: (63)
What have you done to combat drag on your gn/5th wheel trailer???
My goose neck horse trailer is really causing a lot of drag and so much wind disturbance that heavy objects are being blown out of my bed at interstate speeds. What sort of things have you all done to combat this?? Thanks, Phillip
My truck pictures
1995 CC DRW XLT, Converted to 4x4 with D60 front, Alcoa Classics, ZF5, Big bumpers, gooseneck hitch, Cobra 148, SuperDuty electric fuel pump, Aeromotive fuel pressure regulator, Davco/Detroit Diesel fuel filter assembly with twin 10 micron Cummins OTR style filters, Stanadyne Fuel heater, Tymar intake, Isspro EV Pyro and boost gauges, Autometer pod, Ford AIC, Techonsha Hydraulic brake control, TS 6position chip, JD coolant eye, 4" DP with 5" Auto-Jet muffler and exhaust out the back, SWAMPED.
1993 Shoop Gooseneck, Steel/Aluminum, 4 Horse Head-to-Head
2001 Land Rover Discovery SE
KentuckyDiesel is offline
Old 09-01-2006, 05:55 PM   #2 (permalink)
Re: What have you done to combat drag on your gn/5th wheel trailer???
<font color="green">Back when I had trucks with factory beds, I found the best way to handle the turbulence was to not have anything in the truck bed.
I don't have the problem with the flat-beds.
As far as overcoming the drag, the Cummins took care of that. </font>
1985 F-350
5.9 CUMMINS TURBO DIESEL
G360 GETRAG 5-sp
3:55 DANA 70
LongRider is offline
Old 09-01-2006, 08:06 PM   #3 (permalink)
My Photos: (63)
I can't feel the drag, I just know it's there because things are being pitched right over the side of the bed....that and my mileage is down. [img]/ubbthreads/images/graemlins/frown.gif[/img]
-phillip
My truck pictures
Old 09-02-2006, 10:45 AM   #4 (permalink)
i have 2 large trailers.....the trailswest has a really great aerodynamic front and pulls like a dream [about 10,000lbs gross loaded],then i have a custom ordered goosenek brand goosenek that has a large square front[for snoozin in !]and its like night and day it is so draggy and its not near as heavy as the trailswest.there is such a difference that i am seriously looking at having built or buying a aerodynamic front to rivit onto the blunt end.
built 7/98 reg cab,4x4,tymar,203*Therm. and evans coolant,50/100 superchip,4" BD pipes,alum.diff.cover,B&W 9ft flatbed with 50 gal aux tank,riderites.
707727747 is offline
Old 09-02-2006, 10:58 AM   #5 (permalink)
<font color="green">CANAM, what type trailers are the two you mention??
One thing that must be taken into consideration, when discussing drag, is that exterior framed trailers, such as the Gooseneck brand, have a million little wind catchers down their sides that, all added together, amount to a considerable drag.
Also, brush-fender trailers, that terminate in a solid rear plate(where the tail-lights are), catch a lot of wind. </font>
1985 F-350
G360 GETRAG 5-sp
3:55 DANA 70
Old 09-02-2006, 03:56 PM   #6 (permalink)
your right...i hadn't considered all the other wind catchers on the goosenek brand and the general unaerodynamicness of an open stock trailer but smoothing the blunt front end i'm sure would help...its right up there in the airstream....like a 6ft x 2ft wall.
Old 09-02-2006, 05:38 PM   #7 (permalink)
Cool_Canuck's Avatar
My Photos: (12)
The majority of drag comes from the back of the trailer. Making the front end pointy doesn't help that much. Look at aircraft. They can be very blunt up front but the backends always taper off.
Here is most of what you need to know on getting your 7.3L started and how to operate it in the cold winter months. These posts use to readily available, but they've been hid in a subforum top of the 7.3 Power Stroke Engine and Drivetrain forum.
Winter Operation (How I Do It)
Hard/No Start? Check here first
2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Cool_Canuck is offline
Old 09-03-2006, 09:34 AM   #8 (permalink)
hauling stock over the years [on dirt roads] i have found trailers that have almost solid sides and are 50% open at the back end suck in dust so bad that it blankets the animals,but open sides and back on a trailer creates no "vacuum" back of the front end....in still conditions i can lay a plume of dust a mile long and the animals are as clean as a whistle.BUT...i suppose there is still drag created...i still think if i could fair the front end [cheaply]it would be worth trying.
Old 09-03-2006, 01:03 PM   #9 (permalink)
You want some drag, back a 2030 JD with a 6ft round bale over the nose of a flat bed and see what happens. I thought the brakes were on when I tried to get over 45MPH. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Partsman is offline
Old 09-04-2006, 08:30 AM   #10 (permalink)
roger that partsman [img]/ubbthreads/images/graemlins/biggrin.gif[/img],back of that truck must have looked like a dog squattin to pee [img]/ubbthreads/images/graemlins/grin.gif[/img].
Old 04-02-2007, 11:44 PM   #11 (permalink)
My Photos: (6)
web page
You could be the first at your next roping to show up with these! [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
99.5 F-250 CC LB 4x4 7.3 Red, Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, Bilstien Shocks, Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, BFG AT/KO 285/75x16, Magnaflow 3.5" DP - 4" Exhaust, 2003 Cup Holder, X-Springs, Rear 4" F350 Blocks, ATS Housing, Edge Evolution (Rev. 19), Banks Big Head, DS Boost Relief, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, Sonnax/Tricum
NRA
Ducks Unlimited
My Truck Pics
Flywheel is offline
Old 04-03-2007, 01:21 AM   #12 (permalink)
Slow down.
DENNY
1999 F350 CC SRW LB 4X4 SIX SPEED.
DENNY is offline
Old 04-03-2007, 08:15 AM   #13 (permalink)
My Photos: (27)
I bought a V-nose [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. All kidding aside, V-nose or not, you will always get some weird wind turbulance in the bed with a gooseneck hooked up. Before I bought mine, guys told me fairly heavy stuff that you'd bet would NEVER blow out sure will. They were right.
Canam, couldn't agree more. My fully loaded V-nose 3-horse (7000 lbs.+-) pulls pretty much the same as my fairly square front end 23' gooseneck travel trailer (5000 lbs.+-)
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 04-03-2007, 10:04 PM   #14 (permalink)
My Photos: (6)
I put a wing on the truck to cut down on drag or the RV.
Worked great!
Worked even better for removing ANYTHING from the bed.
2007 CC LWB Lariat, 6" Fabtech,dual Bilstein w/res front, Bilstein rear,dual stabilizers,35"BFG M/T
2001 CC LWB Superduty 4" lift,35" BFG M/T,Bilstiens,Tymar,SuperDuty Air Bags,4" Exh,CCV mod,DP Tuner 6 position chip,Snows Water/Meth Injection,BD exh brake,BD Torqloc,Autometer Phantoms in pillar,Wicked Wheel,PML trans/diff covers,fumoto valve,Suncoast trans/triple lock,12,000# Warn,Alpine,Sony,))XM((,dual Optimas on passenger tray...(spare CPS in the glovebox)
Intercooler wrap removed/painted
My Pics
genesiscom is offline
