What is my Max 5th wheel pin weight? - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 02-10-2008, 04:25 PM Thread Starter
We want to move up from a TT to a 5th wheel, so this week I purchased the following:
F350, CC, PSD, 4X4, LWB Dulley w/ 4:10 gears.
What is my Max Pin Weight?
Could you suggest some models of 5th wheels to search?
2006 Lariat Chrome Edtion Red F350 CC 4X4 Dually w/4:10 Gears Born 04/26/06 w/ color matching speedliner, PCM Reprogramed to Level "L",@ 24,535 miles AMSOIL Front to Back, AMSOIL By Pass Filter BMK-11, Amsoil Coolant Nitrogen in all 6 tires @ 75 PSI W/ 34.2 x 102" wide Coachman Royal TT.
Gone but not forgotten 2001 X 7 years / 218K w7.3
Ken1 is offline
post #2 of 19 (permalink) Old 02-10-2008, 04:44 PM
Load up you and your wife and go fuel up. Then go to a scale (about $7). Look at the GVWR on the door jamb and take the difference. That's your pin weight. Every time you add something to the truck (tool box, junk, options) go do it again.
Can't help on the fifth wheel. We're looking for one ourselves.
JC
F-450, 4wd, club cab, 4.88, KR, satellite, navigation, hi-capacity trailer towing, reverse sensor, memory mirrors/pedals/seats and tailgate step. Also Linex, TruckCoverUSA bed cover, CrimeStopper Remote Start and Alarm and a 25K Air Safe Air Ride 5er hitch. Also Banks with IQ.
Jerryc is offline
post #3 of 19 (permalink) Old 02-10-2008, 05:09 PM
MDarrough's Avatar
My Photos: (18)
I can highly recommend the Jayco Eagle series. I did a lot of searching and researching before I bought mine and found the Eagle to have the most bang for the buck. There are a lot nicer units out there but some are quite expensive. I finally decided on the Eagle 291RLTS. It is 35 ft long and has a pin wieght of 2400 and my 350 SRW handles it great.
Jayco 2008
Good luck,
Mark
2011 F-350 DRW 4X4 Lariat -
Pulling a 2010 Sierra 355QBQ 5er
Sold- '08 F-350 -
Sold - '01 F-350 -
MDarrough is offline
post #4 of 19 (permalink) Old 02-10-2008, 05:43 PM Thread Starter
Thanks for the replies
Ken
Ken1 is offline
post #5 of 19 (permalink) Old 02-10-2008, 08:07 PM
jhamlin164's Avatar
The Montana 5th Wheels Are Very Nice............
I think that based on your truck's configuration, the heaviest 5th wheel that you can safely tow is 15,600 lbs. The GVWR of any 5th wheel that you get can be no more than 15.6k. The pin weight of such a trailer is about 15-25% of the trailers' total weight......................err on the high side and say 25% of 15,600 or 3,900 lbs. The payload of the truck is around 5,200 lbs, give or take. Now the kicker is----------you, your wife, tool boxes, gear, fuel, and any other junk counts against that 5,200 lbs as does the pin weight of your trailer. When you take the truck/5th wheel combo to be weighed, you wanna be sure that it is within both axle weight ratings for your truck, or 6k and 9k, respectively.
I can say this much to you........................get you a 5th wheel that has a GVWR of 14,500 lbs or less and your truck will pull it beautifully, pull it safely, stop it safely, and give you a wonderful little cushion to play with.
Hope that helps you a little more,
Jerry
2006 F-350, King Ranch, 6.0L PSD CC, DRW, 4X4
Kenwood Head Unit / Navigation system
Clarion LCD DVD player
Rancho RSX 9000 shocks
Line-X Bedliner
JL Audio ZR-570CSi speaker system
JL Audio StealthBox Sub
2 JL Audio Amps
2 Odyssey PC 1500DT batteries
DC Power 275-SP High-Output Alternator
Amsoil By-Pass system
Ford OEM Head gaskets
ARP Head Studs
Sinister Diesel Coolant Filtration system
Bullet-proof EGR Cooler
Blue Spring upgrade
Updated STC Fitting
Edge Insight CTS (monitoring only)
Big Three Wiring Upgrade
jhamlin164 is offline
post #6 of 19 (permalink) Old 02-10-2008, 11:41 PM
SmokeyWren's Avatar
My Photos: (45)
... this week I purchased the following:
Year matters. But assuming it is the 2006 in your sig, then your GCWR is 23,500 pounds and your GVWR is 13,000 pounds.
Your wet and loaded tow vehicle should weigh about 9,000 pounds unless you haul gobs of tools and junk in the pickup toolbox. So that leaves about 4,000 pounds for pin weight without exceeding the GVWR.
And a GCWR of 23,500 minus 9,000 for the tow vehicle leaves 14,500 pounds as the max weight of the trailer without exceeding the GCWR of the tow vehicle.
To verify those numbers, you need to load the tow vehicle up with mama and the kiddos, go to a truckstop and fill up with diesel. then weigh the wet and loaded tow vehicle. If it doesn't weigh about 9,000 pounds, then adjust all the numbers above accordingly. For example, if your wet and loaded tow vehicle grosses 10,000 pounds (and some do!) then the max trailer weight falls to 13,500.
A 5er that grosses 14,500 will probably have about 18 to 20 percent pin weight. But even it it's more, that's a lot less than 4,000 pounds. So gross trailer weight - not pin weight - is your limiter.
Don't try to guess how much junk your sweetheart will haul in the trailer. Instead, go by the GVWR of the trailer. Don't even consider any trailer with a GVWR of more than 14,500 pounds.
Some RVs don't mention GVWR. Instead the specs include dry weight and max cargo weight. Add those two together and that's the GVWR of the trailer.
SmokeyWren is offline
post #7 of 19 (permalink) Old 02-11-2008, 04:09 AM Thread Starter
Thanks to all for the replies. When you ask a question on this forum I become amazed at the quality of information and support from the memebers
Ken1 is offline
post #8 of 19 (permalink) Old 02-11-2008, 08:06 PM
The other item to check out is what limits may exist on your drivers licence. In most states, if your trailer axle weight (the towing weight) exceeds 10,400 lbs, you may need a licence upgrade. In some states that can be a real pain as the only alternative they offer may be a commercial licence (CDL). So check your DMV.
MY "Rule of thumb"... if the trailer GVWR is under 12,500 then the axle weight will be low enough that you should be ok. If the GVWR is over 13,000 lbs then the axle weight almost certainly will be over 10,400 and you will need a licence upgrade. If your trailer GVWR is over 12,000. then get it weighed to be sure.
John
99 F350 PSD CC DRW, BD Tranny, Fan driven tranny cooler, exhaust brake, tranny temp gauge
Titanium 29/34 Fifthwheel
HiJack 21k 4way hitch
hiljoball is offline
post #9 of 19 (permalink) Old 02-11-2008, 08:34 PM
I think most states exempt recreational vehicles although I have no idea why.
JC
Jerryc is offline
post #10 of 19 (permalink) Old 02-12-2008, 05:13 PM
JC
If you check with your DMV, I think that you will find that this is not correct.
John
post #11 of 19 (permalink) Old 02-13-2008, 10:52 AM
MDarrough's Avatar
My Photos: (18)
Here's what the Texas DPS sais about this.
See page 2 in the link.
Part 383 - Commercial Driver License
Mark
Sold- '08 F-350 -
Sold - '01 F-350 -
post #12 of 19 (permalink) Old 02-13-2008, 12:11 PM
Hook'em Horns!'s Avatar
Send a message via Yahoo to Hook'em Horns! Send a message via Skype™ to Hook'em Horns!
Mark
Of course the TX Commercial Driver's Handbook actually states:
'A recreational vehicle that is driven for personal use.'
Which conflicts with:
'Persons operating recreational vehicles for personal use.'
as stated in the txdps publications referenced above. Oh, well...
2007 Chev Duramax LBZ/6-spd Allison 3500 LT3 DRW CCLB, Sulastics, Putnam XDR 15K, B&W 30K-Turnover GN, Ride-Rite Air, Roll-Top Cover
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab 9'Flat-GN
A/T Revos
Use-ta-Haves
2005 Chev Duramax/Allison 3500LS DRW CCLB
2002 Chev Duramax/Allison 3500LS DRW CCLB
DON'T STEAL! The Government Hates Competition
Hook'em Horns! is offline
post #13 of 19 (permalink) Old 02-13-2008, 06:20 PM
To investigate what your licence allows, I suggest that you start by looking at the standard DL. If you start looking at CDL you will find all kinds of confusion as applied to recreational vehicles.
For example, If you have a Texas DL, do you have a Class A, B or C licence? CLass C is the 'normal' DL
The class C is limited to GCWR under 26001 lbs and trailer not exceeding 10,000 gross weight.
Class A & B allow heavier GVWR and over 10,000 trailer weight.
Source is Texas DRIVERS HANDBOOK Pages 1-4 and 1-5
It may be different for your state, and the licence names may be different, but the example is typical.
John
post #14 of 19 (permalink) Old 02-17-2008, 10:39 PM
Let me see if I can get this straight, What you are saying here is he can tow up to 14,500 Lbs.ACTUAL weight ????, if he goes to a scale and weighs that trailer and it weighs 14,500 or less everything is good ???? if that is what you are saying, then what is GVWR, ???? if a trailer actually weighs 12,000 Lbs. with a GVWR of 15,500 Lbs. What if you are pulling around a trailer dry that weighs an actual 12,000 Lbs.with a sticker that has 15,500 lbs. GVWR, are you legally over the rated weigh of 14,500. I guess what I am asking is what the heck can the truck in question tow in real live lbs.,and also who cares about the GVWR of a trailer other than the total that trailer can handle, correct me if I am wrong 12,000 lb. trailer 15,500 GVWR, you can add up to 3,500 lbs. to the trailer, Please set me straight. Thanks
up2nogood is offline
post #15 of 19 (permalink) Old 02-17-2008, 11:43 PM
Bill1013's Avatar
Fifth Wheel Weight Calculator
You might be interested in this.
Bill
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
