Old 11-27-2006, 09:27 PM   #1 (permalink)
What not to do with your Ford!!
I thought you guys would appreciate this:
http://video.google.ca/videoplay?doc...91&q=dozer
[img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford06 is offline
Old 11-27-2006, 10:11 PM   #2 (permalink)
Re: What not to do with your Ford!!
HAHA that was great [img]/ubbthreads/images/graemlins/biggrin.gif[/img] I bet that was one hell of a load! [img]/ubbthreads/images/graemlins/phoney.gif[/img]
My Trucks,
1999 Dodge 2500... 438HP, I just got a superchip...
1997 F250 ext cab 7.3, 5spd, 4x4, with some modifications (Sold)
2007 Q&S Gooseneck, 25+5 with tandem duals.
1966 Mustang coupe, (Sold)
1984 Chevy K10, Built motor, lift, all the good stuff. (Sold)
1997 F150 XLT ext cab, sb. (Sold)
http://community.webshots.com/user/pogrelis97
Myspace: http://profile.myspace.com/index.cfm...ndid=103875904
Ben97 is offline
Old 11-27-2006, 10:17 PM   #3 (permalink)
Re: What not to do with your Fprd!!
Looks like the hitch broke. I have rear (blocks) to avoid damage to truck when loading tractors/heavy stuff. (trailer came with them) Still 17 ton (IIRC) is more then I would consider of cargo. (esp with 10 ton trailer)
I forgot rear stands once and loaded 110hp tractor and it dang near lifted rear of pickup in air.
larry_minn is offline
Old 11-28-2006, 08:07 AM   #4 (permalink)
that was brilliant
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
NickKent is offline
Old 11-28-2006, 09:45 AM   #5 (permalink)
MarkEkberg's Avatar
My Photos: (13)
The hitch didn't break. The trailer popped off the ball or the pintle was not locked down.
No biggie. We have had that happen to us at our marina once or twice.
We also have had our hitch break off with our hydraulic trailer. Hitch looked like it had a crack for a long time. Broke right off going down the road, trailer dug right into the pavement and came to a abrupt hault in the middle of the road. Thankfully no boat on.
MarkEkberg is offline
Old 11-28-2006, 09:54 AM   #6 (permalink)
Just a good thing he didn't have his tail gate down!
Bet he does that all the time wanted to show a friend to two with GM's or Dodge's that it can be done.
Had the dump trailer come off the ball this Summer getting onto I94. Last time somebody but me hooks it up.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 11-28-2006, 12:38 PM   #7 (permalink)
NO biggie! In april, I bought a forklift that was supposed to be 14K, ended up, loaded on the trailer pulled with my 2001 F250 I grossed at 44,000 lbs. The only thing the guy at the scale asked was what kind of motor you got in that thing? Only a FORD would have hauled it!!!
2001 F250 SD PSD, , 6 Speed, bought used in April 2004, 73000 miles. Bully Dog 50,75,100 chip, Bully Dog Pillar Mounted Boost and Pyro Guages, 4" exhaust, Homemade open air "Tymar" type filter, American Racing Wheels, Bilstein Shocks, Spal aftermarket electric windows, Commando Power Door Locks and Alarm System
thebaldeagle is offline
Old 11-28-2006, 01:59 PM   #8 (permalink)
lone_star_dsl's Avatar
How do you know?
2002 F-350 Lariat, Crew Cab, Long Bed, SRW, 4X4, Auto trans, Blue IH CPS, Tymar intake, Wicked Wheel, Zoodad Mod, Intercooler wrap removal, 4" straight pipe exhaust, 2" leveling kit, ISSPRO gauges, Acetone Badges, XM radio, Cobra CB, DVD, 315 Dick Cepeks,
CHROME EVERYTHING!!
106,000 mostly trouble free miles and counting!
On the wish list:
ATS Housing
Stacks
http://community.webshots.com/user/tward93
www.wardandcompanyonline.com
lone_star_dsl is offline
Old 11-28-2006, 07:34 PM   #9 (permalink)
I'd have to agree. I wouldn't think the weight of the truck would break the hitch. I bet the ball either popped off, or the pintle lock pin sheared off.
NickKent is offline
Old 11-28-2006, 07:57 PM   #10 (permalink)
That's great. Reminds me of trying to load a bobcat on a trailer... without the truck. Oh, and to make things more fun, a 3" jump from ground to ramp. It took me 10 minutes of chasing that trailer all over creation with the bobcat, but I did get it loaded. That was the last time they (rental company) insisted that we reload something without the truck that they unloaded with a truck. No, I didn't break or bend anything. The boss reamed them a new one when they came to pick it up. Picture it in your mind... Bobcat pulling wheelies to get the front tires on the trailer, without hitting the end of the trailer on the underside of the bobcat(which send the trailer rolling). Then running forward onto the trailer so it doesn't fly out from underneath, but no so fast as to overshoot the front end. Oh, and by the way, try to get it to stop really close to the axle so it doesn't slam down on the jack. On a nice smooth wood deck.
Oh, what fun!
'96 F250 XLT, PSD, 4x4, ExtCab, LB, Auto, 3.55.
11-06: DIY Open Element, EBPV & TC exhaust brake.
02-07: 40 gal '05 F550 aft-axle tank = ~60 gal total.
03-07:DIY/RDS stage 1's, 220,356mi, BTS downpipe & 6pos chip.
04-07: 226,000mi 277HP, 543TQ, Graph
05-07: EGT, Boost, Trans from Tymar
06-07: 4" exhaust, 31 row 6.0L trans cooler
08-07: BTS Transmission.
09-07: 80.76 @ 16.527
My picture & diagrams
danjreed is offline
Old 11-28-2006, 08:59 PM   #11 (permalink)
How do you know?
If the hitch broke lifting up the rear of a 3/4 ton, It would break driving through the field pulling a 35000 lb tractor plus trailer. How much does the rear end weigh 3000 lb at most right? I second the idea of a pintle hitch unlatched or a hitch popping off the ball.
on another note why the he#$ did he not have some kind of jack or something holding up the rear of the trailer [img]/ubbthreads/images/graemlins/shrug.gif[/img]
89' 7.3 lwb 12'flatdeck 4x4 5 spd.
HughJazz is offline
Old 11-29-2006, 01:41 AM   #12 (permalink)
My Photos: (33)
I'm surprised the trailer didn't try and shoot forward and put a hole in his tailgate. But agreed that the pintle latch failed.
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
Dualie is offline
Old 11-29-2006, 12:33 PM   #13 (permalink)
I wonder what kind of brakes that trailer uses? Most that size are air, but i guess it could be electric over hydraulic.
Ford06 is offline
Old 12-12-2006, 11:06 PM   #14 (permalink)
Tom S's Avatar
My Photos: (20)
That video shows it has Bloodhound virus on my computer.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Tymar intake, Cowl Hood, 4" Stainless Magnaflow/Aeroturbine exhaust
14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
Old 12-13-2006, 09:27 AM   #15 (permalink)
Yep, happens all the time with tag trailers like that. Those hitches take a beating after while (might have even had wrong ball size) and get worn out, they love to "jump track" so to speak! More than likey the trailer has a 2 5/16" ball and ding dong in truck had a 2".
That guy should have kept a pintle hitch set up on that trailer. It might have still picked up the rear of the truck (good way to break the parking gear in the trans) but at least it wouldnt have tore the hell out of the truck.
I wont even comment on the actual act of hauling a bulldozer with a pickup truck [img]/ubbthreads/images/graemlins/bleh.gif[/img]
Just eating rainbows and butterflies
01 F350 dually 4x4 CC auto.
311 hp 610 torque a while back.
My Pickup
Some Photos and Sound Clips
Diesel Power & Performance Derby Ks.
#46
Kanman is offline
