Whats GAWR mean in trailers????? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 02-26-2006, 04:25 PM Thread Starter
I was reading the big tex web site on a 20foot GN and I see it said GVWR 14,000 then it said GAWR 6,400lbs???? Whats the GAWR mean???????? Also does anyone know how much the 14GN 20+5 weighs?
2003 F-250 ext cab 7.3 Powerstroke
Sport Package
Stock for now
Derag2 is offline
post #2 of 8 (permalink) Old 02-26-2006, 04:58 PM
Re: Whats GAWR mean in trailers?????
GAWR= Gross Axle Weight Rating. Meaning, if you were to weigh the trailer the axles shouldn't have more than 6400 lbs each, or 13,800 total. They would never have that much anyway, as 14000 lbs trailer has roughly 2500 lbs pin weight. That would put 11500 on the axles and 2500 on the truck. I really can only guess what the trailer weighs, but I'd say between 4500-5000 lbs dry.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
post #3 of 8 (permalink) Old 02-26-2006, 05:20 PM Thread Starter
Alrighty,
Thanks a bunch...
Sport Package
Stock for now
Derag2 is offline
post #4 of 8 (permalink) Old 02-26-2006, 06:52 PM
SmokeyWren's Avatar
My Photos: (45)
Gross axle weight rating. The max amount of weight each axle can carry.
So single tires must be rated for at least 3,200 pounds each.
And two axles could carry a max of 12,800 pounds. So they assume hitch weight of 1,200 pounds to come up with the GVWR.
But hitch weight on a properly-loaded and balanced gooseneck trailer will be about 18 to 20 percent. So when you were grossing 14k on the trailer, you have a hitch weight of around 2,500 to 2,800 pounds. Subtracting that hitch weight from the GVWR means that you'd never come very close to overloading the trailer axles as long as you never exceeded the GVWR of the trailer. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Some trailers set the GVWR as the total of the GAWRs, ignoring hitch weight altogether. I guess they don't want any problems with blow outs. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
SmokeyWren is offline
post #5 of 8 (permalink) Old 04-15-2015, 10:14 PM
85 14 bolt 10 1/2 weight ?
I have a restored 85 GMC C3500 with a 14 bolt 10 1/2 inch Corporate "American Axle" rated at 8,900 pds, I have purchased a 38 ft 3 axle Fifth wheel RV Trailer with a total weight of 9,999 pds!
Will be pulling it from D.C. to Houston, Tx!
Can it pull it considering that all axles have been fully rebuilt, bearings, seals, brakes, new tires "Dually", pinion/diff rebuild????
Thks
Ben
832-764-2357
bmcclure0561dad@gmail.com
bmcclure0561dad is offline
post #6 of 8 (permalink) Old 04-15-2015, 10:48 PM
GAWR indicated the weight an axle can bear, not what it can pull. For example, my 2005 SRW f350 can support 7000lbs on the rear axle, but it can pull a 140 tonne train car if it has enough traction.
Matthew
2005 F-350 ext. cab long box, FX4
Blue Spring
BCP High Idle Mod
DS Bypass Coolant Filter
Rotella Ultra ELC
Rotella T6 Synthetic; 0w-40 (winter) & 5w-40(summer)
EGR Cooler Delete
Bulletproof Oil Cooler, Oil Filter, & Amsoil Bypass Oil Filter
276 000km/172 500 miles as of April. 1 2015.
Canadian Mind is offline
post #7 of 8 (permalink) Old 04-16-2015, 10:03 AM
69mach1377's Avatar
^that would make a great commercial
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, otherwise mostly stock.
Jayco 26BHS elite, no RV parks...just the woods.
69mach1377 is offline
post #8 of 8 (permalink) Old 04-18-2015, 09:43 AM
Pretty sure someone already did it.
Matthew
Blue Spring
BCP High Idle Mod
Rotella Ultra ELC
EGR Cooler Delete
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
