I don't have a lot of experience towing with a brake controller, I came to this forum and after reading felt that Prodigy gave the best bang for the buck. I have not been sorry. I am extremely pleased with its performance and as you say simplicity.
04.5 ram quadzilla standard box with commander, aero turbine mufler with an AFE fre flow, amsoil nanofilter on a AFE montster intake.
My other diesel fix
Dieselbombers.com
The manufacturers already put pressure switches and in some cases pressure sensors on the hydraulic circuits. You might be able to feel a difference on an all drum brake truck but with disc brakes and the deflection in calipers, you cannot feel the very slight amount of displaced fluid used by a pressure sensor or even the old hydraulic controllers.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.88 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 feet on the floor Elite/Outlaw LQ horse trailer. Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
My other diesel fix
Dieselbombers.com
Come on folks, what ever happened to Jordan Ultima? Just a vague mention of it above. It was all the rage about 4 years ago. I'm still using mine. Whenever the pedal is depressed, it's working. Forward, reverse, ice...you name it.
True, it's not pressure sensing, but it does work well and you don't have to deal with the momentum garbage.
'02 F350 PSD XLT SC, 6 sp, DRW, Manual 4X4, 3.73, AIC
ISSPRO Boost & Pyro
DP 40-60-80-100-120-140 (each has it's use!)
BTM and 5" curved stacks
6637 filter, Coolant Bypass
CCV (smells like an old tractor)
Other stuff: SS Nerfs, Flddwn Gooser
DIY Exh. brake, Jordan Ultima, Cobra 29NH, Husky Bedbox, front lugnut covers.
Going in real soon: York air compressor, ARB locker and Mag Hytech Cover!
My other diesel fix
Dieselbombers.com
I was just given a Jordan new in the box from my dad. The Tekonsha that I had had some issues in my truck, and he offered to give me the Jordan, as he had bought it and never installed it.
After getting it installed, and using it to pull a few different trailers recently from a 32' gooseneck with a JD backhoe, to a 24' stock trailer it has performed great. I no longer have any jerking that I got accustomed to.
If the man is still making the Jordan when I need another, I will be buying them in the future.
I'll have to look into the jordans as well. thanks for the info
My other diesel fix
Dieselbombers.com
I will second that, until the factory controller in my truck the Jordan was the best brake controller I ever used. It does not rely on deacceleration (inertia) to apply braking action. It has a direct connection to the brake pedal so braking action is completely proportional and not subject to traction of the TV.
08 F250 CC SRW SWB 4x4 6.4L PSD
where do you find the jordans? how hard are they to install? do the truck manufacturers like you taping into their brake?
My other diesel fix
Dieselbombers.com
They are temporarily out of production, due to the company being purchased. It does not tap into the brake line, it uses a cable attached to the brake pedal. It can be easily removed. I never had to have my Dodge service so I don't know for sure, but I suspect it should not present any problems.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: GRI</div><div class="ubbcode-body">where do you find the jordans? how hard are they to install? do the truck manufacturers like you taping into their brake? </div></div>
GM incorporates a plug in wire harness for the controller add on. Plug in the harness on the firewall behind the parking brake and your set. Everything is wired in to the 7pt plug at the bumper. They got tired of everyone tapping into the wrong wires for sensors.
yeah my dodge has a plug for an aftermarket brake controller. Tekoshna sells a harness to hook up to the 03-06 doges and other models.
My other diesel fix
Dieselbombers.com
Guess I am going to have to break down and speed the $$ to get a MaxBrake unit. First had a Tekonsha Voyager but the pendulum would start swinging with the surging of the front rotors amplifying the action till my whole rig would be bouncing like a rodeo bull. Read many of the rave reviews on the Tekonsha Prodigy and the electronic accelerometer, figured it would be a better option, in some ways it is better but it will also go through the bouncing problem as was experienced recently while hauling some pine logs to the dump. The gooseball load was heavier on the truck than what I usually load the JD5300 4x4 tractor and it started bouncing as I slowed to turn which is when it became apparent money was going to have to become a very secondary issue to get away from this issue. I know new rotors will help also, but you never know when that problem will recur.
GOD BLESS OUR TROOPS!! - GOD BLESS AMERICA!!
