Old 08-13-2005, 05:35 PM   #1 (permalink)
My Photos: (5)
where can i find the factory trailer wiring connector under the dash?
I bought the prodigy and the wire harness for a ford. The only plug that i found that looks like the one i need is tucked in tight and feels like it is mounted in place. This connector is to the right of the steering column and is attached to some metal that is in the area of the wallet pocket on the dash. Where do i find this plug. Also from there, do i just plug and go or is there more to this installation. Thanks. I am not going to use it until tuesday, so i got a couple of days to figure it out. THANKS
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, DP Tuner F5 - no start, stock, 40t, 60t, 80e and 80t, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, currently 80,100 miles. truck Pictures
clydesdale is offline
Old 08-13-2005, 08:06 PM   #2 (permalink)
RDG
RDG's Avatar
My Photos: (15)
Re: where can i find the factory trailer wiring connector under the dash?
That is the location that I found the plug for the controller. See if the plug fits.
If I remember right, there are two plugs in that area. Only one will fit.
Bob
Retired: UAW 383 12.01.03 after 32 years at BENDIX, Allied, AlliedSignal, BOSCH, St Joseph MI Plant
99.5 F-250 CC SRW: Automatic, 3:73 Gears, Tymar Intake, SpeedLiner Bed Coating, Timbren Rubber Springs, Hayden Trans Cooler, Perma Cool Trans Filter, Sonnax Valve & Tricumulator Springs, Reese 15,000lb 5th Wheel Hitch, Tekonsha Prodigy Trailer Brake Controller, Handy Flow Thru T-gate, AFE 4" Exhaust, Warn Hubs, SP Diesel EB, GOS Headlight Harness, Smoked Headlights & Corners with Sylvania Silverstar ULTRA SU bulbs, 08 Sterling Alum Diff Cover, Delphi XM Radio, TomTom One XL-S GPS with ProClip mount
DIESELSITE Stuff: Super Chip 1705 Programmer, AutoMeter Lunar Gauges In Under The Cubby Hole Mount, AC Control Valve, AIH Plug, Coolant filter, Wicked Wheel, BilletTstat Housing, 203 degree Tstat & HX cross over hose..
RDG is offline
Old 08-13-2005, 10:53 PM   #3 (permalink)
My Photos: (21)
Here's FullTimer's Dandy Photo
O
6.0 PSD TSB's
02/03 built F350 6L, DRW, 05 Grille , 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully Airhorns , 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0, In-Dash PC , XM Commander.
Photos
ozhoo is offline
Old 08-13-2005, 11:16 PM   #4 (permalink)
I had to take the screws on the bottom of the panel and trash bag holder loose to reach my hand up there to reach the plug. Mine was also wire tied to the brace.
2001 7.3L F450 4x4 CC Automatic Fontaine Conversion 4:30 Limited slip Reyco Granning Full Air Ride Supension, Transfer Flow Fuel System, 4" MBRP turbo back, gages, pryo pre turbo.
Build Date 03-12-01 in KY. Towing a 34 foot Thor Tahoe toy hauler 5er.
2004 F250 CC SB XLT 6.0 Automatic Gauges Big Walker Truck Muffler towing a 23 foot American Freedom with a buggy inside
OldmanII is offline
Old 08-14-2005, 08:35 AM   #5 (permalink)
My Photos: (5)
well, fulltimers photo is perfect. That is the plug i am talking about. But it is attached to that brace. I will see if it is wire tied as well. I kind of would like to free it up. Can i get it loose or is that futile? Thanks
Old 08-14-2005, 10:37 AM   #6 (permalink)
If you open the panel you can use a small pair of dikes or a pair of line mans scissors to cut it loose.
OldmanII is offline
Old 08-14-2005, 12:35 PM   #7 (permalink)
My Photos: (5)
OK, got it. Thanks guys. Now the question is where to mount it.
Old 08-14-2005, 05:47 PM   #8 (permalink)
My Photos: (21)
Under Cubby and inside cubby and both popular options. Or for something a little far out, get an old shool astray and jam the bugger inside
O
6.0 PSD TSB's
Photos
ozhoo is offline
Old 08-28-2005, 10:36 PM   #9 (permalink)
Ozhoo:
Just want to add my appreciation for the FullTimer's photo. It helped me to find the receptacle easily!
Mike
2002 2WD XLT CrewCab, 3.73 Limited Slip. KC reverse backup lights with on/off dash switch , Mobil 1 Transmission Fluid, Undercover Bed Lid, Monroe Reflex Shocks. Gentex K-21 auto dimming/temp/compass mirror. Michelin LTX/MS tires. Door Seal Mod. ZooDad. Ford SD AIS. Assembled 08-09-01, Cuautitlan Mexico
MikeTEC is offline
