Where to get a trailer rock guard? - Diesel Forum - TheDieselStop.com
Old 04-28-2009, 02:21 PM   #1 (permalink)
I see guys with these big "broom" looking things mounted to their hitches to keep rocks from denting their travel trailers.
Where does one get something like this? The ones I've found online are ridiculously expensive.
Thanks in advance!
2002 F250 7.3 PSD XLT 4x4 EXT Cab Shortbox - EVO2, AIS w/Zoodad, MBRP 4" 409SS, 08 rear diff cover, 6.0 Trans cooler, Heated tow mirrors w/signals
1988 Mustang GT 9.71 @ 143 (1.43 60ft)
2008 H+H 24' CL series V Nose Car Hauler
Blk88GT is offline
Old 04-28-2009, 06:14 PM   #2 (permalink)
rock guard
they sell them in the cabelas truck cat.
they range from 159.99 to 399.99 depending how many adj you want
jcashtrucking is offline
Old 04-29-2009, 10:43 AM   #3 (permalink)
I see you are in Canada so this may not apply but Camping World has a couple different styles and sizes of rear mud/rock guards. I have a solid flap on the rear of my 5th wheel to protect my boat when double towing. I like it better as the broom styles I have seen seem to blow back too much at highway speeds. On my truck I have a Roadwing mud flap setup that attaches to the hitch. It also has solid mud flaps for the same reason-they aren't effected by the wind as much as the broom style. Roadwing or other brands are available at many places.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline
Old 04-29-2009, 11:23 AM   #4 (permalink)
Honestly, I can't believe the cost of these things for what they are. I'm going to try my hand at building my own. $200-$350 buys a lot of material and beer to get the job done.
Blk88GT is offline
Old 04-29-2009, 12:33 PM   #5 (permalink)
My Photos: (60)
True deal, but I would suggest holding the beer till you are done. Otherwise you may not like the install next day.
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 04-29-2009, 12:37 PM   #6 (permalink)
My Photos: (60)
I would also suggest using mudflaps instead of the grass stuff. I have never used either on personal vehicles but have been around trucks and trucking for 35 years. Thinking about it something thrown from the road can go through the grass pretty easily, it is a bit harder to go through one of the reinforced rubber mudflaps you see on older big trucks and trailers and those are pretty cheap mudflaps to buy, you can cut them to size with a sharp knife.
THIS LINK will take you to JC Whitney's version - it really is a simple design, I would think someone could make one pretty easily. Even just bolting the mudflaps to your rear bumper would work, unbolt when you do not need them. 4 bolts per side, simple deal.
Old 04-29-2009, 12:44 PM   #7 (permalink)
My Photos: (60)
Just did a quick search and found these hard plastic (these puppies are pretty tough, I have worked with them for many years) for $29 plus shipping for four. You could put the lettering toward the tires if you wanted to and can cut them to size with a jig saw. Anyway it gives you an idea what I am talking about.
CLICK HERE
Old 04-29-2009, 08:25 PM   #8 (permalink)
trampsdieseltruck's Avatar
My Photos: (33)
get freightliner mud flaps they look good with chrome weights,
1992 f250 7.3 nonturbo,4x4 360,000km,auto tranny
trampsdieseltruck is offline
Old 05-02-2009, 11:09 PM   #9 (permalink)
BlueMuleTrucking's Avatar
Send a message via AIM to BlueMuleTrucking
I have a set of anti-sails that have their own frame that mounts behind the spring gusset.
Evan-
2003 Ford F-350 Crew Cab L/B/Dually XLT FX4 7.3L/Auto- Gooseneck Hitch Fifth Wheel Rails, Firestone Air Bags/ Toolbox
BlueMuleTrucking is offline
Old 05-03-2009, 05:38 PM   #10 (permalink)
My Photos: (6)
Try these mudflaps
Enkay MudFlaps | Home
The EnKay's are good units. Give 'em a look.
fordson1 is offline
Old 05-09-2009, 01:08 PM   #11 (permalink)
Bill1013's Avatar
Being in Canada and coping with the perma frost, the broom style won't be worth even looking at. You need something like the Rock guard. Get some old mud flaps cut to length and attach them to an angle iron, mount under the rear bumper with about 4 bolts. Easy to remove when not being used.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
