Old 12-27-2007, 07:42 PM   #1 (permalink)
F350_6's Avatar
My Photos: (5)
Who's running Air Bags with a B&W hitch?
If so what brand? Are your mounted inside the wheel or outside? I've read about brackets failing on some of the "fit's 5th wheel hitch" models, and about the lever rubbing a hole in the bag on another one. I don't need onboard air just a decent set of bags.
02 F350 SRW CC LWB.
Thanks.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 305,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
Old 01-08-2008, 09:46 AM   #2 (permalink)
bcoakley's Avatar
Re: Who's running Air Bags with a B&W hitch?
Surprised you haven't got a response on this one yet. I have the Firestone airbags on mine with the B&W. I think they are model #2400. They are mounted directly between the axle and the frame. Initially I ran the filler valves out through the license plate frame, but got tired of dragging my portable airtank along and has since mounted a onboard compressor just in front of the fuel tank and put the gauge and controls in the glovebox. I know some guys have had problems with these bags, I'm wodering how much weight they may have put on them and/or was the install done correctly? I have had no problems at all so far. For me, they make a huge difference, especially in the driveability while towing. Last trip I was kind of in a hurry when hooking up and didn't get enough air in the bags prior to leaving. I usually use a set amount of pounds (65#). Something felt weird, so I asked the wife to open the glovebox and check. Sure enough, only had about 50-55 pounds, she pumped them up to 65# and I could actually feel the difference in how the truck/trailer was driving. Nice to have that capability while running down the road.
2005 Arizona Beige F250 6.0PS automatic, MBRP 4" turbo back, AFE stage I, Diablo Predator programmer, B&W turnover ball gooseneck with 5th wheel companion, Firestone airbags, Dipricol gauges, B&D exhaust brake, Bedrug and Snugtop SL tonneau cover, Zoodad mod.
bcoakley is offline
Old 01-08-2008, 12:50 PM   #3 (permalink)
F350_6's Avatar
My Photos: (5)
Thanks for the response. I ended up getting the Firestone 2330 kit. Had to move the brake lines around a bit so they wouldn't rub but otherwise it worked out great.
Chris
F350_6 is offline
Old 01-11-2008, 08:56 PM   #4 (permalink)
LabRat's Avatar
I've had Air Lift air bags for some time now. Just installed B&W under bed mount hitch (actually had someone do it). Air bags mount over hitch bracket now which has the bag tilted in brackets. I'll test it for now but it may need a bracket mod to get right again. Either way, they ride outsied the frame & the rod doesn't rub on the bag.
1997 F350 7.3L PSD; LB; SRW; Crew cab; RSK with dual front Bilstein shocks; Banks PowerPack; E40D with BadBoy converter & shift kit; 3" DP with 3.5" back; Airlift air bags; Mag-Hytec diff/trans covers; Power Slot rotors; Flex-a-Lite remote trans cooler; Tymar intake & CCV mod; SPDiesel SSEBTC controller; B&W turn-over ball & Companion 5th wheel hitch.
Homepage: http://community.webshots.com/user/rmrusten1
LabRat is offline
Old 01-11-2008, 09:49 PM   #5 (permalink)
I'm with rideblue. My bags also mount between the springs and frame. I can't remember if they are model 2400 or what. I do know that they are the correct bags for my application because I called Firestone and talked with a tech about them when I was shopping for a set.
They've been on there for a couple hundred thousand miles now with zero problems. I pull trailers that sometimes weigh up to 16,500 lbs and the bags make a huge difference, I wouldn't do without them.
"Early" '99, 4-98, F350 2WD CC DRW Lariat, Diablo tuner, Swamps 20* HPOP, 4" turbo back straight pipe & a 5" tip, S&B 12" open element air filter, CCV mod, EBV gutted, Vedder's built 4R100 with triple disk convertor, 6.0 trans cooler, Dfuser T/C lockup mod, DieselSite coolant filter, DieselSite TurboMaster, ITP reg fuel return, 4:10 gear w/lmtd slip,Centramatics, Western Diesel gauges, AIC, Ride Rite air bags & onboard compressor kit, Super-Vu convex mirrors, R.D.S. 91 gal. diamond plate aux fuel tank & toolbox combo, B&W gooseneck & 18K companion 5th wheel setup, Rhino lined, Drawtite 1,000lb leveler bars, Drawtite Activator II, Brown's Welding shop (New Braunfels,Tx)full grill/bumper/headlight guard, TurboNet V-Gate.
508,058 miles and still strokin'.
BioDiesel:
Feed a farmer, starve a terrorist.
N.R.A. Life Member
ProDriver18 is offline
Old 01-16-2008, 07:31 PM   #6 (permalink)
I had a B&W hitch on my 05 F350 w/Firestone air bags don't remember the model number but the bags were installed inside the two frame rails. I normally tow a 5th wheeler weighing in around 17k, let's say king pin weight would be 3.4k. I pump the bags up to 55-65Lbs. and the levels the truck up and removes the rear from squatting. Also, a good trick I use when unhooking the trailer is pumping the bags up to 80 Lbs. so it takes some of the stress off the 5th wheeler landing gear. After I lower the landing gear down then I deflate the bags to about 30Lbs. then I unhook the trailer. I just bought a F450 and I also installed the Firestone bags. Great setup.
2008 F450 Lariat 4X4, Line-X, Pace Edwards bed cover, B&W Gooseneck, B&W Companion hitch, Firststone Air Bags. Everything else stock.
2002 Excursion Limited 4X4, 7.3 with Banks Stinger Plus, AFE, Rear sway bars, Bilstien Shocks
PSDCool is offline
Old 01-18-2008, 11:31 PM   #7 (permalink)
F350_6's Avatar
My Photos: (5)
Well I've had them for a couple of thousand miles now and have to say I can't believe I waited 238,000 miles to get some. The 2 things I have noticed that I did not expect is
1) My headlights work better now since my rear spring sag is corrected.
2) The inside the frame mount seems to have worsened my rear sway control slightly.
I looked at the air lift springs, but their "no drill" kit involved drilling out a and replacing with a bolt for mounting.
All I know for sure is the first 2 things I'll do to my next truck will be heated seats and air bags. I guess the season will decide which comes first.
Chris
F350_6 is offline
Old 01-23-2008, 10:26 AM   #8 (permalink)
Firestones
If you install these yourself, it will be much easier if you remove the spare tire. You will then have lots of room to move around.
After driving for 500 miles check all nuts and bolts.
2003, F250, Super Duty, Super Cab, 7.3, Auto, 4X4 Silver, 2" lift in front only, 46 gal fuel tank, Billet Grill, 285X75X16 BFG MT, Bilsteins, Firestone Air Rear, B&W Gooseneck, We call it the "Silver Knocker"
reba is offline
