Old 03-08-2006, 01:46 PM   #1 (permalink)
Why do I see fewer 6.0 car haulers (hot shot)?
Why is it that I see less and less 6.0 haulers? Ford was all I saw for a long time. Now I see more Dodges. I just wondered what gives? Does Ford not have more towing capacity? Any thoughts?
Jason [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2005 F250 PSD Auto 3.73 LS Super Cab FX4 Long Box
Repairs to date: Crankshaft seal, External Tranny Filter Housing, Latest Ford reflash for cold weather. Replaced lower intercooler hose.
High Idle mod
John Deere 5105 Tractor.....You gotta love them Deeres
2001 F250 PSD Auto 3.73LS SC Long Bed Camper pkg Off Road Black on Gray No longer have this truck and I miss it
JDeere5105 is offline
Old 03-08-2006, 02:14 PM   #2 (permalink)
Re: Why do I see fewer 6.0 car haulers (hot shot)?
You drive in the wrong state. I see far more new Fords here than any other brand.
Timothy, Colene and the original off-roaders Bonnie and Clyde (Sulcata Tortoises)
04 F350 PSD Lariat CC LB FX4
82 Jeep Cherokee wide track
BadInfluence is offline
Old 03-08-2006, 02:38 PM   #3 (permalink)
I bet it has something to do with hot shoters needing the most reliable rig possible and all the "problems" the 6.0's have had too. No problems here but the talk about it prob swayed alot of people that are in need of a truck that they can count on.
Lovin
04' F-350, Crew Cab, King Ranch, Dually, LOADED.. DPPI Turbo Back, gauges,SCT from kermit, air raid, coolant filter, amsoil bypass
CAN YOU KEEP UP
06' ZX-6R
Dad's rides...
99' 7.3L F-350 Custom flatbed, supercab, dually
96' 7.3L F-250
99' Expedition 5.4L
99' Contour
2 T300 bobcat
6 custom built trailers
03' BMW 330Ci
soccerstud19 is offline
Old 03-08-2006, 03:20 PM   #4 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
[/ QUOTE ]Natural selection? The 6.0 leakers are all dead beside the road. 7.3 L PSDs just keep going right by. (JK, couldn't resist).
haul_n_horses2 is offline
Old 03-08-2006, 03:46 PM   #5 (permalink)
Perhaps these guys dont buy BRAND NEW...i know if i were
beating my truck to death for a living id take advantage of
the used truck market, and try to reduce my cost/overhead
and improve my margin.
I personally cant imagine buying a 52k dollar truck to
make a living...'specially w/ fuel cost and maint. what
they are...
for the life of me i dont know how these hot shot guys
can make a living.
bushpilot is offline
Old 03-09-2006, 12:58 AM   #6 (permalink)
These guys put over 100k a year on their trucks they have to buy new. You couldn't buy a used truck every year. And they get to write the truck off on their taxes so that helps to.
1999 Dodge Cummins 2500 4x4 Quad Cab TST Power Max 3 w/remote, South Bend Clutch Con OFE, Auto meter Ultralite pyro,boost and fuel pressure gauges. Pacbrake
F & A.M. Lodge 266
GeorgeC
"I will own a fleet of Dodges first."
BarrySmith is offline
Old 03-09-2006, 10:33 AM   #7 (permalink)
I run I-95 between NC and SC every month and Bad_Influence is right. Most are pulling campers but the hotshots that I do see are mostly Fords. There is an auto auction down the road from my SC destination and most of the haulers going in and out are Fords also.
You gotta remember too that the Dodges and D/A's have had their problems also and if you read enough of these forums for the different brands you'll see that all of the big three have had their problems.
I feel that the 6.0 problems are mostly in the past but that the early failures put such a stigma over the engine that it has a bad name now. Remember too that you don't usually hear about the hundreds of thousands of 6.0 engines happily plying the roads everyday.
Would I buy another 6.0 powered truck? Absolutely, there are other things that I like than just the engine. Besides, I find it hard for me to sit in a Dodge, let alone drive one any distance.
Capt Ron
May 2003 F-350, CC, DRW, 6.0L, 6sp man, LB, Al Wheels, Moon Roof, 52gal tranfer tank. Hitches: Draw-Tite 16K 4X and B&W GN, 8040lbs GVW. Towing 35' Newmar Kountry Star 5th Wheel Camper, 14,000lbs GVW, or Wells Cargo 24' Car Hauler, 12,000lbs GVW.
CaptRon is offline
Old 03-10-2006, 05:22 AM   #8 (permalink)
My Photos: (10)
Because most small carhaulers are going to single axle big trucks for the sleeper and more power and wieght.
j_apetersen is offline
Old 03-10-2006, 06:40 PM   #9 (permalink)
My Photos: (13)
May see even more Dodges now the the Cab and Chassis trucks have a 6.7 liter cummins (larger than the 5.9)
http://www.dodge.com/en/chassis-cab/...pe=tradePicker
Ag__Teacher is offline
Old 03-14-2006, 06:44 PM   #10 (permalink)
My Photos: (27)
We do here in Wyoming as well. We have between 10-15 hot shot drivers pull in our shop (National Oilwell, Downhole tools) every day dropping off & picking up mud motors. The majority are 6.0 Power Stroke Super duties with the Dodge Cummins a close second. The D-max Chevy's are far and few between.
Lane
2008 F-350 Lariat, 6.4 PSD, 4x4 Dually
Tow Boss, 4:30 gears, 450 wide track, 6" Pro Comp radius arm lift, MX6 reservoir shocks, 22" American Force dually whls, 37" Toyo MT's, Buckstop bumper w/Warn 16.5, APM Ram air hood.
North Texas Power Stroke Association & Wyoming Power Stroke Association
BadSuperduty is offline
Old 03-16-2006, 09:09 PM   #11 (permalink)
My Photos: (12)
Fuel economy. Every Dodge i have ran with has done between 2 and 3 mpg better than my 6.0 loaded and empty....................
05 Expedition 5.4 3 valve. (It does better in the mileage catagory on the interstate than my 6.0 EVER did!!!!)
GONE!!!!!!2003 F250 CC 4x4 <font color="red"> 6.0 PSD</font> 6 Speed, 3.73 XLT Dark Shadow Gray ,Moonroof, Camper Package, Skid plates ect. (Gutless PIG from idle to 1800) May 12th 03 build week. 122,000 miles as of 01/01/07......... 4" exhaust and AFE intake b&w turnover ball.
Flashed 6 times, EGR cooler replaced, VVRT solenoid replaced, Turbo Ped Replaced, EGR valve replaced 2X NO LEAKS!!! 8 new injectors, new fuel pump, new FICM, new ball joints, Exaust manifold gaskets, both front wheel bearing assy's, The list goes on and on!!!
Former trucks:
89 F250 2wd 7.3 5spd with 256K when sold
94 F250 4X4 IDI Turbo 7.3 5 spd 160K when sold
95 F250 S/C 4x4 PSD 5 spd with 146K when sold
00 F250 C/C 4X4 PSD 6 Spd with 126K when sold (160K now)
None of these trucks EVER spent a day in the shop!!!!
mjstef is offline
Old 03-20-2006, 02:29 PM   #12 (permalink)
Yeah dodge will get better fuel milage but from my expierience haulin cars I have blown any dodge out of the water when it comes to running up a good grade. I agree though I am an OTR driver and I am seeing a lot of 05 6.0 fords my guess is because the brake controler. My personal opinion on the 6.0 is carry a lot of coolant with you if your pullin something heavy. I have a 03 7.3 and I would not trade it for a 6.0 ever. I am not trying to put any 6.0 owner down but I would not recommend a 6.0 for hotshotting. I very often see them on the roadside puffing white smoke with the driver on the phone calling a tow truck. They just dont like the massive strain on the aluminum heads.
03 7.3 EXT. cab 4x4 Powered by No Limit Diesel Performance, Trucks By Buck. DIY Tymar, IDMed, 5" Hypermax 3.5"DP, Autometer gauges, DP Tuner 6 pos. stock/40/80/100/140/High Idle, heater plug delete, BTS Valve Body a must for those of you who cant afford a BTS tranny yet, WW, and the Zoodad MOD.
milskired is offline
Old 03-20-2006, 09:02 PM   #13 (permalink)
mr mill,the 6.0 dosent have aluminum heads.the duramax does...
the fleet; ferds ,02'f350,[97'f350,90'f250 now gone].the generals ,82'2500, 82'2500 4x4, 82' blazer, 86' blazer ,93'3500, 96'3500, and a 99'3500hd soon to be 12v powered. the goats, 90'd250, 91'd350 4x4,[95 model 3500 now gone],00 model 3500 now wrecked, 05'3500. all are diesel powered. a list of bigger stuff, as well as gasser's, got lucky, wife comes from a family that collects junk iron too!
navistar45 is offline
Old 03-21-2006, 01:24 AM   #14 (permalink)
I appologize about that I thought the 6.0 had ALUM. heads also. What I do know is my dad being a mech for Ford said that they have had a number of 6.0s come in with bad head gaskets and also one with either a cracked or warped head on it. The truck had under a 100K on it to thats what I find scary about towing anything with one.
Old 03-21-2006, 08:52 PM   #15 (permalink)
i wouldnt be shocked at the headgasket going bad.way i understand is the 6.0 has 10 head bolts per side,could be the reason for the gasket failures,just a theroy.
