Old 05-13-2008, 12:57 PM   #1 (permalink)
My Photos: (5)
Will a smaller skidsteer, like bobcat 743 or 753 work on 12ft dump trailer?
I have a low profile 12ft dump that I want to tow a skidsteer home with. Any idea if this will work. I realize a longer trailer would be better, but this is what I have. Thanks
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 85,100 miles. truck Pictures
clydesdale is offline
Old 05-13-2008, 03:09 PM   #2 (permalink)
Chyrel's Avatar
I have a 12-foot, 14,000-pound PJ dump trailer, and I haul my 4200 John Deere tractor w/ backhoe, (5,000-pounds) don’t even know it’s back there! Of course the bucket hangs over the front, (blocked up) and the doors / tailgate doesn’t quite close.
But it does work.
Why Chyrel? To quote the late great Johnny Cash!
"My name is Sue! How do you do! Now you gonna die!"
2007 Dodge 3500, 4X4 Quad cab SLT, with 6.7L Cummins / 6-speed Aisin, 4:10 gears, and 9 1/2-foot Aluma flatbed.
Long gone
2004 F-550, 6.0 PSD, Torqshift, 4:88 LS axle, Flatbed dump with a 10-ton Scott hoist. Autometer Pyro/trans/boost on pillar. Turbo lifesaver.
Chyrel is offline
Old 05-13-2008, 09:43 PM   #3 (permalink)
As long as you have appropriate tie downs, and tires on the dump that are rated for the load, you should be fine.
2004 F-350 Lariat SRW <><
315 BFGs, Edge Platinum, ARP Studs, & B&W Goose
1998 Cherokee RockCrawler
NCfarmboy is offline
Old 05-15-2008, 11:43 AM   #4 (permalink)
Do it all the time, but I have a 16ft gooseneck dumper. It hauls it fine, but its not the best riding skidsteer trailer I have towed. Mostly I only put an 1845C in there due to the width of the larger skidsteers.
1992 E350 7.3 IDI, 3.73 club van - 160K
1998 Quad cab 2500 12V Cummins, 4x4,auto
2000 F350,DRW converted to SRW,4x4,6 speed,Lariat,Napa 6642 airfilter,Edge Juice w/Attitude,Cody Cushon gooseneck, 165K, Prodigy, 3.73 gears
2002 TDI Jetta Manual 180K
2002 TDI Jetta Manual 200K
2003 TDI Jetta Maual 80K
1999 Polaris Diesel Quad
2004 Kubota BX 1500 599cc diesel
(yah I like the old mechanical diesels)
Truck and Trailer
Westro is offline
