will it tow it safely - Diesel Forum - TheDieselStop.com
Old 04-21-2006, 10:49 PM   #1 (permalink)
My Photos: (13)
Opinions:
Smokey and others...using my current truck 2006 PSD Tow-Boss (see below) will it tow the following trailer with the following load.
Trailer: Econoline 9Ton tilt-deck, Goose-Neck tri-axle trailer, trailer wieght 5K,lbs
Load: John Deere 244J compact loader, wieght no more than 12K,lbs.
Total load 17K lbs or 8.5 tons
Now I am not talking about going cross country but local distance within 50 miles. I don't want to damage truck be illegal etc. It is for my business so the other question begs do I need a CDL for this load? Want to maintain and ensure my insurance covers it.
SD-Dave [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Current Diesels
2008 F-550 CrewCab 4WD...being upfit currently
2006 John Deere 244J Wheel Loader
2006 John Deere 4720 Cab Tractor 4x4
2003 Frieghtliner Sprinter Van MB power
Past Diesels
2006 F-350 Lariat CrewCab-LB Dually 4X4 PSD Tow Boss Pack Chrome Pack,Loaded...Black Tan
Fuso FG Cabover truck
2002 New Holland TN-75 Full Cab 4x4 Tractor
2000 F-450 Reg.Cab 4x4 StakeBody Plow beast
2004 John Deere 3800 Articulated Telehandler
2005 F-350 CrewCab 4x4 sb/srw PSD Dark Stone
2002 Excursion PSD
2000 Excursion PSD
2002 F-350 XLT CrewCab 4x4 PSD sb/srw
2000 F-350 XLT CrewCab 4x4 PSD lb/srw
1999 F-250 XLT SuperCab 4x4 sb/srw V-10 (oops)
1999 GMC Kodiak Flatbed Car Hauler, Cat Diesel pwr
SuperDutyDave is offline
Old 04-22-2006, 12:00 AM   #2 (permalink)
Re: will it tow it safely
Opinions:
IMO in MN you would be fine. Now as business you better check with DMV/DOT in your state on BOTH questions.
My truck 1989 F-250 srw 7.3 ATS turbo. I have legally pulled (with MN-DOT looking it over) over 18k lbs (cargo) on trailer. All they cared is do lights work? are the tires less then (IIRC) 500lbs per sq in of contact surface, the lightest component (tires or axle) is MORE then load on that axle/tire load. And brakes of course.
Some (assumptions check the actual numbers) Your trailer has 3 6000lb axles? (maybe 7200 or more?) so 6000x3+ 18000 lbs for trailer axles. Figure some weight for truck (I tend to put MORE rather then less on truck) lets say 1500 lbs You are withing limits of trailer/truck. (if memory serves)
But you must check local laws.
larry_minn is offline
Old 04-22-2006, 08:56 AM   #3 (permalink)
JimTJr's Avatar
My Photos: (20)
For business use, YOU HAULING IT FOR YOU OWN BUSINESS,,(Grading, Excavating. Ect...) I dont belive you will need a CDL. IF YOU were hauling for money,and have your own transport authority, like I do..(However right now I only have 26k plates) a CDL would be needed... if I step up on trailer and load then I also will need a Class "A" in Missouri I know.
But if your a "contractor" and haul endloaders, skid steers,,,and such.
I think your covered legaly state wise.. CONTACT your insurance agent for that part. If it is for your business,,then I imagine your business insurance will cover it. You may need a "Rider" for the policy, who knows.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 04-22-2006, 04:04 PM   #4 (permalink)
My Photos: (13)
thanks guys...I am sure my insurance will cover it as long as I am not overloaded and/or in non-compliance with state/fed laws. I am hauling for my own internal business use between my commerical owned locations and my home/farm.
The real question is will the truck handle the load legally and physically without damage etc.
Assuming a truck wieght of 8000lbs + 5000lbs,trailer and 12,000lbs loader = 25,000lbs total wieght.
Towboss is supposed to give you 19K towing capacity plus truck for a total allowable of 26K...
Am I wrong any thoughts in this area?
Current Diesels
Past Diesels
2002 Excursion PSD
2000 Excursion PSD
Old 04-22-2006, 04:14 PM   #5 (permalink)
Roy_Boy's Avatar
You might want to weigh your truck and trailer empty on a certified scale, my F250 and econoline 29' 12 ton tilt deck weighs in at like 15,000 empty.
As long as you are under 26k combined and stay within your state, not doing "for-hire" hauling, you shouldn't need a CDL, but check with your state, just to be sure. States do vary on regulations.
I've pulled 38k lbs combined, with my F250, and didn't break anything, but that's another story. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Roy
2011 F450
Lariat Ultimate
Duraflap Mud Flaps w/ SS
Retrax PRO Bed Cover
Otherwise stock
Roy_Boy is offline
Old 04-23-2006, 07:43 AM   #6 (permalink)
Yes the equipment is capable of going from point A to point B with that load.
It can do it without breaking anything.
You will be within "legal" limits weather or not you are within Fords recomendations.
Is the DRIVER capable?
The driver is what is going to make this "Safe" or not.
Some people aren't "Safe" in a truck that is empty.
Being "Legal" isn't going to make anyting "Safe" nor is having lots of insureance.
If you or your driver kills someone, does it really matter if you were legal or right or wrong??? The person is still DEAD & YOU did it.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
Old 04-23-2006, 08:10 AM   #7 (permalink)
My Photos: (13)
Thanks for the info guys...I thought I was alright...but I've been wrong before...just ask my wife [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
As for the driver being safe...yes that could be another story...but considering it is me and I have driven and hauled large loads many times with no problems, I am not concerned.
When its your insurance but ultimately your "ass" and checkbook on the line you don't take chances....
See you guys on the road
Current Diesels
Past Diesels
2002 Excursion PSD
2000 Excursion PSD
