Old 03-06-2007, 10:14 PM   #1 (permalink)
MLT
Wire Harness Routing from Bumper to front of Wheel Well
Was wondering what people were doing for routing wiring harness from bumper plug to a plug location in front of the drivers side wheel well.
Are there any issues routing it from the rear bumper directly into the fender and then over the wheel well? Any concern over dirt that might accumulate in fender above wheel well, or lack of tie-down points for harness following this routing?
Don't think the harness I bought is long enough to be routed along the frame to the Diesel tank and then up along the fender.
Thanks!
2007 F-350 4X4 King Ranch, 6.0/Torqueshift FX4, SRW, 20" Aluminum Wheels, ESOF, Tow Command, 3.73 Diff, White/Arizona Beige, Build Date: 06/06
MLT is offline
Old 03-08-2007, 10:17 AM   #2 (permalink)
Re: Wire Harness Routing from Bumper to front of Wheel Well
I have read your question a few times and I'm not clear I understand it. You are routing a plug from the rear bumper area to somewhere just in front of the fuel tank? Everything on my truck goes along the frame, which seems to be the straightest shot. Up and over the wheel seems like it would be more wire?
07 F350 4X4 XL supercab 6.0 Torqshift Lots 'o options, Line X, Isspro EGT, Trans, Voltage in overhead module, airbags, runningboards,mudguards and coolant filter.
My Pictures
DesertDave is offline
Old 03-08-2007, 11:13 PM   #3 (permalink)
MLT
Sorry for the confusing wording, What I was trying to say was that from under the truck the location would be approximately at the back end of the fuel tank is where I would leave the frame to go into the fender with the harness.
The plug location in the bed, is just in front of the wheel well in the bulged section at the bottom of the side wall.
Will check the routing along the frame again but on the previous attempt I came up short by about a foot with the harness I have.
Thanks!
Marc
MLT is offline
Old 03-09-2007, 12:18 PM   #4 (permalink)
tbeck's Avatar
What about going from factory location to rear of fender? I have my 6 pin located in the box at the rear drivers corner. No more having extra harness dragging on highway....
'94 1/2 F250 4x4, SuperCab XLT, 5 spd, SMF w/ Valaeo clutch, 4.10 (syn. lube), 5w40 Rotella T Syn, manual hubs, Flip over Gooseneck hitch, authentic Tymar intake, 4" AFE exhaust, FRP mod., Isspro boost/pyro,digital thermometer, homebuilt exhaust brake, 153K
tbeck is offline
Old 03-09-2007, 01:44 PM   #5 (permalink)
Paul H's Avatar
My Photos: (10)
You can do it two ways.
1 open the back of the bumper connector and use additional wire (the connector lugs are big enough for two wires in each), route the wire along the inside of the frame with the original wire harness then over the top with a rubber hose as a rub guard. Up between the inner and outer bed side to the new connetion point.
2 mount the new connection plug and going down between the inner and outer bed wall over the frame to the wire harness splicing in at that point. All wire connections tapped into the harness should be made very weather tight.
Paul H
OWNER
2004 Ford F350 6.0L Dualie
1996 Ford F350 7.3L Dualie
FOKISD CLUB MEMBER
FOKISD CLUB SITE WEBMASTER
double U double U double U Dot FOKISD Dot ORG
My Pictures
Paul H is offline
Old 03-11-2007, 08:43 PM   #6 (permalink)
Go to etrailer.com and look for 5th wheel wiring. They have a harness that plugs into the bumper plug with enough wiring and another plug to run up to the bed. Looks like an easy fix. Sorry I don't know how to make a link-I'll have to learn that.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops,Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system,towing a Hitchhiker 33' Discover America and a Lund boat. Stock-for now
Traded-99(built6/98), F350 X-cab, SRW, Auto, 4x4, XLE8 code, A-pillar w/ Trans Temp,Boost & EGT guages, WD chip, Pinnacle 4" exhaust, AIS intake,Tricummulator & Sonnax, Lund running boards, D-Celerator exhaust brake, Amsoil in gear boxes,Towed 32'Snowbird 5th wheel & Lund boat
bobsherrie is online now
Old 03-12-2007, 11:05 AM   #7 (permalink)
My Photos: (6)
I have my GN 6-way in the bed in front of the wheel well int he flat spot there. Drilled the hole and spliced into the factory harness at the rear 7-way pigtail. Got the 6 way wiring from trailer place. - needed 8' (buy 10). routed inside the frame rail with the stock harness and then out to the socket in the bed. Zip-tied it all in place - works great. I like it in front of the wheel well so you dont have to squeeze between the trailer and the bed rails to connect - gives you more room.
Anyway - hope that helps.
99.5 F-250 CC LB 4x4 7.3 Red, Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, Bilstien Shocks, Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, BFG AT/KO 285/75x16, Magnaflow 3.5" DP - 4" Exhaust, 2003 Cup Holder, X-Springs, Rear 4" F350 Blocks, ATS Housing, Edge Evolution (Rev. 19), Banks Big Head, DS Boost Relief, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, Sonnax/Tricum
NRA
Ducks Unlimited
My Truck Pics
Flywheel is offline
Old 03-12-2007, 10:36 PM   #8 (permalink)
MLT
The harness I bought is 8 foot long and already has the two plugs to splice into the OEM harness at the trailer hitch plug without having to cut any wires.
Guess I just need to work the routing along the frame to make the 8 foot length work.
MLT is offline
Old 03-13-2007, 04:14 PM   #9 (permalink)
My Photos: (6)
Yep - that is even better - I wish I had gotten that one....Where di you get it?
NRA
Ducks Unlimited
My Truck Pics
Flywheel is offline
Old 03-13-2007, 10:26 PM   #10 (permalink)
MLT
Bought it from Tweetys.com along with a B&W Turnover Hitch. Cost was around $50 plus shipping for the harness.
MLT is offline
