Old 06-25-2007, 11:17 PM   #1 (permalink)
wiring 7way to winch
Ive got a ft dovetail trailer with a 4500 lb winch that currently run off a car battery. I want to wire it up so I wont have to carry the car battery or jump it to my truck battery to operate the winch.
How do I hook it up to the 7 way to run the winch? [img]/ubbthreads/images/graemlins/smokin.gif[/img]
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
AmaMoparmanbutlikeForrrrrdtrucks
truckdrivindave is offline
Old 06-25-2007, 11:24 PM   #2 (permalink)
Re: wiring 7way to winch
I don't think any of the lines in the 7 pin connector are rated to carry more than 30 amps. The trailer battery charge circuit is on a 30 amp fuse and relay, but that is probably the highest capacity circuit you could run. I would guess that even a small winch like the one you're talking about would draw more than that.
06 F350XL rc,lb,manual 4x4, 6.0 PSD, 6 speed
Upfitter Switches
BCP Idle Control
55 watt halogen back up lights
200 psi 5 gallon air system with hammer 3 horns
Diesel Site Coolant Filter
MattShade is offline
Old 06-25-2007, 11:48 PM   #3 (permalink)
Believer45's Avatar
My Photos: (17)
I second needing heavier wire than you will have in the trailer wiring harness. The winch will pull a lot of juice under a heavy load.
You can get welding cable for an electric welder or get some 4 gauge or so wire from an electrical supply house to run the wiring to the back of the truck, make up another cable from the winch to run along side the trailer light cord and use a separate plug like is used to hook the power from a truck to an electric liftgate - looks like a tractor-trailer plug but only has two posts. Any trailer sales place should be able to help you out.
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
Believer45 is offline
Old 06-25-2007, 11:56 PM   #4 (permalink)
Believer45's Avatar
My Photos: (17)
<font color="red">THIS SOCKET</font> would go on the back of the truck, connected directly to your off side battery (probably driver side) with appropriate breaker protection. Use 4 gauge wire, you have a pretty good run to carry the juice.
<font color="red">THIS PLUG</font> would be used on the trailer, wired to the winch with 4 gauge cable. It can carry 100 amps which should be plenty even when trying to start the winch with a full load on it.
Dave / Believer45
Old 06-26-2007, 09:49 PM   #5 (permalink)
another option, is to run welding lead disconnects, or the plugs that the charger for an electric foklift uses.
On my trailer, I just mounted a group 29 battery in a marine box, and keep it charged with the charge wire in the 7 pin connector, which is on a self resetting circuit breaker, so if it ever draws over 30 amps, it will just pop the breaker.
88' F-350 reg cab, SRW, 4x4.
7.3/ZF5, 4.10's and 33's, rear locker,
banks turbo, 3.5" straight pipe, pump maxed, and advanced 2 degrees.
89' F-150, 351, 435, dual T-cases, rear discs, front electric winch, PTO winch rear, OBA, 40's
Jrod13 is offline
Old 06-27-2007, 12:08 AM   #6 (permalink)
OK I guess this is the route I will take. Ill weld a "table" to hold the battery like on the TTs and with the charge wire from the 7 pin connector.....thanks..... [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Old 06-27-2007, 11:34 AM   #7 (permalink)
JimTJr's Avatar
My Photos: (6)
I THIRD THIS!!!
ANother option would be run a LONG pair of battery cables back to the rear, put a "Fork lift" style battery connector on it and your winch, then plug it in, and kick the AIC to "Charge Protect" when you need it,, that is going to be my plan, I also will have the winch on a receiver so I can remove it, and use it on two different trailers, I agree on not wanting to mess with "Dead batts" on the trailers!
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 06-27-2007, 08:30 PM   #8 (permalink)
I THIRD THIS!!!
This is basically what I did with mine. 10k winch on a receiver (for front or rear of the truck, also mounts on the trailer), 4 gauge welding cables (+ &amp; -) from truck batteries to the front and rear (through pvc pipe) of the truck. All connections are "blue" forklift connectors. To hook from truck to winch when it's mounted on the trailer, I had to make a 4' jumper wire. I also made a set of 4 gauge jumper cables with "blue" connectors on one end so I could use the winch on my '95 Nissian "beater truck" or anyone elses that I might need it on.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
Old 06-28-2007, 05:24 PM   #9 (permalink)
JimTJr's Avatar
My Photos: (6)
Very cool idea to make a plug in jumper cable too,, you could use this either way, to jump another vehicle, or to hook the jumpers to another batt and run the winch,, I'll remember that!
JimTJr is offline
Old 06-30-2007, 12:46 PM   #10 (permalink)
I have plans to do the same and this has been a very useful thread. I was not aware of the 100amp 2 pin connectors. Are the blue forklift connectors something different from this? Thanks to everyone who contributed!
'94 F350 4x4 PowerStroke, 5-speed, 4.10 gears, crew cab, XLT, Luk Clutch, ZF-47, 294,000 miles
'96 F350 4x4 PowerStroke, auto, 4.10 gears, crew cab, XLT, DRW conversion, 436,000 miles
'95 Lance 11'3" Model 900
Diesel_Aggie is offline
Old 06-30-2007, 08:51 PM   #11 (permalink)
I like that one! May put one on my reciver mounted lift gate and get rid of the whimpy one thats on there.
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
Old 06-30-2007, 10:06 PM   #12 (permalink)
Yes they are different. The forklift connectors come in different amp sizes denoted by color. <font color="blue"> These </font> are like the ones I'm talking about.
Joe
