Does anyone make a 5th wheel wiring adapter for the Old Body trucks? I have a 97 F350 Heavy Duty (non-superduty) and have not found an adapter harness. I've seen them for the 98 and up trucks. This an adapter harness that plugs between the oem 7-wire harness and allows you to just plug and play to install the 7-wire in the bed. If anyone has found one, could you point me in the right direction?
1997 F350 Crew Cab 4x4, AT, 4.10, drivetrain is all stock. Toyo Open Country A/T 285/65-18 10-ply on Allied Renegade wheels. Snugtop shell. TYMAR Intake. Coated H-Max DP with 4" exhaust. Donaldson resonator and Cat had to be put to sleep. Just turned 49,000 original miles!!!! Best addition-Wildman chip-(just added) Phantom II gauges. Sonnax valve w/ Tri-C springs and Royal Purple in the trans. B&W turnover with Companion 5th wheel. SuperSprings installed.
do this
get a plug, mount, and the wires (usualy sold in a kit) then pick up a crimper and wire crimp connectors (autozone) youll need 7 connectors (redones i think idr for sure)
then just match them to their places
if you tape them on to the old plug then crimp once you know they are right that will help
this will give you easy but permanat way to put a plug in the bed
also you will not have to worry about a extention coming out of the bottom hitch
and all you need to do is mount the plug on the side of the bed rail with a screw
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops,Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system,towing a Hitchhiker 33' Discover America and a Lund boat. Stock-for now
no luck finding a plug and play adapter for the OBS truck. Guess all the manufacturers think everyone has a superduty. oh well.....
